查看: 3749|回复: 4
51单片机红外遥控解码程序 用1602液晶屏显示
ID:115316 发表于 2016-4-19 20:48 | 显示全部楼层 |阅读模式
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define uint unsigned int
  5. sbit lcden = P2^7;
  6. sbit lcdrs = P2^6;
  7. sbit lcdwr = P2^5;
  8. sbit IR = P3^2;
  9. uchar IRCOM[6];//数组,用于存储红外编码
  10. uchar code table1[] = "remote control";
  11. uchar code table2[] = "CODE:";
  12. void delayms(uchar x)// 延时x*0.14ms
  13. {
  14. uchar i;
  15. while(x--)
  16. for(i=0;i<13;i++){}
  17. }
  18. void delay(uchar x) //延时xms
  19. {
  20. uchar i,j;
  21. for(i=x;i>0;i--)
  22. for(j=110;j>0;j--);
  23. }
  24. /****************************LCD部分***********************************************/
  25. void write_com(uchar com)
  26. {
  27. lcden = 0;
  28. lcdrs = 0;
  29. lcdwr = 0;
  30. P0 = com;
  31. delay(5);
  32. lcden = 1;
  33. delay(5);
  34. lcden = 0; //别忘了lcden拉低
  35. }
  36. void write_date(uchar date)
  37. {
  38. lcden = 0;
  39. lcdrs = 1;
  40. lcdwr = 0;
  41. P0 = date;
  42. delay(5);
  43. lcden = 1;
  44. delay(5);
  45. lcden = 0;
  46. }
  47. void lcd_init(void)
  48. {
  49. lcden = 0;
  50. lcdrs = 0;
  51. lcdwr = 0;
  52. delay(5);
  53. write_com(0x38);
  54. write_com(0x0c);
  55. write_com(0x06);
  56. write_com(0x01);
  57. }
  58. /*****************main()************************/
  59. void main(void)
  60. {
  61. uchar count=0;
  62. IR = 1;
  63. lcd_init();
  64. write_com(0x80);
  65. while(table1[count]!='\0')
  66. {
  67. write_date(table1[count]);
  68. count++;
  69. delay(5);
  70. }
  71. count = 0;
  72. write_com(0x80+0x40);
  73. while(table2[count]!='\0')
  74. {
  75. write_date(table2[count]);
  76. count++;
  77. delay(5);
  78. }
  79. IE = 0x81; //开中断
  80. TCON = 0x01;//脉冲负边沿触发
  81. while(1);
  82. }
  83. /*********************红外中断**************************/
  84. void IR_time() interrupt 0
  85. {
  86. uchar i,j,TimeNum=0;//TimeNum用来计IR高电平次数 从而判断是0还是1
  87. EX0 = 0; //关闭中断
  88. delayms(5);
  89. if(1 == IR)
  90. {
  91. EX0 = 1;
  92. return;
  93. }
  94. while(!IR) //跳过9ms前导低电平
  95. delayms(1);
  96. for(i=0;i<4;i++)
  97. {
  98. for(j=0;j<8;j++)
  99. {
  100. while(IR) //跳过4.5ms的前导高电平
  101. delayms(1);
  102. while(!IR) //跳过0.56ms的低电平
  103. delayms(1);
  104. while(IR)
  105. {
  106. TimeNum++; //计时高电平时间从而判断读取的是0还是1
  107. delayms(1);
  108. }
  109. if(TimeNum>=30)//按键按下时间过长 跳过
  110. {
  111. EX0 = 1;
  112. return;
  113. }
  114. IRCOM[i] = IRCOM[i]>>1;
  115. if(TimeNum >= 8) //8*0.14ms 这时读取的是1;
  116. {
  117. IRCOM[i] = IRCOM[i]|0x80;
  118. }
  119. TimeNum = 0;
  120. }
  121. }
  122. if(IRCOM[2]!=~IRCOM[3])//判断八位数据和八位数据反码是否相等
  123. {
  124. EX0 = 1;
  125. return;
  126. }
  127. IRCOM[4] = IRCOM[2]&0x0f;//取低四位
  128. IRCOM[5] = IRCOM[2]>>4; //IRCOM[5]取IRCOM[2]高四位
  129. if(IRCOM[4] > 9) //转换成字符
  130. {
  131. IRCOM[4] = IRCOM[4] + 0x37;
  132. }
  133. else
  134. IRCOM[4] = IRCOM[4] + 0x30;
  135. if(IRCOM[5] > 9)
  136. {
  137. IRCOM[5] = IRCOM[5] + 0x37;
  138. }
  139. else
  140. IRCOM[5] = IRCOM[5] + 0x30;
  141. delay(5);
  142. write_com(0x80 + 0x40 + 5);
  143. write_date(IRCOM[5]);
  144. write_date(IRCOM[4]);
  145. EX0 = 1; //重新开启外部中断
  146. }
ID:112693 发表于 2016-4-21 23:33 | 显示全部楼层
给个线路图呗
ID:149319 发表于 2016-11-23 21:48 | 显示全部楼层
接收不i到ir的数据
ID:160317 发表于 2017-4-17 15:22 | 显示全部楼层
能给个protus的仿真图吗
ID:353588 发表于 2018-6-20 09:59 | 显示全部楼层
超级感谢楼主的
