查看: 3091|回复: 0
STM32的AD用DMA方式时的请注意初始化顺序
ID:75263 发表于 2015-6-9 02:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天无意之间看到了这篇帖子,是斑竹好久前发的~~~
我突然意识到我的数据好像一直没有错位,看到这个我又试验了一下,发现把DMA_Cmd(DMA1_Channel1,ENABLE);放置到哪儿都是一样的啊~~~
这个是原帖部分:
珍情岁月(84848098) 17:19:23
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr= ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr= (u32)&ADC_Result;
  DMA_InitStructure.DMA_DIR =DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize= 6;
  DMA_InitStructure.DMA_PeripheralInc= DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc= DMA_MemoryInc_Enable;;
  DMA_InitStructure.DMA_PeripheralDataSize= DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize= DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode =DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority= DMA_Priority_High;
  DMA_InitStructure.DMA_M2M =DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1,&DMA_InitStructure);
  //DMA_Cmd(DMA1_Channel1,ENABLE);//以前在这里启用DMA,出现通道错乱
  ADC_InitStructure.ADC_Mode =ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode= ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode= ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv= ADC_ExternalTrigConv_None;
  ADC_InitStructure.ADC_DataAlign= ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel= 6;
  ADC_Init(ADC1,&ADC_InitStructure);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_11, 2, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_12, 3, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_13, 4, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_14, 6, ADC_SampleTime_55Cycles5);
  ADC_RegularChannelConfig(ADC1,ADC_Channel_15, 5, ADC_SampleTime_55Cycles5);
  ADC_DMACmd(ADC1, ENABLE);
  ADC_Cmd(ADC1, ENABLE);
  ADC_ResetCalibration(ADC1);
  while(ADC_GetResetCalibrationStatus(ADC1));
  ADC_StartCalibration(ADC1);
  while(ADC_GetCalibrationStatus(ADC1));
  ADC_SoftwareStartConvCmd(ADC1,ENABLE);
以上代码转自STM32交流群的“情岁月”(84848098) 17:27:48的发言,在此对他表示感谢。
下面的经验也是“珍情岁月”提供:
用DMA连续采样多路,自动触发,如果在初始化AD前使能了DMA就会出现数据错位现象。
要注意在初始化时将DMA_Cmd(DMA1_Channel1,ENABLE);放置到ADC_SoftwareStartConvCmd(ADC1, ENABLE);前面。
原因是:如果在初始化AD的时候DMA被触发了一次,但是此时并没有采样,但是DMA目的地址已经发生了自加,
当你采样第一路的时候,数据却填充到了第二路。
