由于经常要操作新浪云数据库,特写了如下数据库操作类,留做后续学习使用。
sqlTool.class.php源码如下
<?php
class sqlTool{
private $conn ; // = NULL;
private $port ="3**7";
private $host = SAE_MYSQL_HOST_M;
private $user = "2*wx2*****0";
private $password = "ylx5lj101w****mh1l5i4****h5zzm***3yz";
private $db = "app_s***e*";
public function dblink(){
$this->conn = mysql_connect($this->host.':'.$this->port,$this->user,$this->password);
if(!$this->conn){
die("连接数据库失败".mysql_error());
mysql_select_db($this->db,$this->conn);
mysql_query("SET names 'UTF8'");
return $this->conn; //为了取$this->conn加上的,如不取这个值,可以不用
//完成select语句
public function excute_dql($sql){
$res = mysql_query($sql) or die(mysql_error());
return $res;
//完成update,delete,insert
public function excute_dml($sql){
$b = mysql_query($sql,$this->conn);
if(!$b){
return 0; //失败
if(mysql_affected_rows($this->conn)>0){
return 1; //表示成功
return 2; //表示没有影响到行数
//引用类来操作数据库
//dml操作
$sql = "insert into slb (hyh,guige,menfu,kezhong,dlj,dlw,slj,slw,spj,spw) values('D15086003FY','50*50 144*80 府绸','57/58',120,150,140,3,3,8,8)";
$a = new sqlTool();
$conn1 = $a->dblink();
$res = $a->excute_dml($sql);
if(!$res){
return 0;
else if(mysql_affected_rows($conn1)>0){
echo "操作成功"; // retrun 1;
else {
return 2;
//dql操作
$sql = "select * from slb ";
$b = new sqlTool();
$b->dblink();
$res = $b->excute_dql($sql);
var_dump($res);
echo "hell";
while($row = mysql_fetch_row($res)){
foreach($row as $key=>$val){
echo "$key-->$val";
echo "<br/>";
mysql_free_result($res);
sqlTool_demo.PHP 源码
<?php
require_once "sqlTool.class.php";
//引用类来操作数据库
//dml操作
// $sql = "insert into slb (hyh,guige,menfu,kezhong,dlj,dlw,slj,slw,spj,spw) values('D15086003FY','50*50 144*80 府绸','57/58',120,150,140,3,3,8,8)";
$sql = "delete from slb where hyh = 'D15086003FY'";
$a = new sqlTool();
if(!$res){
return 0;
else {
return 2;
echo "<br>";
//dql操作
$b = new sqlTool();
$b->dblink(); //因为前面dml操作$conn1 = $a->dblink();此处可以不要,也可以要
var_dump($res);
echo "hell";
echo "$key-->$val";
echo "<br/>";
调用演示
