//LED8*8滚动显示
//列扫描,低电平有效
//包含头文件
#include <reg52.h>
#include "74HC595.H"
#include<intrins.h> //包含_nop_()函数定义的头文件
//全局变量定义
unsigned char i,flag,t,w,t;
unsigned int m,n;
unsigned char t1,t2,t3,t4;
//代码库
#define num sizeof(buff) //代码长度
unsigned char code aa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code table2[]={
0x60,0x60,0x00,0x3E,0x7F,0x41,0x7F,0x3E,/*"0",0*/
0x60,0x60,0x00,0x42,0x7F,0x7F,0x40,0x00,/*"1",1*/
0x60,0x60,0x00,0x62,0x73,0x59,0x4F,0x46,/*"2",2*/
0x60,0x60,0x00,0x22,0x6B,0x49,0x7F,0x36,/*"3",3*/
0x60,0x60,0x00,0x38,0x3E,0x7F,0x7F,0x20,/*"4",4*/
0x60,0x60,0x00,0x4F,0x4F,0x49,0x79,0x31,/*"5",5*/
0x60,0x60,0x00,0x3E,0x7F,0x49,0x7B,0x32,/*"6",6*/
0x60,0x60,0x00,0x03,0x73,0x79,0x0F,0x07,/*"7",7*/
0x60,0x60,0x00,0x36,0x7F,0x49,0x7F,0x36,/*"8",8*/
0x60,0x60,0x00,0x26,0x6F,0x49,0x7F,0x3E,/*"9",9*/
unsigned char code table1[]= {
//取模方式 阴码 列扫描 逆向
0x00,0x3E,0x7F,0x41,0x7F,0x3E,0x00,0x00,/*"0",0*/
0x00,0x42,0x7F,0x7F,0x40,0x00,0x00,0x00,/*"1",1*/
0x00,0x62,0x73,0x59,0x4F,0x46,0x00,0x00,/*"2",2*/
0x00,0x22,0x6B,0x49,0x7F,0x36,0x00,0x00,/*"3",3*/
0x00,0x38,0x3E,0x7F,0x7F,0x20,0x00,0x00,/*"4",4*/
0x00,0x4F,0x4F,0x49,0x79,0x31,0x00,0x00,/*"5",5*/
0x00,0x3E,0x7F,0x49,0x7B,0x32,0x00,0x00,/*"6",6*/
0x00,0x03,0x73,0x79,0x0F,0x07,0x00,0x00,/*"7",7*/
0x00,0x36,0x7F,0x49,0x7F,0x36,0x00,0x00,/*"8",8*/
0x00,0x26,0x6F,0x49,0x7F,0x3E,0x00,0x00,/*"9",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/
unsigned char buff[]={
0x00,0x03,0x03,0x3E,0x7F,0x41,0x63,0x22,/*"C",0*/
以下是DS18B20的操作程序
sbit DQ=P3^3;
unsigned char time; //设置全局变量,专门用于严格延时
函数功能:将DS18B20传感器初始化,读取应答信号
出口参数:flag
bit Init_DS18B20(void)
bit flag; //储存DS18B20是否存在的标志,flag=0,表示存在;flag=1,表示不存在
DQ = 1; //先将数据线拉高
for(time=0;time<2;time++) //略微延时约6微秒
DQ = 0; //再将数据线从高拉低,要求保持480~960us
for(time=0;time<200;time++) //略微延时约600微秒
; //以向DS18B20发出一持续480~960us的低电平复位脉冲
DQ = 1; //释放数据线(将数据线拉高)
for(time=0;time<10;time++)
; //延时约30us(释放总线后需等待15~60us让DS18B20输出存在脉冲)
flag=DQ; //让单片机检测是否输出了存在脉冲(DQ=0表示存在)
for(time=0;time<200;time++) //延时足够长时间,等待存在脉冲输出完毕
return (flag); //返回检测成功标志
函数功能:从DS18B20读取一个字节数据
出口参数:dat
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat; //储存读出的一个字节数据
for (i=0;i<8;i++)
