查看: 19706|回复: 70
12864在单片机上显示图片
ID:63839 发表于 2014-8-28 16:06 | 显示全部楼层 |阅读模式
  1. #include<stc12.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. #define LCD_data  P0
  6. sbit LCD_RS=P1^0;        // 数据/命令选择端
  7. sbit LCD_RW=P1^1;        // 读写选择端
  8. sbit LCD_EN=P1^2;        // 使能信号
  9. sbit LCD_PSB=P1^6;           // 并/串选择
  10. uchar code table[64][16]={
  11.           0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  12.       0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  13.       0xFF,0xFE,0xDF,0x00,0x1C,0x0E,0x1D,0xFE,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  14.       0xFF,0xFE,0xBF,0xF5,0xFD,0xEF,0xD0,0x21,0xB7,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  15.       0xFF,0xFD,0x81,0x80,0x3C,0x0E,0xD7,0xBD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  16.       0xFF,0xF9,0x7D,0xB5,0xBD,0xEE,0xD0,0x20,0x03,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  17.       0xFF,0xF4,0xEF,0x80,0x3C,0x0E,0xD7,0xFD,0xBF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  18.       0xFF,0xFD,0xAB,0xF7,0xFF,0xFE,0x10,0x3D,0x37,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  19.       0xFF,0xFD,0xAB,0x00,0x00,0x03,0xD2,0xB8,0xAF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  20.       0xFF,0xFD,0x6D,0xEE,0xFB,0x7F,0x90,0x25,0xDF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  21.       0xFF,0xFC,0xED,0xC5,0xF9,0x06,0x4A,0xBD,0x9B,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  22.       0xFF,0xFD,0xEF,0xF8,0xF6,0x7F,0xDA,0xBC,0x6B,0x7B,0xEF,0xBD,0xF8,0x00,0x00,0x00,
  23.       0xFF,0xFD,0x8F,0x07,0x2F,0x03,0x1F,0x31,0xF3,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  24.       0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  25.       0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  26.       0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  27.       0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x00,0x00,0x00,
  28.       0xEA,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFD,0xFF,0xF8,0x00,0x00,0x00,
  29.       0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x3F,0xDC,0xFF,0xF8,0x00,0x00,0x00,
  30.       0xC0,0x2F,0xFF,0xFF,0xF3,0xFF,0xFF,0xFF,0xFF,0xBD,0x8C,0xFF,0xF8,0x00,0x00,0x00,
  31.       0xF1,0xFF,0xFF,0xFF,0xC7,0xEF,0xFF,0xFC,0xFF,0xB9,0x04,0xFF,0xF8,0x00,0x00,0x00,
  32.       0xE8,0xFF,0xFF,0xFF,0x07,0x1F,0x7F,0xFF,0x3F,0xF0,0x20,0xFF,0xF8,0x00,0x00,0x00,
  33.       0xDB,0x7F,0xFF,0xFC,0x0C,0x1C,0x7F,0x7F,0xCF,0xEE,0x71,0xFF,0xF8,0x00,0x00,0x00,
  34.       0xFB,0xF7,0xE3,0xF8,0x00,0x10,0xDF,0x8F,0xF3,0xFE,0x7D,0xFF,0xF8,0x00,0x00,0x00,
  35.       0xFF,0xFB,0xC1,0xF0,0x00,0x00,0x97,0xC1,0xF8,0xFE,0xFF,0xEF,0xF8,0x00,0x00,0x00,
  36.       0xFB,0xEB,0x98,0xE0,0x00,0x39,0x10,0xF0,0x3C,0x3F,0xFF,0xBF,0xF8,0x00,0x00,0x00,
  37.       0xFF,0xF1,0xA4,0xE0,0x00,0x04,0x10,0x1C,0x06,0x1F,0x8F,0x97,0xF8,0x00,0x00,0x00,
  38.       0xFF,0xD1,0x8A,0xC0,0x00,0x00,0x30,0x00,0x01,0x0F,0x07,0x8F,0xF8,0x00,0x00,0x00,
  39.       0xFF,0xE0,0x8A,0x00,0x00,0x00,0x30,0x38,0x00,0x06,0x33,0x1B,0xF8,0x00,0x00,0x00,
  40.       0xFF,0xA0,0x44,0x00,0x00,0x00,0x50,0x40,0x00,0x06,0x4B,0x17,0xF8,0x00,0x00,0x00,
  41.       0xFF,0xC0,0x60,0x00,0x0F,0xC0,0x48,0x00,0x00,0x02,0xA2,0x05,0xF8,0x00,0x00,0x00,
  42.       0xFF,0x40,0x70,0x00,0x3F,0xE0,0x88,0x00,0x00,0x00,0xA2,0x03,0xF8,0x00,0x00,0x00,
  43.       0xFF,0x80,0xF8,0x00,0x00,0xF1,0x04,0x07,0xE0,0x00,0x44,0x01,0xF8,0x00,0x00,0x00,
  44.       0xFE,0x81,0xE8,0x00,0x01,0xC2,0x04,0x4F,0xF8,0x00,0x0F,0x03,0xF8,0x00,0x00,0x00,
  45.       0xFF,0x00,0x08,0x00,0x01,0x84,0x02,0x3E,0x00,0x00,0x1F,0x82,0xF8,0x00,0x00,0x00,
  46.       0xFD,0x00,0x10,0x00,0x00,0x88,0x01,0x06,0x00,0x00,0x10,0x41,0xF8,0x00,0x00,0x00,
  47.       0xFE,0x01,0xE0,0x01,0x13,0x08,0x00,0x87,0x00,0x00,0x10,0x01,0xB8,0x00,0x00,0x00,
