查看: 3120|回复: 0
看百度文库上430的MODBUS程序这个文档挺多的,可是我发现函数不全,好像不完整,
ID:65446 发表于 2014-9-22 17:46 | 显示全部楼层 |阅读模式
看百度文库上这个文档挺多的,可是我发现函数不全,好像不完整,有人编过430的MODBUS程序吗,测试通过的,我看过这个程序了,
其中缺少函数,感觉这个不是完整的,有用这个程序试成功过的吗,欢迎探讨
#include "synth.h"
bool CommState;             // 通讯状态
bool  Request;              // 允许接收
bool  Response;             // 允许发送
bool  EnCommWrite;          // 允许通讯写
uchar UDRBuf;               // 通讯接收寄存器缓存
uchar CommIndex;            // 通讯索引
uchar CrcLow;               // CRC低字节
uchar CrcHigh;              // CRC高字节
uchar Interval;             // 3.5字符时间间隔
uchar CommWrEntry;          // 通讯写入口
uchar CommBuf[BUF_SIZE];    // 通讯缓冲区
uint  StartAddr;            // 起始地址
uint RegNum;                // 寄存器数量
int bAudBuf;                // 通讯波特率缓存
int FormBuf;                // 通讯数据格式缓存
extern const StrKeybd Keybd[];
void ResetInterval(void)    // 重置3.5字符时间间隔
    switch(bAudBuf)
        case  0: Interval = (uchar)(1000/( 1200/11.0)*3.5/TBASE); break;
        case  1: Interval = (uchar)(1000/( 2400/11.0)*3.5/TBASE); break;
        case  2: Interval = (uchar)(1000/( 4800/11.0)*3.5/TBASE); break;
        default: Interval = (uchar)(1000/( 9600/11.0)*3.5/TBASE); break;
        case  4: Interval = (uchar)(1000/(19200/11.0)*3.5/TBASE); break;
void OpenComm(void)    // 打开或关闭通讯
    ResetInterval();
    UCA0CTL1 |= (UCSSEL_2 + UCRXEIE);
    switch(FormBuf)
        default: UCA0CTL0 = UCSPB;         break;  // N-2
        case  1: UCA0CTL0 = UCPEN;         break;  // O-1
        case  2: UCA0CTL0 = UCPEN + UCPAR; break;  // E-1
        case  3: UCA0CTL0 = 0;             break;  // N-1
    switch(bAudBuf)
        case  0: UCA0BR1 = (uint)(BRCLK/1200) >> 8;
                 UCA0BR0 = (uchar)((uint)(BRCLK/1200));
                 UCA0MCTL = (uint)((BRCLK/1200-(uint)(BRCLK/1200))*8)<<1;
                 break;
        case  1: UCA0BR1 = (uint)(BRCLK/2400) >> 8;
                 UCA0BR0 = (uchar)((uint)(BRCLK/2400));
                 UCA0MCTL = (uint)((BRCLK/2400-(uint)(BRCLK/2400))*8)<<1;
                 break;
        case  2: UCA0BR1 = (uint)(BRCLK/4800) >> 8;
                 UCA0BR0 = (uchar)((uint)(BRCLK/4800));
                 UCA0MCTL = (uint)((BRCLK/4800-(uint)(BRCLK/4800))*8)<<1;
                 break;
        default: UCA0BR1 = (uint)(BRCLK/9600) >> 8;
                 UCA0BR0 = (uchar)((uint)(BRCLK/9600));
                 UCA0MCTL = (uint)((BRCLK/9600-(uint)(BRCLK/9600))*8)<<1;
                 break;
        case  4: UCA0BR1 = (uint)(BRCLK/19200) >> 8;
                 UCA0BR0 = (uchar)((uint)(BRCLK/19200));
                 UCA0MCTL = (uint)((BRCLK/19200-(uint)(BRCLK/19200))*8)<<1;
                 break;
    UCA0CTL1 &= ~UCSWRST;
    IE2 |= UCA0RXIE;
void Communication(void)    // 通讯
    if((SMM.out1 == COMM) || (SMM.out2 == COMM) || (SMM.out3 == COMM))
        if((bAudBuf != SMM.bAud) || (FormBuf != SMM.ForM) || (!CommState))
            bAudBuf = SMM.bAud;
            FormBuf = SMM.ForM;
            UCA0CTL1 = UCSWRST;
            OpenComm();
            CommState = true;
        UCA0CTL1 = UCSWRST;
        CommState = false;
void SingleCRC(uchar data)    // 计算单字节CRC校验码
    uchar c = CrcLow ^ data;
    CrcLow  = TabCRC[c] ^ CrcHigh;
    CrcHigh = TabCRC[c + 0x100];
__monitor void SilentInterval(void)   // 检测通讯3.5字符时间间隔
    if(CommState)
        if(Interval == 0)
            ResetInterval();
            CrcLow = 0xFF;
            CrcHigh = 0xFF;
            CommIndex = 0;
            if(Response)
                Response = false;
                IE2 |= UCA0TXIE;
                IE2 &= ~UCA0TXIE;
                Request = true;
            --Interval;
bool CheckDataValid(void)    // 检测写入数据的有效性
    uchar c, index = StartAddr + OFFSET;
    for(c = 0; c < RegNum; ++c, ++index)
        uchar buf = c * 2;
        int data = ((int)CommBuf[7 + buf] << 8) | CommBuf[8 + buf];
        if((data < Keybd[index].LowerLimit) || (data > Keybd[index].HigherLimit))
            return(false);
    return(true);
