查看: 5092|回复: 3
STM32 ADC多通道的DMA连续转换
ID:72519 发表于 2015-1-23 17:46 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
描述:用ADC连续采集11路模拟信号,并由DMA传输到内存。ADC配置为扫描并且连续转换模式,ADC的时钟配置为12MHZ。在每次转换结束后,由DMA循环将转换的数据传输到内存中。ADC可以连续采集N次求平均值。最后通过串口传输出最后转换的结果。
程序如下:
#include "stm32f10x.h"        //这个头文件包括STM32F10x所有外围寄存器、位、内存映射的定义
#include "eval.h"             //头文件(包括串口、按键、LED的函数声明)
#include "SysTickDelay.h"
#include "UART_INTERFACE.h"
#include <stdio.h>
#define N   50         //每通道采50
#define M  12          //12个通道
vu16  AD_Value[N][M];   //用来存放ADC转换结果,也是DMA的目标地址
vu16  After_filter[M];    //用来存放求平均值之后的结果
int    i;
/*GPIO管脚的配置
选用ADC的通道0 1  2  8 9  10  11 12  13  14  15,分别对应的管脚为PA0 PA1  PA2  PB0 PB1  PC0  PC1 PC2  PC3  PC4 PC5
串口使用USART1其中TXPA9RXPA10 */
void GPIO_Configuration(void)
         GPIO_InitTypeDef GPIO_InitStructure;
/* Configure USART1 Tx (PA.09) as alternatefunction push-pull */
         GPIO_InitStructure.GPIO_Pin= GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //因为USART1管脚是以复用的形式接到GPIO口上的,所以使用复用推挽式输出
         GPIO_InitStructure.GPIO_Speed= GPIO_Speed_50MHz;
         GPIO_Init(GPIOA,&GPIO_InitStructure);
         /* Configure USART1 Rx (PA.10) as input floating */
         GPIO_InitStructure.GPIO_Pin= GPIO_Pin_10;
         GPIO_InitStructure.GPIO_Mode= GPIO_Mode_IN_FLOATING;
         //PA0/1/2 作为模拟通道输入引脚
         GPIO_InitStructure.GPIO_Pin= GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
         GPIO_InitStructure.GPIO_Mode= GPIO_Mode_AIN;              //模拟输入引脚
         //PB0/1 作为模拟通道输入引脚
         GPIO_InitStructure.GPIO_Pin= GPIO_Pin_0|GPIO_Pin_1;
         GPIO_Init(GPIOB,&GPIO_InitStructure);
         //PC0/1/2/3/4/5 作为模拟通道输入引脚
   GPIO_InitStructure.GPIO_Pin =GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
         GPIO_Init(GPIOC,&GPIO_InitStructure);
/*配置系统时钟,使能各外设时钟*/
void RCC_Configuration(void)
        ErrorStatus HSEStartUpStatus;
    RCC_DeInit();                     //RCC 系统复位
    RCC_HSEConfig(RCC_HSE_ON);      //开启HSE
    HSEStartUpStatus = RCC_WaitForHSEStartUp();  //等待HSE准备好
    if(HSEStartUpStatus == SUCCESS)
      FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
      FLASH_SetLatency(FLASH_Latency_2);     //Set 2 Latency cycles
      RCC_HCLKConfig(RCC_SYSCLK_Div1);   //AHB clock  = SYSCLK
      RCC_PCLK2Config(RCC_HCLK_Div1);   //APB2 clock =HCLK
      RCC_PCLK1Config(RCC_HCLK_Div2);   //APB1 clock =HCLK/2
      RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6); //PLLCLK = 12MHz * 6 = 72 MHz
      RCC_PLLCmd(ENABLE);          //Enable PLL
      while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);  //Wait till PLLis ready
      RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //SelectPLL as system clock source
      while(RCC_GetSYSCLKSource() != 0x08);  //Waittill PLL is used as system clock source
    /*使能各个外设时钟*/
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
             | RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1| RCC_APB2Periph_AFIO |RCC_APB2Periph_USART1, ENABLE );      //使能ADC1通道时钟,各个管脚时钟
         /* Configure ADCCLK such as ADCCLK = PCLK2/6 */
         RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //72M/6=12,ADC最大时间不能超过14M
         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1,ENABLE);      //使能DMA传输
/*配置ADC1*/
void ADC1_Configuration(void)
          ADC_InitTypeDef  ADC_InitStructure;
         ADC_DeInit(ADC1);  //将外设 ADC1 的全部寄存器重设为缺省值
         /* ADC1 configuration ------------------------------------------------------*/
         ADC_InitStructure.ADC_Mode= ADC_Mode_Independent; //ADC工作模式:ADC1ADC2工作在独立模式
         ADC_InitStructure.ADC_ScanConvMode=ENABLE;       //模数转换工作在扫描模式
         ADC_InitStructure.ADC_ContinuousConvMode= ENABLE;   //模数转换工作在连续转换模式
         ADC_InitStructure.ADC_ExternalTrigConv= ADC_ExternalTrigConv_None; //外部触发转换关闭
         ADC_InitStructure.ADC_DataAlign= ADC_DataAlign_Right;         //ADC数据右对齐
         ADC_InitStructure.ADC_NbrOfChannel= M; //顺序进行规则转换的ADC通道的数目
         ADC_Init(ADC1,&ADC_InitStructure);   //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
         /* ADC1 regular channel11 configuration*/
