查看: 1811|回复: 0
帮忙解释一下代码!!加一下注释 蟹蟹蟹蟹
ID:157004 发表于 2016-12-26 10:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
60黑币
#include <at89x51.h>
#define uint unsigned int
sbit S_SET=P3^0;
sbit M_SET=P3^1;
sbit H_SET=P3^2;
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
unsigned char dispbitcode[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char dispbuf[8]={0,0,16,0,0,16,2,1};
uchar dispbitcnt;
uchar second;
uchar minite;
uchar hour;
uint tcnt;
uchar mstcnt;
uchar i,j;
//主函数
void main(void)
  TMOD=0x02;//定时器方式2
  TH0=0x06;
  TL0=0x06;
  TR0=1;
  ET0=1;
  EA=1;
  hour=12;
      if(S_SET==0)
          for(i=5;i>0;i--)
          for(j=248;j>0;j--);
          if(S_SET==0)
              second++;
              if(second==60)
                  second=0;
              dispbuf[0]=second%10;
              dispbuf[1]=second/10;
              while(S_SET==0);
      if(M_SET==0)
          for(i=5;i>0;i--)
          for(j=248;j>0;j--);
          if(M_SET==0)
              minite++;
              if(minite==60)
                  minite=0;
              dispbuf[3]=minite%10;
              dispbuf[4]=minite/10;
              while(M_SET==0);
      if(H_SET==0)
          for(i=5;i>0;i--)
          for(j=248;j>0;j--);
          if(H_SET==0)
              hour++;
              if(hour==24)
                  hour=0;
              dispbuf[6]=hour%10;
              dispbuf[7]=hour/10;
              while(H_SET==0);
void t0(void) interrupt 1 using 0
  mstcnt++;
  if(mstcnt==8)
      mstcnt=0;
      P2=0xff;      //关闭所有显示
      P0=dispcode[dispbuf[dispbitcnt]];
      P2=dispbitcode[dispbitcnt];
      dispbitcnt++;
      if(dispbitcnt==8)
          dispbitcnt=0;
  tcnt++;
  if(tcnt==4000)
      tcnt=0;
      second++;
      if(second==60)
          second=0;
          minite++;
          if(minite==60)
              minite=0;
              hour++;
              if(hour==24)
                  hour=0;
      dispbuf[6]=hour%10;
      dispbuf[7]=hour/10;
数字电子钟.zip
127.71 KB, 下载次数: 4
