查看: 8271|回复: 1
51单片机小车制作 STEP2.3 直流电机PWM按键调速
ID:65608 发表于 2014-9-12 01:48 | 显示全部楼层 |阅读模式
上面的如果播放不了,可以去这个地址看http://www.tudou.com/programs/view/Yk844_HjfJ0/
思路什么的,贴吧有http://tieba.baidu.com/p/2807615491?pn=3
#include
sbit PWM_OUT1P=P0^5;
sbit PWM_OUT2P=P0^6;
sbit PWM_OUT3P=P0^7;
sbit key1=P0^0;
sbit key2=P0^1;
bit PWM_OUTDAT1;
bit PWM_OUTDAT2;
bit PWM_OUTDAT3;
bit delaybit1=0; //延时开关
bit delaybit2=0;
unsigned int PWM_t1=0;
unsigned int PWM_t2=0;
unsigned int PWM_t3=0;
unsigned int delaytime_res1=0;//延时长度计数
unsigned int delaytime_res2=0;
unsigned int keybit=0; //按键计数
PWM_OUT1(unsigned int Cycle1,unsigned int PWM_on1);
PWM_OUT2(unsigned int Cycle2,unsigned int PWM_on2);
PWM_OUT3(unsigned int Cycle3,unsigned int PWM_on3);
TMOD=0x01;
TH0=(65536-100)/256;
TL0=(65536-100)%6;
IE=0x82;
TR0=1;
key1=1;
key2=1;
keybit=0;
if(key1==0)
delaybit1=1;
if(delaytime_res1==2)
if(key1==0)
if(keybit<7)
keybit++;
  delaytime_res1=0;
delaybit1=0;
if(key2==0)
delaybit2=1;
if(delaytime_res2==2)
if(key2==0)
if(keybit>0)
keybit--;
delaybit2=0;
delaytime_res2=0;
switch(keybit)
case 1:
PWM_OUT1P=PWM_OUT1(1000,900);
PWM_OUT2P=PWM_OUT2(1000,900);
break;
case 2:
PWM_OUT1P=PWM_OUT1(1000,700);
PWM_OUT2P=PWM_OUT2(1000,700);
break;
case 3:
PWM_OUT1P=PWM_OUT1(1000,500);
PWM_OUT2P=PWM_OUT2(1000,500);
break;
case 4:
PWM_OUT1P=PWM_OUT1(1000,300);
PWM_OUT2P=PWM_OUT2(1000,300);
break;
case 5:
PWM_OUT1P=PWM_OUT1(1000,100);
PWM_OUT2P=PWM_OUT2(1000,100);
break;
case 6:
PWM_OUT1P=PWM_OUT1(1000,0);
PWM_OUT2P=PWM_OUT2(1000,0);
break;
void Time_r() interrupt 1
TL0=(65536-100)%6;
PWM_t1++;
PWM_t2++;
PWM_t3++;
if(delaybit1==1)
delaytime_res1++;
if(delaybit2==1)
delaytime_res2++;
if(PWM_t1==PWM_on1)
PWM_OUTDAT1=0;
else if(PWM_t1==Cycle1)
PWM_t1=0;
if(PWM_on1!=0)
PWM_OUTDAT1=1;
return PWM_OUTDAT1;
if(PWM_t2==PWM_on2)
PWM_OUTDAT2=0;
else if(PWM_t2==Cycle2)
PWM_t2=0;
if(PWM_on2!=0)
PWM_OUTDAT2=1;
return PWM_OUTDAT2;
ID:74784 发表于 2015-3-19 11:14 | 显示全部楼层
单片机与电机之间应该加入驱动电路