         //设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
         //ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
         ADC_RegularChannelConfig(ADC1,ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );           ADC_RegularChannelConfig(ADC1,ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_8, 5, ADC_SampleTime_239Cycles5 );           ADC_RegularChannelConfig(ADC1,ADC_Channel_9, 6, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_10, 7, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_11, 8, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_12, 9, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_13, 10, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
         ADC_RegularChannelConfig(ADC1,ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
          // 开启ADCDMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
   ADC_DMACmd(ADC1, ENABLE);
         /* Enable ADC1 */
          ADC_Cmd(ADC1, ENABLE);     //使能指定的ADC1
          /* Enable ADC1reset calibaration register */
         ADC_ResetCalibration(ADC1);          //复位指定的ADC1的校准寄存器
         /* Check the end of ADC1 reset calibration register */
         while(ADC_GetResetCalibrationStatus(ADC1));     //获取ADC1复位校准寄存器的状态,设置状态则等待
         /* Start ADC1 calibaration */
         ADC_StartCalibration(ADC1);          //开始指定ADC1的校准状态
         /* Check the end of ADC1 calibration */
         while(ADC_GetCalibrationStatus(ADC1));                //获取指定ADC1的校准程序,设置状态则等待
/*配置DMA*/
void DMA_Configuration(void)
         /* ADC1  DMA1Channel Config */
         DMA_InitTypeDefDMA_InitStructure;
         DMA_DeInit(DMA1_Channel1);   //DMA的通道1寄存器重设为缺省值
         DMA_InitStructure.DMA_PeripheralBaseAddr=  (u32)&ADC1->DR;  //DMA外设ADC基地址
         DMA_InitStructure.DMA_MemoryBaseAddr= (u32)&AD_Value;  //DMA内存基地址
         DMA_InitStructure.DMA_DIR= DMA_DIR_PeripheralSRC;  //内存作为数据传输的目的地
         DMA_InitStructure.DMA_BufferSize= N*M;  //DMA通道的DMA缓存的大小
         DMA_InitStructure.DMA_PeripheralInc= DMA_PeripheralInc_Disable; //外设地址寄存器不变
         DMA_InitStructure.DMA_MemoryInc= DMA_MemoryInc_Enable;  //内存地址寄存器递增
         DMA_InitStructure.DMA_PeripheralDataSize= DMA_PeripheralDataSize_HalfWord;  //数据宽度为16
         DMA_InitStructure.DMA_MemoryDataSize= DMA_MemoryDataSize_HalfWord; //数据宽度为16
         DMA_InitStructure.DMA_Mode= DMA_Mode_Circular;  //工作在循环缓存模式
         DMA_InitStructure.DMA_Priority= DMA_Priority_High; //DMA通道 x拥有高优先级
         DMA_InitStructure.DMA_M2M= DMA_M2M_Disable;  //DMA通道x没有设置为内存到内存传输
         DMA_Init(DMA1_Channel1,&DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道
//配置所有外设
void Init_All_Periph(void)
         RCC_Configuration();
         GPIO_Configuration();
         ADC1_Configuration();
         DMA_Configuration();
         //USART1_Configuration();
         USART_Configuration(9600);
/*获取ADC的值,将二进制换算为十进制*/
u16 GetVolt(u16 advalue)
  return (u16)(advalue * 330 / 4096); //求的结果扩大了100倍,方便下面求出小数
/*求平均值函数*/
void filter(void)
       int sum = 0;
         u8 count;
       for(i=0;i<12;i++)
        for ( count=0;count<N;count++)
          sum += AD_Value[count][ i];
          After_filter[ i]=sum/N;
         sum=0;
int main(void)
          u16         value[M];
         init_All_Periph();
         SysTick_Initaize();
    /* Start ADC1 Software Conversion */
         ADC_SoftwareStartConvCmd(ADC1,ENABLE);
DMA_Cmd(DMA1_Channel1, ENABLE); //启动DMA通道
                   while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待传输完成否则第一位数据容易丢失
        filter();
                    for(i=0;i<12;i++)
                      value[ i]= GetVolt(After_filter[ i]);
                     printf("value[%d]:\t%d.%dv\n",i,value[ i]/100,value[ i]%100) ;
                      delay_ms(100);
总结
该程序中的两个宏定义,M和N,分别代表有多少个通道,每个通道转换多少次,可以修改其值。
曾出现的问题:配置时钟时要知道外部晶振是多少,以便准确配置时钟。将转换值由二进制转换为十进制时,要先扩大100倍,方便显示小数。最后串口输出时在printf语句之前加这句代码,防止输出的第一位数据丢失:while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
收藏收藏1 分享淘帖 顶 踩
ID:219729 发表于 2017-8-3 22:02 | 只看该作者
楼主源程序还在吗?可不可以给我发一份作参考,拜托了,谢谢1424011549@qq.com
ID:203238 发表于 2017-5-21 19:53 | 只看该作者
想问一下,为什么我的程序根本无法打印出结果
ID:78060 发表于 2015-4-26 22:10 | 只看该作者
谢谢分享!收藏了!
