查看: 6772|回复: 4
stm32产生spwm波的pwm寄存器配置与教程工具等
ID:101489 发表于 2016-1-4 18:08 | 显示全部楼层 |阅读模式
有很多种方案可以选择,我现在你解决的方案是用定时器和DMA来做的,还可以有其他很多方法我还没有去试,如果有其他方法成功了的期待分享,不多说了,直接上程序:
  1. #include "stm32f10x.h"
  2. #define TIM1_CCR3_Address    0x40012C3C
  3. TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  4. TIM_OCInitTypeDef  TIM_OCInitStructure;
  5. uint16_t SRC_Buffer[3] = {500, 500, 500};
  6. ErrorStatus HSEStartUpStatus;
  7. /* Private function prototypes -----------------------------------------------*/
  8. void RCC_Configuration(void);
  9. void GPIO_Configuration(void);
  10. void DMA_Configuration(void);
  11. int main(void)
  12. {
  13.   RCC_Configuration();
  14.   GPIO_Configuration();
  15.   DMA_Configuration();
  16.   /* TIM1 Peripheral Configuration --------------------------------------------*/
  17.   /* Time Base configuration */
  18.   TIM_TimeBaseStructure.TIM_Prescaler = 0;
  19.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  20.   TIM_TimeBaseStructure.TIM_Period = 1000-1;//72M/x=frq
  21.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  22.   TIM_TimeBaseStructure.TIM_RepetitionCounter = 2;
  23.   TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  24.   /* Channel 3 Configuration in PWM mode */
  25.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
  26.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  27.   TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
  28.   TIM_OCInitStructure.TIM_Pulse = 127;
  29.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  30.   TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  31.   TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
  32.   TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  33.   TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  34.   /* TIM1 Update DMA Request enable */
  35.   TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
  36.   /* TIM1 counter enable */
  37.   TIM_Cmd(TIM1, ENABLE);
  38.   /* Main Output Enable */
  39.   TIM_CtrlPWMOutputs(TIM1, ENABLE);
  40.   while (1)
  41.   {}
  42. }
  43. void RCC_Configuration(void)
  44. {
  45.   SystemInit();
  46.   /* TIM1, GPIOA and GPIOB clock enable */
  47.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 | RCC_APB2Periph_GPIOA |
  48.                          RCC_APB2Periph_GPIOB, ENABLE);
  49.   /* DMA clock enable */
  50.   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  51. }
  52. void GPIO_Configuration(void)
  53. {
  54.   GPIO_InitTypeDef GPIO_InitStructure;
  55.   /* GPIOA Configuration: Channel 3 as alternate function push-pull */
  56.   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_10;
  57.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  58.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  59.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  60.   /* GPIOB Configuration: Channel 3N as alternate function push-pull */
  61.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  62.   GPIO_Init(GPIOB, &GPIO_InitStructure);
  63. }
  64. void DMA_Configuration(void)
  65. {
  66.   DMA_InitTypeDef DMA_InitStructure;
  67.   /* DMA1 Channel5 Config */
  68.   DMA_DeInit(DMA1_Channel5);
  69.   DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)TIM1_CCR3_Address;
  70.   DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)SRC_Buffer;
  71.   DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  72.   DMA_InitStructure.DMA_BufferSize = 3;
  73.   DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  74.   DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  75.   DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  76.   DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  77.   DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  78.   DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  79.   DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  80.   DMA_Init(DMA1_Channel5, &DMA_InitStructure);
  81.   /* DMA1 Channel5 enable */
  82.   DMA_Cmd(DMA1_Channel5, ENABLE);
  83. }
上面的数组SRC_Buffer[3] = {100, 200, 500};
是作为SPWM波的产生数组,需要自己去取码表,还有就是用一些软件取出来的码表可能有负值,所以需要将这样的码表整体抬升成正值。
关键的问题来了,就是这数组怎么取出来的这是关键的,lz说说你怎么取得数组
本来想在上面说明一下,我以为大家都知道,很简单,有一个SPWM码表产生的软件,网上应该能找到,只是取出来的数应该有负数,所以需要抬升,至于抬升的办法就看自己了。可以用EXCEL来做,也可以自己写一个简单的c程序。上面的SPWM码表的产生其实也可以自己写一个简单的C程序来完成,这就需要自己想一点算法了。
我就好人做到底把SPWM波码表的产生软件和我自己写的一个码表的抬升程序都上传了吧。抬升程序解压之后在码表抬升软件文件夹下的debug文件夹下,直接运行daydayup。exe就可以了,第一次提醒输入抬升的码表的码值个数,然后提醒输入码表(可以直接粘贴上去),然后会提醒输入要抬升多少,最后会以一定的格式输出,自己再复制出来就可以了。
SPWM波产生软件.rar (159.56 KB, 下载次数: 83)
ID:115487 发表于 2016-4-20 17:07 | 显示全部楼层
谢谢楼主
ID:115487 发表于 2016-4-20 17:08 | 显示全部楼层
谢谢楼主
ID:226075 发表于 2017-10-8 16:42 | 显示全部楼层
可以可以
ID:381834 发表于 2018-8-10 16:35 | 显示全部楼层
谢谢楼主