DQ =1; // 先将数据线拉高
_nop_(); //等待一个机器周期
DQ = 0; //单片机从DS18B20读书据时,将数据线从高拉低即启动读时序
dat>>=1;
_nop_(); //等待一个机器周期
DQ = 1; //将数据线"人为"拉高,为单片机检测DS18B20的输出电平作准备
; //延时约6us,使主机在15us内采样
if(DQ==1)
dat|=0x80; //如果读到的数据是1,则将1存入dat
dat|=0x00;//如果读到的数据是0,则将0存入dat
//将单片机检测到的电平信号DQ存入r[i]
for(time=0;time<8;time++)
; //延时3us,两个读时序之间必须有大于1us的恢复期
return(dat); //返回读出的十进制数据
函数功能:向DS18B20写入一个字节数据
入口参数:dat
WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=0; i<8; i++)
DQ =1; // 先将数据线拉高
_nop_(); //等待一个机器周期
DQ=0; //将数据线从高拉低时即启动写时序
DQ=dat&0x01; //利用与运算取出要写的某位二进制数据,
//并将其送到数据线上等待DS18B20采样
;//延时约30us,DS18B20在拉低后的约15~60us期间从数据线上采样
DQ=1; //释放数据线
for(time=0;time<1;time++)
;//延时3us,两个写时序间至少需要1us的恢复期
dat>>=1; //将dat中的各二进制位数据右移1位
for(time=0;time<4;time++)
; //稍作延时,给硬件一点反应时间
void ReadyReadTemp(void)
Init_DS18B20(); //将DS18B20初始化
WriteOneChar(0xCC); // 跳过读序号列号的操作
WriteOneChar(0x44); // 启动温度转换
for(time=0;time<100;time++)
; //温度转换需要一点时间
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0xBE); //读取温度寄存器,前两个分别是温度的低位和高位
//显示函数
void Display(void)
if(flag==2){
Ser_IN((aa[i])); //列扫描数据
Ser_IN(buff[i + n]); //查表取出行扫描数据
Par_OUT(); //输出显示
i++; if(i == 8) i = 0; //循环扫描
m++; if(m == 100) {m = 0; n++;} //滚动速度控制
if(n == num-7)
n = 0; //循环显示
flag=1;
//定时器初始化
void T_init(void)
TMOD = 0x11;
TH0 = 0xfc; //1MS
TL0 = 0x66;
EA = 1; //允许CPU中断
ET0 = 1; //定时器0中断打开
TR0 = 1;
//定时器中断服务
void T0_intservice(void) interrupt 1 using 0
TH0 = 0xfc;
TL0 = 0x66;
Display();
//主函数
void main (void)
unsigned char TL; //储存暂存器的温度低位
unsigned char TH; //储存暂存器的温度高位
unsigned char TN; //储存温度的整数部分
unsigned char TD; //储存温度的小数部分
flag=1;
T_init();
while(1){
if(flag==1){
ReadyReadTemp(); //读温度准备
TL=ReadOneChar(); //先读的是温度值低位
TH=ReadOneChar(); //接着读的是温度值高位
TN=TH*16+TL/16; //实际温度值=(TH*256+TL)/16,即:TH*16+TL/16
//这样得出的是温度的整数部分,小数部分被丢弃了
TD=(TL%16)*10/16; //计算温度的小数部分,将余数乘以10再除以16取整,
t1=TN/100; //取百位
t2=(TN%100)/10; //取十位
t3=TN%10; //取个位
t4=TD;
flag=0;
if(flag==0){
for(w=1;w<6;w++){
if(w==5){
flag=2;
for(t=0;t<8;t++){
switch(w){
case 1:
buff[t+(8*w)]=table1[(8*t1)+t];
break;
case 2:
buff[t+(8*w)]=table1[(8*t2)+t];
break;
case 3:
buff[t+(8*w)]=table1[(8*t3)+t];
break;
case 4:
buff[t+(8*w)]=table2[(8*t4)+t];
break;