void GetDataToMenu(void)    // 更新参数值
    uchar c, *ta = &SB[(StartAddr + OFFSET) * 2], *src = &CommBuf[8];
    for(c = RegNum; c; --c)
    {                       // 低字节
        *ta = *src;
        ta  += 2; src += 2;
    ta = &SB[(StartAddr + OFFSET) * 2 + 1], src = &CommBuf[7];
    {                       // 高字节
        *ta = *src;
        ta  += 2; src += 2;
void GetDataToBuff(void)    // 取参数值
    uchar c, *ta = &CommBuf[4], *src = &SB[(StartAddr + OFFSET) * 2];
    {                       // 低字节
        *ta = *src;
        ta  += 2; src += 2;
    ta = &CommBuf[3], src = &SB[(StartAddr + OFFSET) * 2 + 1];
    {                       // 高字节
        *ta = *src;
        ta  += 2; src += 2;
void ManageWrite(void)    // 写指令
    uchar c = REGNUM * 2 + 7;    // 指向CRCL
    if(CommIndex < c)
        SingleCRC(UDRBuf);
        CommBuf[CommIndex++] = UDRBuf;
    else if(CommIndex == c)
        if(CrcLow == UDRBuf)
            StartAddr = STARTADDR;
            RegNum = REGNUM;
            ++CommIndex;
            Request = false;
        Request = false;
        if(CrcHigh == UDRBuf)
            if((RegNum >= 1) && (RegNum <= 0x7B) && (CommBuf[6] == (RegNum * 2)))
                if((StartAddr + RegNum) <= COMM_WL_WR)
                    if(!CheckDataValid())
                        CMD |= 0x80; CommBuf[2] = ERR_DATA;    // 非法数据
                        GetDataToMenu();
                        if(StartAddr < (COMM_WL_WR - 2))
                            switch(StartAddr+RegNum)
                                case COMM_WL_WR    : RegNum -= 2; break;
                                case (COMM_WL_WR-1): RegNum -= 1; break;
                                default            :              break;
                            CommWrEntry = ENTRY;
                            EnCommWrite = true;
                    CMD |= 0x80; CommBuf[2] = ERR_ADDR;    // 非法地址
                CMD |= 0x80; CommBuf[2] = ERR_NUM;    // 非法数量
            Response = true;
void ManageRead(void)    // 读指令
    if(CommIndex == 6)
            RegNum = REGNUM;
            CommBuf[2] = RegNum * 2;
            ++CommIndex;
            Request = false;
        Request = false;
            if((RegNum >= 1) && (RegNum <= 0x7D))
                if((StartAddr + RegNum) <= COMM_WL_RD)
                    GetDataToBuff();
            Response = true;
#pragma vector = USCIAB0TX_VECTOR
__interrupt void UART_transmit(void)    // 通讯发送
    uchar c;
    TACCTL0 &= ~CCIE;
    IE2 &= ~UCA0TXIE;
    __enable_interrupt();
    ResetInterval();
    if(CMD == READ)                     // 读指令
        c = CommBuf[2] + 3;             // 指向CRCL
    else if(CMD == WRITE)               // 写指令
        c = 6;
    else                                // 错误的指令
        c = 3;
    if(CommIndex <= (c + 1))
        if(CommIndex < c)
            c = CommBuf[CommIndex];
            SingleCRC(c);
            UCA0TXBUF = c;
            UCA0TXBUF = CrcLow;
            UCA0TXBUF = CrcHigh;
        ++CommIndex;
        __disable_interrupt();
        IE2 |= UCA0TXIE;
        TACCTL0 |= CCIE;
        TACCTL0 |= CCIE;
#pragma vector = USCIAB0RX_VECTOR
__interrupt void UART_receive(void)    // 通讯接收
    UDRBuf = UCA0RXBUF;
    TACCTL0 &= ~CCIE;
    IE2 &= ~UCA0RXIE;
    ResetInterval();
    if(Request)
        switch(CommIndex)
            case  0: if(UDRBuf != SMM.Addr)
                         Request = false;
                         break;
            case  1:
            case  2:
            case  3:
            case  4:
            case  5: SingleCRC(UDRBuf);
                     break;
            default: if(CMD == READ)           // 读指令
                         ManageRead();
                         ManageWrite();
                     else                      // 非法指令
                         Request = false;
                         CMD |= 0x80; CommBuf[2] = ERR_CMD;
                         Response = true;
                     break;
    IE2 |= UCA0RXIE;
    TACCTL0 |= CCIE;
