stc8h8k64u 代码是论坛上的,只显示方格,不显示内容,背光调节了也没有,请大佬看看是什么原因
#include<STC8h.h>
#include <stdio.h>
#define uint unsigned int
sbit RS=P0^5;
sbit E=P0^6;
sbit RW=P0^7;
sbit DB=P2;
void delay(uint del) //延时1ms
uint i,j;
for(i=0;i<del;i++)
for(j=0;j<=168;j++);
void writecmd(uchar com)
E=0; //为什么要写这一条呢,看看时序图就清楚了
RS=0;
RW=0;
P2 = com;
delay(2); //延时一下会稳定很多,后面一条也是一样的
E=1;
delay(2);
E=0;
void writedata(uchar dat)
RS=1;
RW=0;
P0 = dat;
E=1;
delay(2);
E=0;
void init(void)
delay(15);
writecmd(0x38);
delay(5);
writecmd(0x38);
delay(5);
writecmd(0x38);
writecmd(0x38);
writecmd(0x08);
writecmd(0x01);
writecmd(0x06);
writecmd(0x0c);
uchar tab1[]=" www.51hei.com "; //要显示什么就在这儿改
uchar a[]="0123456";
uchar table2[]="sun";
uchar week[][3] = {"MON","TUE","WED","THU","FRI","SAT","SUN"};
uchar j;
P_SW2 |= 0x80; //扩展寄存器XFR访问使能
P0M1 = 0x00; P0M0 = 0x00; //设置为准双向口
P1M1 = 0x00; P1M0 = 0x00; //设置为准双向口
P2M1 = 0x00; P2M0 = 0x00; //设置为准双向口
P3M1 = 0x00; P3M0 = 0x00; //设置为准双向口
P4M1 = 0x00; P4M0 = 0x00; //设置为准双向口
P5M1 = 0x00; P5M0 = 0x00; //设置为准双向口
P6M1 = 0x00; P6M0 = 0x00; //设置为准双向口
P7M1 = 0x00; P7M0 = 0x00; //设置为准双向口
init();
writecmd(0x80); //告诉液晶在哪个地方显示 (设置地址指针)//80H+00
for(j=0;j<16;j++) //有16个字符,要循环16次
writedata(tab1[j]);
delay(2);
while(1);
