查看: 3232|回复: 0
C语言:51+PIC单片机二合一的1602液晶显示-欢迎+时钟
ID:103513 发表于 2016-1-17 00:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
//来个猛一点的,显示欢迎界面,之后进入当前日期,时钟显示
//我前前后后花了10来天才调成功,没得问,汗死了,网上又没资料供参考
//51+PIC通杀:时钟
#define ww
#ifdef ww
#include<reg52.h>
#define uint unsigned int
uchar code table[]="  hello!jasper  ";
uchar code table1[]="   xm.dabiao    ";
uchar code aa[]=" 2018-01-04 MON ";
uchar code bb[]="    09:59:56    ";
sbit lcden=P3^4; //液晶使能位
sbit lcdrs=P3^5; //液晶RS,数据/命令切换选择位
sbit dula=P2^6;      //数码管关断
sbit wela=P2^7;
sbit FM=P2^3;
#endif
#ifdef PIC
#include <pic.h>
__CONFIG(0X3B31);
const uchar table[]="  hello! jasper ";
const uchar table1[]="   xm.dabiao    ";
const uchar aa[]="  2012-01-04 MON ";
const uchar bb[]="    09:59:56    ";
#define lcden RA3
#define lcdrs RA5
#define lcdrw RA4
#define P0 PORTD
#define FM RE0
#endif
uchar num,count;
char miao=56,fen=59,shi=9;
void delay(uint z)
  uint x,y;
  for(x=z;x>0;x--)
   for(y=110;y>0;y--);
void write_com(uchar com)
  lcdrs=0;
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_data(uchar date)
  lcdrs=1;
  P0=date;
  delay(5);
  lcdrs=1;
#ifdef PIC
  lcdrw=0;
#endif
  lcden=1;
  delay(5);
  lcden=0;
void lcd_enable(void)
lcdrs = 0;
#ifdef PIC
lcdrw = 0;
#endif
lcden = 0;
delay(5);
lcden = 1;
void delayzd(uint zz)
  uint xz,yz;
  for(xz=zz;xz>0;xz--)
   for(yz=110;yz>0;yz--);
void write_comzd(uchar comz)
  lcdrs=0;
  P0=comz;
  delayzd(5);
  lcden=1;
  delayzd(5);
  lcden=0;
void write_datazd(uchar dataz)
  lcdrs=1;
  P0=dataz;
  delayzd(5);
  lcdrs=1;
#ifdef PIC
  lcdrw=0;
#endif
  lcden=1;
  delayzd(5);
  lcden=0;
void write_sfm(uchar adda,char datez)
  char shi,ge;
  shi=datez/10;
  ge=datez%10;
  write_comzd(0x80+0x40+adda);
  write_datazd(0x30+shi);
  write_datazd(0x30+ge);
void lcd_enablezd(void)
lcdrs = 0;
#ifdef PIC
lcdrw = 0;
#endif
lcden = 0;
delayzd(5);
lcden = 1;
void init(void)
#ifdef ww
   dula=0;
  wela=0;
  lcden=0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
// write_com(0x80);
  write_com(0x80+0x10);
#endif
#ifdef PIC
  TRISA=0x00;PORTA=0XF0;
  TRISD=0x00;PORTD=0XFF;
   ADCON1=0X07;
  lcd_enable();
  write_com(0x38);
  lcd_enable();
  write_com(0x0e);
  lcd_enable();
  write_com(0x06);
  lcd_enable();
  write_com(0x01);
  lcd_enable();
// write_com(0x80);
#endif
void hello(void)
  for(num=0;num<16;num++)
     write_data(table[num]);
     delay(10);
  write_com(0x80+0x51);
     write_data(table1[num]);
     delay(10);
    write_com(0x18);
    delay(160);
  delay(1800);
void pingxian(void)
  uchar num_x;
  delay(500);
  write_com(0x01);
  write_com(0x80);
  for(num_x=0;num_x<16;num_x++)
     write_data(aa[num_x]);
     delay(20);
  write_com(0x80+0x40);
  delay(5);
     write_data(bb[num_x]);
     delay(20);
  delay(300);
void zd(void)
#ifdef ww
  TMOD=0x01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
#endif
#ifdef PIC
INTCON=0xc0;
PIE1=0x01;
T1CON=0x01;
TMR1L=(65536-50000)%256;
TMR1H=(65536-50000)/256;
#endif
  init();
  hello();
  pingxian();
  zd();
void timego(void)
if(count==19)
     count=0;
     miao++;
     if(miao==60)
       miao=0;
       fen++;
       if(fen==60)
         fen=0;
         shi++;
         if(shi==24)
           shi=0;
         write_sfm(4,shi);
       write_sfm(7,fen);
     write_sfm(10,miao);
#ifdef ww
void timer0() interrupt 1
  count++;
  timego();
#endif
#ifdef PIC
void interrupt time0(void)
  TMR1IF=0;
  count++;
  //if(count==19)P0=0x02;
  timego();
#endif
