查看: 335|回复: 3
51单片机开发板ds1302+lcd1602出现问号,不能正确计时,困扰很久了,求一下解...
回帖奖励 200 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
ID:1091773 发表于 2024-3-3 15:16 | 显示全部楼层 |阅读模式
普中51开发板ds1302+lcd1602出现问号,不能正确计时,请问我代码有什么问题,实在是找不出来了
现在可以确定的是驱动lcd1602的代码没啥问题
感谢大佬的帮助!
单片机代码和现象如下:
main.c
  1. #include <REG52.H>
  2. #include <INTRINS.H>
  3. #define delay()  \
  4.     {            \
  5.         _nop_(); \
  6.     }
  7. sbit DS1302_CE = P3 ^ 5;
  8. sbit DS1302_IO = P3 ^ 4;
  9. sbit DS1302_SCLK = P3 ^ 6;
  10. unsigned char T0RH = 0;
  11. unsigned char T0RL = 0;
  12. bit flag200ms = 0;
  13. void configTimer0(unsigned int ms);
  14. void init_DS1302();
  15. extern void lcdShowStr(unsigned char x, unsigned char y, unsigned char *str);//在lcd1602的x列,y行输出str
  16. extern void initLCD1602();//初始化lcd1602
  17. unsigned char DS1302SingleRead(unsigned char reg);
  18. void main()
  19. {
  20.     unsigned char i;
  21.     unsigned char psec = 0xAA;
  22.     unsigned char time[8];
  23.     unsigned char str[12];
  24.     EA = 1;
  25.     configTimer0(1);
  26.     init_DS1302();
  27.     initLCD1602();
  28.     while (1)
  29.     {
  30.         if (flag200ms)
  31.         {
  32.             flag200ms = 0;
  33.             for (i = 0; i < 7; i++)
  34.             {
  35.                 time[i] = DS1302SingleRead(i);
  36.             }
  37.             if (psec != time[0])
  38.             {
  39.                 str[0] = '2';
  40.                 str[1] = '0';
  41.                 str[2] = (time[6] >> 4) + '0';
  42.                 str[3] = (time[6] & 0x0F) + '0';
  43.                 str[4] = '-';
  44.                 str[5] = (time[4] >> 4) + '0';
  45.                 str[6] = (time[4] & 0x0F) + '0';
  46.                 str[7] = '-';
  47.                 str[8] = (time[3] >> 4) + '0';
  48.                 str[9] = (time[3] & 0x0F) + '0';
  49.                 str[10] = '\0';
  50.                 lcdShowStr(0, 0, str);
  51.                 str[0] = (time[5] & 0x0F) + '0';
  52.                 str[1] = '\0';
  53.                 lcdShowStr(11, 0, "week");
  54.                 lcdShowStr(15, 0, str);
  55.                 str[0] = (time[2] >> 4) + '0';
  56.                 str[1] = (time[2] & 0x0F) + '0';
  57.                 str[2] = ':';
  58.                 str[3] = (time[1] >> 4) + '0';
  59.                 str[4] = (time[1] & 0x0F) + '0';
  60.                 str[5] = ':';
  61.                 str[6] = (time[0] >> 4) + '0';
  62.                 str[7] = (time[0] & 0x0F) + '0';
  63.                 str[8] = '\0';
  64.                 lcdShowStr(4, 1, str);
  65.                 psec = time[0];
  66.             }
  67.         }
  68.     }
  69. }
  70. void DS1302ByteWrite(unsigned char dat)
  71. {
  72.     unsigned char mask;
  73.     for (mask = 0x01; mask != 0; mask <<= 1)
  74.     {
  75.         if (mask & dat)
  76.         {
  77.             DS1302_IO = 1;
  78.             delay();
  79.         }
  80.         else
  81.         {
  82.             DS1302_IO = 0;
  83.             delay();
  84.         }
  85.         DS1302_SCLK = 1;
  86.         delay();
  87.         DS1302_SCLK = 0;
  88.         delay();
  89.     }
  90.     DS1302_IO = 1;
  91. }
  92. unsigned char DS1302ByteRead()
  93. {
  94.     unsigned char mask;
  95.     unsigned char dat = 0;
  96.     DS1302_IO = 1;
  97.     for (mask = 0x01; mask != 0; mask <<= 1)
  98.     {
  99.         if (DS1302_IO)
  100.         {
  101.             dat |= mask;
  102.         }
  103.         DS1302_SCLK = 1;
  104.         delay();
  105.         DS1302_SCLK = 0;
  106.         delay();
  107.     }
  108.     return dat;
  109. }
  110. void DS1302SingleWrite(unsigned char reg, unsigned char dat)
  111. {
  112.     DS1302_CE = 1;
  113.     delay();
  114.     DS1302ByteWrite((reg << 1) | 0x80);
  115.     DS1302ByteWrite(dat);
  116.     DS1302_CE = 0;
  117.     delay();
  118. }
  119. unsigned char DS1302SingleRead(unsigned char reg)
  120. {
