查看: 1904|回复: 1
求大神帮我看下代码怎么改
ID:98832 发表于 2015-12-10 18:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.H>
#include <intrins.h>
#include "lcd.h"
#include "key.h"
#include "delay.h"
#include "eeprom.h"
void int0(void);
unsigned char password[6]/*={0x01,0x02,0x03,0x04,0x05,0x06}*/;
unsigned char password1[6];
unsigned char code aa[]="Password   ";
unsigned char code gg[]="New";
unsigned char code bb[]="ERROR  ";
unsigned char code cc[]="OK      ";
unsigned char code dd[]="       ";
unsigned char code ee[]="Next   ";
unsigned char code ff[]="success ";
unsigned char keydata;
main()
    unsigned char i,j,k,l,m,n,o,a1;
    for(i=0;i<6;i++)
    Write_IIC(i,password[ i]);
    init();//LCD初始化
    int0();
    P3_6=0;
    P3_7=0;
    P1=0x0f;
    LCD_Write_String(0,0,aa);
    LCD_Write_String(1,1,dd);
    write_com(0xc0+1);
start: LCD_Write_String(0,0,aa);
       write_com(0xc0+1);
           if((0<keydata)&&(4>keydata)||(4<keydata)&&(8>keydata)||(8<keydata)&&(12>keydata)||keydata==14)
                  //在0-9之间的数字通过
              password=keydata;//键盘值进行保存
              keydata=0;        //把键盘值置其它值,不被其它利用,以一样
              i++;
              write_data('*');  //在LCD上显示*这字符代表输入了一个密码
              if(i==6)          //这里限制了六位密码
                  i=0;
                  goto panduan;
           if(keydata==33)      //确定进入密码比较
              keydata=0;
panduan:      i=0;
              for(j=0;j<6;j++)
                  l+=password[j];
                  k+=Random_Read(j);
              if(l!=k)      //密码不同进行处理
                  l=0;
                  k=0;
                  LCD_Write_String(0,0,bb);
                  DelayMs(1000);
                  a1+=1;
                  if(a1==2){while(1)P3_7=1;P3_6=0;}//两次错误发出报警
                  goto start;               //第二次输入密码
              if(l==k)   //密码对了,进入运行状态,这里绿灯代表该状态
                   l=0;
                   k=0;
                   a1=0;
                   P3_6=1;
                   P3_7=0;
                   LCD_Write_String(0,0,cc);
                   if(o==1)
                    o=0;
                    LCD_Write_String(0,0,gg);
                    LCD_Write_String(4,0,aa);
                    write_com(0xc0+1);
                    goto text2;
                   goto yingxing;        //跳到下面函数中,yingxing里
yingxing:while(1)
           if(keydata==4)    //锁定功能
              P3_6=0;
              goto start;
           if(keydata==15)      //修改密码
              o++;
              if(o==1) goto start;
text2:        keydata=0;
                         //上面表达式0-9之间的数字通过
                     password[m]=keydata;  //读取键盘值
                     keydata=0;
                     m++;
                     write_data('*');
                     if(m==6)           //到密码输入到六位的时候进行判断是否再输入,或者判断前后两次密码是否一致
                         m=0;
                         n++;
                         if(n==2)goto panduan1;  //输入第二次的时候进行前后两次密码进判断
                         for(i=0;i<6;i++)      //储存前一次密码
                            password1=password[ i];
                         LCD_Write_String(0,0,ee);
                         DelayMs(1000);
                         write_com(0xc0+1);
                  if(keydata==13)     //重新输入改密
text:                 m=0;
                     n=0;
                     write_com(0xc0+1);
                  if(keydata==33)    //退出不改密码
out:                 m=0;
                     n=0;
                     o=0;
                     goto yingxing;
                  if(keydata==33)
                     keydata=0;
panduan1:            for(j=0;j<6;j++)//第一次与第二次密码比较
                         l+=password[j];
                         k+=password1[j];
                     if(l!=k)      //第一次与第二次密码输入错误
                         l=0;
                         k=0;
                         DelayMs(1000);
                         goto text;
                         for(i=0;i<6;i++)
                           LCD_Write_String(0,0,ff);
                           DelayMs(1000);
                           goto out;
void int0(void)
    EA=1;
    EX0=1;
    IT0=1;
void ISR_INT0(void) interrupt 0
    keydata=key_scan();
错误是嵌套太多,谢谢啦
ID:102817 发表于 2016-1-11 23:22 | 只看该作者
自己先仔细检查一下再说吧
