/*按键K1K2加减数字数码管显示 按键K3K4加减数码管显示
- #include "STC8H.h"
- #include "intrins.h"
- unsigned char NixieTable[]={ 0x03,/*0*/
- 0x9F,/*1*/
- 0x25,/*2*/
- 0x0D,/*3*/
- 0x99,/*4*/
- 0x49,/*5*/
- 0x41,/*6*/
- 0x1F,/*7*/
- 0x01,/*8*/
- 0x09,/*9*/};
- sbit k1 = P0^3 ;
- sbit k2 = P5^4 ;
- sbit k3 = P3^6 ;
- sbit k4 = P3^7 ;
- unsigned int Num,Num1;
- void Delay1ms() //@11.0592MHz
- unsigned char i, j;
- i = 15;
- j = 90;
- do
- while (--j);
- } while (--i);
- void DelayXms(unsigned int x) //@11.0592MHz
- while (--x)
- Delay1ms();
- void Led_Seg(unsigned int date) //显示函数
- unsigned int a,b,c;
- a=date/100%10; //求百位
- b=date/10%10; //求十位
- c=date%10; //求个位
- P14=1;P15=1;P33=1;
- P2=NixieTable[a];//百位
- P14=0;P15=1;P33=1;
- DelayXms(5);
- P2=NixieTable[b];//十位
- P15=0;P33=1;P14=1;
- DelayXms(5);
- P2=NixieTable[c];//个位
- P33=0;P14=1;P15=1;
- DelayXms(5);
- void Led_Seg1(unsigned int date) //显示函数
- c=date%10; //求个位
- P00=1;P01=1;P02=1;
- P00=0;P01=1;P02=1;
- DelayXms(5);
- P00=1;P01=0;P02=1;
- DelayXms(5);
- P00=1;P01=1;P02=0;
- DelayXms(5);
- unsigned char keyscan()
- char x=0;
- if ( k1 == 0|k2 == 0|k3 == 0|k4 == 0)
- DelayXms(10);
- if (k1 == 0) x=1;
- else if (k2 == 0) x=2;
- else if (k3 == 0) x=3;
- else x=4;
- while ( k1 == 0|k2 == 0|k3 == 0|k4 == 0);
- return(x);
- void Timer0_init() //1ms
- AUXR &= 0x7F; //定时器时钟12T模式
- TMOD &= 0xF0; //设置定时器模式
- TL0 = 0xCD; //设置定时初始值
- TH0 = 0xD4; //设置定时初始值
- TF0 = 0; //清除TF0标志
- TR0 = 1; //定时器0开始计时
- ET0 = 1; //开T0中断
- EA=1;
- void main ()
- P0M0 = 0x00; P0M1 = 0x00;
- P1M0 = 0x00; P1M1 = 0xc0;
- P2M0 = 0x00; P2M1 = 0x00;
- P3M0 = 0x00; P3M1 = 0x00;
- k1=k2=k3=k4=1;
- Num=123;Num1=456;
- Timer0_init() ;
- while(1)
- unsigned char y;
- y=keyscan();
- if(y!=0)
- if(y==1) Num++;
- else if(y==2) Num--;
- else if(y==3) Num1 ++;
- else Num1--;
- void TM1_Isr0()interrupt 1 //数码管扫描定时器0
- unsigned int s;
- if(++s>1)
- { s=0;
- Led_Seg(Num);P00=1;
- Led_Seg1(Num1);
