#include "msp430G2553.h"
int tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
int temp,time;
//毫秒延迟函数
void delay(int ms)
int i;
while(ms--)
for(i=0;i<200;i++);
//纳米延迟函数
void delayns(int ns)
while(ns--);
void display(temp)//现实位置P2.0=SH;P2.1=ST;P2,2=DS
int k,temp1,temp2;
for(k=7;k>=0;k--)
temp1=1<<k;
temp2=temp & temp1;
if(temp2==temp1)
P2OUT |=BIT2;
P2OUT &=~BIT2;
P2OUT &=~BIT0;
delayns(10);
P2OUT |=BIT0;
P2OUT &=~BIT1;
delayns(10);
P2OUT |=BIT1;
int main( void )
// Stop watchdog timer to prevent time out reset
WDTCTL = WDTPW + WDTHOLD;
DCOCTL=CALDCO_16MHZ;
BCSCTL1 = CALBC1_16MHZ;
BCSCTL2 |=SELM_1+DIVM_0;
P2DIR |=BIT3+BIT2+BIT1+BIT0;//P2.3电机PWM输出,P2.2,P2.1,P2.0为I2C显示输出
P1DIR =0x41;
P1REN |=BIT4+BIT5;
P1OUT |=BIT4+BIT5;
P1IE |=BIT4+BIT5;
P1IES |=BIT4+BIT5;
P1IFG &=~(BIT6+BIT4+BIT5);
_EINT();
P1DIR |=BIT6;
int m,time=0,temp;
m=P1IN;
//显示
temp=tab[(2*m)%10];//个位
display(temp);
temp=tab[(2*m)/10];//十位
display(temp);
P1OUT |=BIT6+BIT0;
delay(time);
P1OUT &=~(BIT6+BIT0);
delay(2000);
#pragma vector=PORT1_VECTOR
__interrupt void ddd(void)
if(P1IFG==BIT4)
//脉宽
time +=50;
if (time>2000)time=2000;
P1IFG &=~BIT4;
if(P1IFG==BIT5)
//脉宽
time -=100;
if (time<200)time=300;
P1IFG &=~BIT5;
if(P1IFG==BIT6)
P1IFG &=~BIT6;
//===========EINT()=========================//
#include "MSP430F2272.h"
int temp; //中断中的变量要是全局变量,必须一开始就定义
int main( void )
P1DIR=0XFF;
P1OUT=0X00;
P2DIR=0X00;
P2REN |=BIT0;
P2OUT |=BIT0;
P2IE |=BIT0;
P2IES |=BIT0;
P2IFG &=~(BIT0);
_EINT();
while(1);
#pragma vector=PORT2_VECTOR
P1OUT=1<<temp;
temp++;
if(temp==8)temp=0;
P2IFG &=~BIT0;
