查看: 3988|回复: 2
如何将*.ile转换成*.il文件
ID:140343 发表于 2016-9-24 19:30 | 显示全部楼层 |阅读模式
procedure( NlDecrypt( inputFile  @optional outputFile "tt")
     prog( (inp out line)
if( inputFile then
     unless( outputFile
outputFile = sprintf(nil "%s.dec" inputFile)
     when( isFile( outputFile )
print( "You must specify a file that doesn't exist!!!\n" )
hiGetAttention( )
return()
     unless( inp = infile(inputFile)
printf("Unable to open input file: %s\n" inputFile)
return()
     unless( out = outfile(outputFile "w")
printf("Unable to open output file: %s\n" outputFile)
return()
     while( line = lineread(inp)
when( line != t
     pprint(line out)
     close(inp)
     close(out)
     printf("You must at least specify an input file!\n")
     return()
) ; ** if inputFile **
return(t)
     ) ; ** let  **
) ; ** procedure  **
NlDecrypt( "abc.ile" "abc.il")
ID:585063 发表于 2019-7-16 14:00 | 显示全部楼层
这个是什么程序啊,需要怎么去运行啊。大师能够帮忙回答下吗
ID:1047545 发表于 2022-10-13 14:17 | 显示全部楼层
大佬,请问咋们运用啊?不会操作
