基于STM32F103ZET6芯片,实际使用没有问题
单片机源程序如下:- /** @addtogroup IAP
- /* Includes ------------------------------------------------------------------*/
- #include "common.h"
- #include "bsp.h"
- #include "cortexm3_macro.h"
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- * Function Name : main
- * Description : Main program.
- * Input : None
- * Output : None
- * Return : None
- int main(void)
- u8 flg = 0;
- #ifdef DEBUG
- debug();
- #endif
- BspInit();
- CommonInit();
- while (1)
- CommonExec();
- if (IS_TIMEOUT_1MS(eTim1, 1000))
- flg? LedOn(LED_5) : LedOff(LED_5);
- flg = !flg;
- #ifdef DEBUG
- * Function Name : assert_failed
- * Description : Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * Input : - file: pointer to the source file name
- * - line: assert_param error line source number
- * Output : None
- * Return : None
- void assert_failed(u8* file, u32 line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
原理图: 无
仿真: 无
代码(仅供参考,有错误请指出):
bootloader.7z
(198.05 KB, 下载次数: 21)
