查看: 2760|回复: 1
函数基础
ID:51090 发表于 2014-9-17 14:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<stdio.h>
#define SPACE ' '
#define A 6
int big (int a, int b);
void hop (char ch, int num);
int main (void)
int a, b;
printf ("please input two number :");
printf ("if you want to quit,please enter q\n");
hop (SPACE, A);
while (scanf("%d,%d",&a,&b) == 2)
  printf("%d\n",big (a,b));  //或者设一个数=big(a,b)
          //也不可以写成这样 big (a,b); leser = min;这样错误的,因为主函数不认识第一个式子
return 0;
void hop (char, int)
int count;
for (count=1; count<=A; count++)
  printf ("%c",A);
int max;
if (a>b)
  max = a;
  max = b;
return max;
ID:51090 发表于 2014-9-17 14:41 | 只看该作者
#include<stdio.h>
int imax (int a, int b)
int main (void)
printf ("The maximum of %d and %d is %d.\n",
   3, 5, imax(3));        //error 缺少一个数
   3, 5, imax(3.0,5.0));      //类型不符
return 0;
int imax (n, m)
int n, m, max;
if (n