  48.       0xFF,0x06,0x20,0x00,0x88,0x10,0x00,0x43,0x00,0x00,0x10,0x01,0x18,0x00,0x00,0x00,
  49.       0xFD,0x0A,0x10,0x01,0x44,0x10,0x00,0x22,0x00,0x00,0x18,0x01,0xB8,0x00,0x00,0x00,
  50.       0xF8,0x11,0x10,0x00,0x80,0x10,0x00,0x21,0x91,0x00,0x14,0x01,0xF8,0x00,0x00,0x00,
  51.       0xFC,0x10,0x88,0x70,0x00,0x10,0x00,0x10,0x22,0x03,0xE0,0x00,0xB8,0x00,0x00,0x00,
  52.       0xFE,0x20,0x84,0x4C,0x00,0x20,0x00,0x10,0x45,0x05,0x31,0x00,0xF8,0x00,0x00,0x00,
  53.       0xF4,0x20,0x43,0x8B,0x80,0xC0,0x00,0x10,0x02,0x08,0x88,0x80,0xB8,0x00,0x00,0x00,
  54.       0xFC,0x20,0x40,0x08,0xFF,0x00,0x00,0x10,0x00,0x18,0x40,0x40,0x78,0x00,0x00,0x00,
  55.       0xF6,0x20,0x40,0x08,0x80,0x00,0x00,0x08,0x00,0x68,0x40,0x00,0xD8,0x00,0x00,0x00,
  56.       0xFC,0x20,0x40,0x08,0x80,0x00,0x00,0x06,0x03,0x90,0x20,0x20,0x68,0x00,0x00,0x00,
  57.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  58.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  59.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  60.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  61.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  62.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  63.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  64.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  65.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  66.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  67.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  68.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  69.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  70.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  72.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  73.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  74.       0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
  75. };
  76. void delay(uint z)                //        延时函数
  77. {
  78.         uint x,y;
  79.         for(x=0;x<z;x++)
  80.          for(y=0;y<110;y++);
  81. }
  82. //写指令数据到LCD
  83. void write_cmd(uchar cmd)
  84. {
  85.         LCD_RS=0;
  86.         LCD_RW=0;
  87.         LCD_EN=0;
  88.         P0=cmd;
  89.         delay(5);
  90.         LCD_EN=1;
  91.         delay(5);
  92.         LCD_EN=0;
  93. }
  94. //写显示数据到LCD
  95. void write_dat(uchar dat)
  96. {
  97.         LCD_RS=1;
  98.         LCD_RW=0;
  99.         LCD_EN=0;
  100.         P0=dat;
  101.         delay(5);
  102.         LCD_EN=1;
  103.         delay(5);
  104.         LCD_EN=0;
  105. }
  106. //12864初始化
  107. void lcd_init()//12964初始化
  108. {
  109.         LCD_PSB=1;                                //并口模式
  110.         write_cmd(0x34);                //基本指令操作
  111.         delay(5);
  112.         write_cmd(0x0c);                //显示开,光标关
  113.         delay(5);
  114.         write_cmd(0x01);                //消除所有显示
  115.         delay(5);
  116. }
  117. //主函数
  118. main()
  119. {
  120.         uchar i,j;
  121.         delay(10);
  122.         lcd_init();                  //初始化
  123.         for(i=0;i<32;i++)
  124.         {
  125.          write_cmd(0x80+i);
  126.          write_cmd(0x80);
  127.          for(j=0;j<16;j++)
  128.          {
  129.          write_dat(table[i][j]);
  130.          }
  131.         }
  132.         for(i=0;i<32;i++)
  133.         {
  134.          write_cmd(0x80+i);
  135.          write_cmd(0x88);
  136.          for(j=0;j<16;j++)
  137.          {
  138.           write_dat(table[i+32][j]);
  139.          }
  140.         }
  141.         write_cmd(0x36);                         //打开绘图模式
  142.         write_cmd(0x30);                         //基本操作模式
  143.         while(1);                                        //没有的话 会一直闪烁 甚至不显示
  144. }
参与人数 1黑币 +100 收起 理由
admin + 100 共享资料的黑币奖励!
