标题:
FD650b的单片机驱动程序
[打印本页]
作者:
vkbvfhp
时间:
2024-4-5 14:36
标题:
FD650b的单片机驱动程序
FD650b驱动
#include "my_fd650b.h"
#include"stc15f2k60s2.h"
#include"dingshiqi.h"
u8 key_fd650b_data = 0;
sbit din = P3^0;
sbit sclk = P3^1;
sbit FD650b_SDA_READ = P3^0;
#define FD650b_SCL_SET() {sclk = 1;}
#define FD650b_SCL_CLR() {sclk = 0;}
#define FD650b_SDA_SET() {din = 1;}
#define FD650b_SDA_CLR() {din = 0;}
/* the numbering of the frontpanel LED:
--0--
5| |1
--6--
4| |2
--3-- .7
u8 code FD650b_SegCode[]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71}; //共阴段码
void dela_xus(u8 i)
u8 j,k;
for(k=0;k<i;k++)for(j=0;j<10;j++);
void FD650b_Start(void)
// FD650_SDA_D_OUT(); //SDA输出模式
FD650b_SDA_SET();
FD650b_SCL_SET();
//FD650_DELAY();
dela_xus(2);
FD650b_SDA_CLR();
//FD650_DELAY();
dela_xus(2);
FD650b_SCL_CLR();
void FD650b_Stop(void)
FD650b_SDA_CLR();
dela_xus(2);
FD650b_SCL_SET();
dela_xus(2);
FD650b_SDA_SET();
dela_xus(2);
// FD650_SDA_D_IN(); //SDA输入模式
void FD650b_WriteOneByte(u8 WriteByte)
u8 i;
for(i = 0; i != 8; i++)
if(WriteByte & 0x80)
FD650b_SDA_SET();
FD650b_SDA_CLR();
dela_xus(2);
FD650b_SCL_SET();
WriteByte <<= 1;
dela_xus(2);
FD650b_SCL_CLR();
FD650b_SDA_SET();
dela_xus(2);
FD650b_SCL_SET();
dela_xus(2);
FD650b_SCL_CLR();
void FD650b_SDA_D_IN(){ //SDA输入模式
FD650b_Start();
FD650b_WriteOneByte(0x4f); //68H,6AH,6CH,6EH对应4个数码管
u8 FD650b_ReadOneByte(void)
u8 i, ReadByte = 0;
FD650b_SDA_D_IN(); //SDA输入模式
FD650b_SDA_SET();
dela_xus(2);
FD650b_SCL_SET();
dela_xus(2);
ReadByte <<= 1;
if(FD650b_SDA_READ) ReadByte++;
FD650b_SCL_CLR();
FD650b_SDA_SET();
dela_xus(2);
FD650b_SCL_SET();
dela_xus(2);
FD650b_SCL_CLR();
return ReadByte;
void my_FD650_WriteCommand(u8 comm,u8 dat)
FD650b_Start();
FD650b_WriteOneByte(comm); //68H,6AH,6CH,6EH对应4个数码管
FD650b_WriteOneByte(dat);
FD650b_Stop();
void my_FD650_Display(u8 Data1, u8 Data2, u8 Data3, u8 Data4, u8 Brightness)//FD650b_DispSegCode
my_FD650_WriteCommand(0x48 , 0x11);
// my_FD650_WriteCommand(0x48 , Brightness);
my_FD650_WriteCommand(0x68 , FD650b_SegCode[Data1]); //FD650_DIG0 = 0x1400
my_FD650_WriteCommand(0x6a , FD650b_SegCode[Data2]); //FD650_DIG1 = 0x1500
my_FD650_WriteCommand(0x6c , FD650b_SegCode[Data3]); //FD650_DIG2 = 0x1600
my_FD650_WriteCommand(0x6e , FD650b_SegCode[Data4]); //FD650_DIG3 = 0x1700
0x44-0x7f有效,不按下也有码输出,是之前码的,有按下时+0X40
void read_fd650key()
u8 key_fd650 ;
key_fd650 = FD650b_ReadOneByte();
switch(key_fd650){
case 0x6f:
key_fd650b_data = 1;
break;
case 0x47:
key_fd650b_data = 2;
break;
case 0x5f:
key_fd650b_data = 3;
break;
case 0x67:
key_fd650b_data = 4;
break;
case 0x57:
key_fd650b_data = 5;
break;
case 0x4f:
key_fd650b_data = 6;
break;
default: break;
my_FD650_WriteCommand(0x68 , FD650b_SegCode[key_fd650b_data ]); //FD650_DIG0 = 0x1400
my_FD650_WriteCommand(0x6a , FD650b_SegCode[2]); //FD650_DIG1 = 0x1500
my_FD650_WriteCommand(0x6c , FD650b_SegCode[key_fd650 >> 4]); //FD650_DIG2 = 0x1600
my_FD650_WriteCommand(0x6e , FD650b_SegCode[key_fd650 & 0x0f]); //FD650_DIG3 = 0x1700
my_fd650b.h
#ifndef __MY_FD650B_H
#define __MY_FD650B_H
#define u8 unsigned char
#define u16 unsigned int
#define u32 unsigned long
void read_fd650key();
void my_FD650_Display(u8 Data1, u8 Data2, u8 Data3, u8 Data4, u8 Brightness);//FD650b_DispSegCode
#endif
欢迎光临 (http://www.51hei.com/bbs/)
Powered by Discuz! X3.1