  121.     unsigned char dat;
  122.     DS1302_CE = 1;
  123.     delay();
  124.     DS1302ByteWrite((reg << 1) | 0x81);
  125.     dat = DS1302ByteRead();
  126.     DS1302_CE = 0;
  127.     delay();
  128.     return dat;
  129. }
  130. void init_DS1302()
  131. {
  132.     unsigned char i;
  133.     unsigned char code initTime[] = {
  134.         0x00, 0x30, 0x12, 0x08, 0x10, 0x02, 0x13};
  135.     DS1302_CE = 0;
  136.     delay();
  137.     DS1302_SCLK = 0;
  138.     delay();
  139.     i = DS1302SingleRead(0);
  140.     if (i & 0x80)
  141.     {
  142.         DS1302SingleWrite(7, 0x00);
  143.         for (i = 0; i < 7; i++)
  144.         {
  145.             DS1302SingleWrite(i, initTime[i]);
  146.         }
  147.     }
  148. }
  149. void configTimer0(unsigned int ms)
  150. {
  151.     unsigned long tmp;
  152.     tmp = 11059200 / 12;
  153.     tmp = (tmp * ms) / 1000;
  154.     tmp = 65536 - tmp;
  155.     tmp += 0;
  156.     T0RH = (unsigned char)(tmp >> 8);
  157.     T0RL = (unsigned char)tmp;
  158.     TMOD &= 0xF0;
  159.     TMOD |= 0x01;
  160.     TH0 = T0RH;
  161.     TL0 = T0RL;
  162.     ET0 = 1;
  163.     TR0 = 1;
  164. }
  165. void interruptTimer0() interrupt 1
  166. {
  167.     static unsigned char timer200ms = 0;
  168.     TH0 = T0RH;
  169.     TL0 = T0RL;
  170.     timer200ms++;
  171.     if (timer200ms >= 200)
  172.     {
  173.         timer200ms = 0;
  174.         flag200ms = 1;
  175.     }
  176. }
lcd1602.c
  2. #define LCD1602_DB P0
  3. sbit LCD1602_RS = P2 ^ 6;
  4. sbit LCD1602_RW = P2 ^ 5;
  5. sbit LCD1602_EN = P2 ^ 7;
  6. /*等待液晶准备好*/
  7. void lcdWaitReady()
  8. {
  9.     unsigned char sta;
  10.     LCD1602_DB = 0xFF;
  11.     LCD1602_RS = 0;
  12.     LCD1602_RW = 1;
  13.     do
  14.     {
  15.         LCD1602_EN = 1;
  16.         sta = LCD1602_DB; // 读取状态字
  17.         LCD1602_EN = 0;
  18.     } while (sta & 0x80); // bit_7为1时表示液晶正忙,重复检测直到其等于1为止
  19. }
  20. /*向LCD1602液晶写入一字节命令,cmd为待写入命令值*/
  21. void lcdWriteCmd(unsigned char cmd)
  22. {
  23.     lcdWaitReady();
  24.     LCD1602_RS = 0;
  25.     LCD1602_RW = 0;
  26.     LCD1602_DB = cmd;
  27.     LCD1602_EN = 1;
  28.     LCD1602_EN = 0;
  29. }
  30. /*向LCD1602液晶写入一字节命令,dat为待写入命令*/
  31. void lcdWriteDta(unsigned char dat)
  32. {
  33.     lcdWaitReady();
  34.     LCD1602_RS = 1;
  35.     LCD1602_RW = 0;
  36.     LCD1602_DB = dat;
  37.     LCD1602_EN = 1;
  38.     LCD1602_EN = 0;
  39. }
  40. /*设置显示RAM起始地址,亦即光标位置,(x,y)为对应屏幕上的字符坐标*/
  41. void lcdSetCursor(unsigned char x, unsigned char y)
  42. {
  43.     unsigned char addr;
  44.     if (y == 0)
  45.     {                    // 由输入的屏幕坐标计算显示RAM的地址
  46.         addr = 0x00 + x; // 第一行字符地址从0x00起始
  47.     }
  48.     else
  49.     {
  50.         addr = 0x40 + x; // 第二行字符地址从0x40起始
  51.     }
  52.     lcdWriteCmd(addr | 0x80); // 设置RAM地址
  53. }
  54. /*在液晶上显示字符串,(x,y)为对应屏幕上的起始坐标,str为字符串指针*/
  55. void lcdShowStr(unsigned char x, unsigned char y, unsigned char *str)
  56. {
  57.     lcdSetCursor(x, y); // 设置起始地址
  58.     while (*str != '\0')
  59.     {                        // 连续写入字符串数据,直到检测到结束符
  60.         lcdWriteDta(*str++); // 先取str指向的数据,然后str自加1
  61.     }
  62. }
  63. /*区域清除,清除从(x,y)坐标起始的len个字符*/
  64. void lcdAreaClear(unsigned char x, unsigned char y, unsigned char len)
  65. {
  66.     lcdSetCursor(x, y);
  67.     while (len--)
  68.     {
  69.         lcdWriteDta(' ');
  70.     }
  71. }
  72. /*清屏指令*/
  73. void lcdFullClear()
  74. {
  75.     lcdWriteCmd(0x01);
  76. }
  77. /*初始化1602液晶*/
  78. void initLCD1602()
  79. {
  80.     lcdWriteCmd(0x38); // 16*2显示,5*7点阵,8位数据接口
  81.     lcdWriteCmd(0x0C); // 显示器开,光标关闭
  82.     lcdWriteCmd(0x06); // 文字不动,地址自动+1
  83.     lcdWriteCmd(0x01); // 清屏
  84. }
ID:164988 发表于 2024-3-3 15:44 | 显示全部楼层
ds1302没有正常工作,ds1302的5.6.7脚加上拉电阻试试。我在仿制别人的时钟时出现过这种情况。
ID:1091773 发表于 2024-3-3 15:48 | 显示全部楼层
谢谢您的回复,板子上是带上拉的,大概率不是硬件问题,因为板子带的DS1302的标程可以正常运行
ID:1091773 发表于 2024-3-3 16:46 | 显示全部楼层
确实如您所说,是这个原因,感谢!
