查看: 1121|回复: 0
51单片机循迹小车代码部分
ID:1128116 发表于 2024-7-4 13:23 | 显示全部楼层 |阅读模式
主逻辑需要自己改写
#include <reg52.h>
#include <intrins.h>
typedef unsigned int u16;
typedef unsigned char u8;
int  a=0;
sbit ENA = P1^6;
sbit IN1 = P1^0;
sbit IN2 = P1^1;
sbit IN3 = P1^2;
sbit IN4 = P1^3;
sbit ENB = P1^4;
void Timer0Init();
void XunJi();
void delay(unsigned int t);
sbit zuo1 = P0^0;
sbit zuo2 = P0^1;
sbit zhong = P0^2;
sbit you1 = P0^3;
sbit you2 = P0^4;
u8 PWMCnt1 = 0;
u8 PWMCnt2 = 0;
u8 cntPWM1 = 0;
u8 cntPWM2 = 0;
        Timer0Init();
                XunJi();
void Timer0Init()
        TH0 = 0xFF;
        TL0 = 0xA3;
        TMOD &= 0xF0;
        TMOD |= 0x01;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
void TurnRight1()
        IN1 = 0;
        IN2 = 1;
        IN3 = 0;
        IN4 = 1;
        cntPWM1 = 70;
        cntPWM2        = 55;
void TurnRight2()
        IN1 = 0;
        IN2 = 1;
        IN3 = 0;
        IN4 = 1;
        cntPWM1 = 50;
        cntPWM2        = 40;
void TurnLeft1()
        IN1 = 1;
        IN2 = 0;
        IN3 = 1;
        IN4 = 0;
        cntPWM1 = 55;
        cntPWM2        = 70;
void TurnLeft2()
        IN1 = 1;
        IN2 = 0;
        IN3 = 1;
        IN4 = 0;
        cntPWM1 = 40;
        cntPWM2        = 50;
void Forward()
        IN1 = 1;
        IN2 = 0;
        IN3 = 0;
        IN4 = 1;
        cntPWM1 = 42;
        cntPWM2        = 54;
void Backward()
        IN1 = 0;
        IN2 = 1;
        IN3 = 1;
        IN4 = 0;
        cntPWM1 = 30;
        cntPWM2        = 30;
void Stop()
        IN1 = 0;
        IN2 = 0;
        IN3 = 0;
        IN4 = 0;
void XunJi()
        unsigned char flag = 0;
        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 1)&&(you2 == 0)&&(you1 == 0))   //0 0 1 0 0
                flag = 0;
if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 0)&&(you2 == 0)&&(you1 == 0))   //0 0 0 0 0
                flag = 6;
//        if((zuo1 == 0)&&(zuo2 == 1)&&(zhong == 1)&&(you2 == 1)&&(you1 == 0))   //0 1 1 1 0
//                flag = 0;
////        if((zuo1== 1)&&(zuo2 == 1)&&(zhong == 1)&&(you2 == 1)&&(you1 == 1))    //1 1 1 1 1
////        {a=a+1;}
////        if(zuo1== 1)
////        {a=0;}
//        if((zuo1 == 1)&&(zuo2 == 1)&&(zhong == 1)&&(you2 == 0)&&(you1 == 0))   //1 1 1 0 0
//                flag = 1;
//        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 1)&&(you2 == 1)&&(you1 == 0))   //0 0 1 1 0
//                flag = 2;
//        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 1)&&(you2 == 0)&&(you1 == 1))   //0 0 1 0 1
//                flag = 2;
//        if((zuo1 == 0)&&(zuo2 == 1)&&(zhong == 1)&&(you2 == 1)&&(you1 == 1))   //0 1 1 1 1
//                flag = 3;
//        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 1)&&(you2 == 1)&&(you1 == 1))    //0 0 1 1 1
//                flag = 3;
//        if((zuo1 == 0)&&(zuo2 == 1)&&(zhong == 1)&&(you2 == 0)&&(you1 == 0))   //0 1 1 0 0
//                flag = 4;
//        if((zuo1 == 1)&&(zuo2 == 0)&&(zhong == 1)&&(you2 == 0)&&(you1 == 0))   //1 0 1 0 0
//                flag = 4;
//        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 0)&&(you2 == 0)&&(you1 == 0))   //1 0 1 0 1
//                flag = 0 ;
//        if((zuo1 == 1)&&(zuo2 == 1)&&(zhong == 1)&&(you2 == 0)&&(you1 == 1))   //1 1 1 0 1
//                flag = 1;
//        if((zuo1 == 1)&&(zuo2 == 0)&&(zhong == 1)&&(you2 == 1)&&(you1 == 1))   //1 0 1 1 1
//                flag = 3;
//        if((zuo1 == 1)&&(zuo2 == 1)&&(zhong == 0)&&(you2 == 0)&&(you1 == 0))   //1 1 0 0 0
//                flag = 2;
//        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 0)&&(you2 == 1)&&(you1 == 1))   //0 0 0 1 1
//                flag = 4;
//        if((zuo1 == 0)&&(zuo2 == 0)&&(zhong == 0)&&(you2 == 0)&&(you1 == 0))   //0 0 0 0 0
//                flag = 5;
        switch(flag)
{while(1)
                case 0:Forward();break;//Ö±ÐÐ
                case 1:TurnLeft1();break;//×ó¿ì
                case 2:TurnLeft2();break;//×óÂý
                case 3:TurnRight1();break;//ÓÒ¿ì
                case 4:TurnRight2();break;//ÓÒÂý
                case 5:Backward();break;//»ØÍË
                case 6:Stop();break;
                default:Stop();break;
void delay(unsigned int t)//ÑÓ
    while(t--);
void InterruptTime0() interrupt 1
        PWMCnt1++;
        PWMCnt2++;
        if(PWMCnt1  >= 200)
                PWMCnt1 = 0;
        if(PWMCnt1 <= cntPWM1)
                ENA = 1;
                ENA = 0;
        if(PWMCnt2 >= 200)
                PWMCnt2 = 0;
        if(PWMCnt2 <= cntPWM2)
                ENB = 1;
                ENB = 0;
        TH0 = (65536 - 50)/256;
        TL0 = (65536 - 50)%256;
