我在PROTEL 99SE 里边画完原理图编译后出现了下面的一堆错误,请问是什么原因?谢谢! C1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. C1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) C1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> C2 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. C2 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) C2 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> C3 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. C3 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) C3 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> Q1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. Q1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) Q1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> R1 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. R1 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) R1 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> R2 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. R2 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) R2 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> R3 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. R3 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) R3 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> R4 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. R4 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) R4 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> R5 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. R5 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) R5 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> R11 Error: Pin order data (PINS=1:[<pins>]) not in READ ONLY field 4. Pins sorted by pin-name. R11 Error: Part type must be entered in READ ONLY field 1: type=<part type>(<spice prefix>) R11 Error: Netlist data must be entered in READ ONLY field 5: netlist=<netlist data> Setup Error: GND Spice Reference Net (specified in Analog Options) is not in the schematic.
[此贴子已经被作者于2008-7-17 10:14:06编辑过]
