查看: 1107|回复: 0
帮看看这程序哪儿错了 帮忙修改下
ID:129825 发表于 2016-7-12 10:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
SEC EQU 29H
MIN EQU 30H
TCNC EQU 34H
ORG 0000H
SJMP START
ORG 000BH
LJMP INT_T0
START:MOV DPTR,#TAB
       MOV SEC,#0
    MOV MIN,#0
    MOV TCNC,#0
    MOV TMOD,#01H
    MOV TH0,#(65536-50000)/256
    MOV TH0,#(65536-50000)MOD 256
    MOV IE,#82H
    SETB TR0
    LCALL DISPLAY
A1:INC SEC
   MOV A,SEC
   CJNE A,#60,A1
   MOV SEC,#0
   LCALL DISPLAY
   LJMP K1
K1:INC MIN
   MOV A,MIN
   CJNE A,#60,K1
   MOV MIN,#0
   LCALL DISPLAY
   LJMP A1
INT_T0:MOV TH0,#(65536-50000)/256
       MOV TL0,#(65536-50000)MOD 256
    INC TCNC
    MOV A,TCNC
    CJNE A,#20,RETUNE
    INC SEC
    MOV TCNC,#0
    MOV A,SEC
    CJNE A,#60,RETUNE
    INC MIN
    MOV SEC,#0
    MOV A,#MIN
    CJNE A,#60,RETUNE
    MOV MIN,#0
    MOV SEC,#0
    MOV TCNC,#0
RETUNE:RETI
DISPLAY:MOV A,ESC
        MOV B,#10
  DIV AB
  CLR P3.4
  MOVC A,@A+DPTR
  MOV P0,A
  LCALL DELAY
  SETB P3.4
  MOV A,B
  CLR P3.5
  MOVC A,@A+DPTR
  MOV P0,A
  LCALL DELAY
  SETB P3.6
  MOV A,MIN
  MOV B,#10
  DIV AB
  CLR P3.2
  MOVC A,@A+DPTR
  MOV P0,A
  LCALL DELAY
  SETB P3.2
  MOV A,B
  CLR P3.3
  MOVC A,@A+DPTR
  MOV P0,A
  LCALL DELAY
  SETB P3.3
  RET
DELAY:MOV R6,#10
    D1:MOV R7,#250
DJNZ R7,$
DJNZ R6,D1
RET
TAB:DB 0C0H,0F9H,0A4H,0B0H,99H,92H,0F8H,90H,90H
    END
