查看: 3418|回复: 1
基于Atmega16L的简单音乐制作
ID:71259 发表于 2014-12-29 01:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
很久没有写过东西了,人懒了。
一直想要搞下AVR,因为是电气而不是电子专业的,整天对着电机啊,交流调速啊,复杂的计算公式,所以学习电子类的东西比较麻烦,最近才有大块的时间来学习AVR,马潮的《AVR单片机嵌入式系统原理与应用实践》不错。
想想也算搞过一些程序了,空间里也没有贴过AVR的程序,就算来个突破下
做了一小段的《卡农》高潮部分。听着感觉不错,呵呵,以前用51的汇编写过《欢乐女神》,听上去不跑调,但是用C51来做,误差实在是太大了,根本没办法听,这次用mega16,外挂8M的晶振,做的是一小段的《卡农》,因为高音的频率太高,蜂鸣器完全受不了,直接破音(哎,什么叫能力有限),所以都降低了7度,即高音变成中音,中音变成低音。听上去还可以,但是难免有些音会走不准。
不废话贴下程序(注解为英文,希望不会写错
// by Witnessiz
// chip : Atmega16L
// frequency : 8,000,000Hz
// function : play music
// output : OC1A(PB5) connect buzzer
#include<avr/io.h>
#include<avr/interrupt.h>
#define uint unsigned int
const uint note[] = {0,1908,1700,1516,1433,1276,1136,1012,956,865,759,716,638,568,506,470};
const uint beat[] = {0,419,470,528,558,627,704,790,837,925,1054,1117,1254,1408,1581,1702};
//const uchar score[] = {4,8,10,4,9,12,10,8,11,4,6,4,8,12,5,4,6,4,7,8,9,4,5,12,8,12}; //《好久不见》一小段
const uchar score[]={12,4,10,2,11,2,12,4,10,2,11,2,10,2,5,2,6,2,7,2,8,2,9,2,10,2,11,2,10,4,8,2,
      9,2,10,4,3,2,4,2,5,2,6,2,5,2,4,2,5,2,8,2,7,2,8,2,6,4,8,2,7,2,6,4,5,2,4,
      2,5,2,4,2,3,2,4,2,5,2,6,2,7,2,8,2,6,4,8,2,7,2,8,4,7,2,6,2,7,2,8,2,9,2,
      8,2,7,2,8,2,6,2,7,2}; //《canon》
volatile uint note_num,beat_num;
int main()
// DDRD |= (1 << PD5);
DDRD = 0x20;
PORTD = 0x20;
TCCR1A |= (1 << COM1A0); // toggle OC1A on compare match [0x40]
TCCR1B |= (1 << WGM12);  //Clear Timer on Compare match (CTC) mode [0x80]
TIMSK |= (1 << OCIE1A);  //Output Compare match Intrrupt Enable [0x10]
beat_num = 1;
TCCR1B = 0x09;
sei();
SIGNAL(SIG_OUTPUT_COMPARE1A)
if(-- beat_num == 0)
  TCCR1B = 0x08; //TCCR1B |= (1 << WGM12); no clock sourse,stop CTC [0x08]
  if(note_num < 112)
   OCR1A = note[score[note_num]];
   beat_num = beat[score[note_num]];
   note_num ++;
   beat_num = beat_num * score[note_num];
   note_num ++;
   TCCR1B = 0x09; //TCCR1B |= (1 << WGM12) | (1 << CS10); clkio/1(no prescale),start CTC [0x09]
   note_num = 0;
   beat_num = 1;
   TCCR1B = 0x08;
后记:果然懒,才写了10分钟。
收藏收藏2 分享淘帖 顶 踩
ID:72577 发表于 2015-4-26 15:24 | 只看该作者
楼主的歌曲怎么弄的