ID:26188 发表于 2014-8-28 16:49 | 显示全部楼层
很好  正好需要
ID:63839 发表于 2014-8-28 17:10 | 显示全部楼层
hujia 发表于 2014-8-28 16:49
很好  正好需要
给点评分呗
ID:65477 发表于 2014-8-29 10:20 | 显示全部楼层
有完整的电路图就好了
ID:69833 发表于 2015-4-22 10:44 | 显示全部楼层
谢谢楼主
ID:76348 发表于 2015-5-1 15:12 | 显示全部楼层
观摩观摩!!!!!!!!!!
ID:77973 发表于 2015-5-1 17:46 | 显示全部楼层
不错
ID:79039 发表于 2015-5-7 08:59 | 显示全部楼层
观摩观摩!!!!!!!!!!
ID:79327 发表于 2015-5-12 17:20 来自触屏版 | 显示全部楼层
小白新手,没想到这么简单
ID:77640 发表于 2015-5-12 17:32 | 显示全部楼层
仔细看看
ID:71795 发表于 2015-5-12 20:57 | 显示全部楼层
学习一下
ID:84566 发表于 2015-7-4 18:36 | 显示全部楼层
有交流才有进步,谢谢楼主分享资料
ID:84566 发表于 2015-7-4 18:37 | 显示全部楼层
这个程序没有使用指针,用数组显示图片很慢
ID:85603 发表于 2015-7-15 20:13 | 显示全部楼层
很好  正好需要
ID:78790 发表于 2015-7-15 20:30 | 显示全部楼层
不错不错!!!
ID:80594 发表于 2015-7-17 11:14 | 显示全部楼层
好像要
ID:85926 发表于 2015-7-17 11:23 | 显示全部楼层
看看学学
ID:79481 发表于 2015-7-17 23:09 | 显示全部楼层
看这么多数,看花了
ID:85916 发表于 2015-7-20 07:28 | 显示全部楼层
我也正在学12864
ID:86097 发表于 2015-7-20 09:55 | 显示全部楼层
看下怎么实现显示图片,学习了
ID:79544 发表于 2015-7-29 13:15 | 显示全部楼层
谢谢分享,值得尊敬!
ID:86621 发表于 2015-8-9 21:32 | 显示全部楼层
这是什么啊这么主函数都吗没有
ID:87486 发表于 2015-8-10 09:26 | 显示全部楼层
谢谢楼主了哈
ID:87688 发表于 2015-8-23 15:24 来自触屏版 | 显示全部楼层
要是能串口发送就好了
ID:88769 发表于 2015-8-23 19:23 | 显示全部楼层
应该不错 欣赏下
ID:59084 发表于 2015-10-12 01:06 | 显示全部楼层
51Hei(51黑)论坛有你更精彩
ID:94946 发表于 2015-11-7 00:47 | 显示全部楼层
看看如何先
ID:84147 发表于 2015-11-8 10:55 | 显示全部楼层
有电路图吗,,,,,
ID:72919 发表于 2015-11-11 22:26 | 显示全部楼层
很好 看看
ID:83519 发表于 2015-11-11 23:16 来自触屏版 | 显示全部楼层
学习一下,谢谢啦
ID:91888 发表于 2015-11-12 21:59 | 显示全部楼层
看看是什么图片
ID:79544 发表于 2015-11-13 10:36 | 显示全部楼层
不是什么图形啊
ID:95622 发表于 2015-11-13 12:48 | 显示全部楼层
看看,初学者,向前辈学习
ID:96450 发表于 2015-12-1 01:48 来自触屏版 | 显示全部楼层
ID:97822 发表于 2015-12-1 10:46 | 显示全部楼层
很不错的
ID:98892 发表于 2015-12-9 20:00 | 显示全部楼层
很好  正好需要 谢了
ID:95419 发表于 2015-12-20 11:00 | 显示全部楼层
看看啊  我的12864怎么都不显示
ID:95419 发表于 2015-12-20 11:01 | 显示全部楼层
看看啊  我的12864怎么都不显示
ID:99905 发表于 2015-12-22 23:30 | 显示全部楼层
用C8051F很快就会好吧?但是89C51。。。慢了点儿吧?
ID:101526 发表于 2016-1-3 23:37 来自触屏版 | 显示全部楼层
谢谢楼主
