查看: 3692|回复: 7
哪位大哥 给解释一下警告什么意思呢?新人 求助
ID:180790 发表于 2017-3-27 16:16 | 显示全部楼层 |阅读模式
#include<reg51.h>
#include<intrins.h>
#define BYTE unsigned char
typedef unsigned int WORD;
#define URMD 0
sfr T2H=0xd6;
sfr T2L=0xd7;
sfr AUXR=0x8e;
sfr ADC_CONTR=0xBC;
sfr ADC_RES=0xBD;
sfr ADC_LOW2=0xBE;
sfr P1ASF=0x9D;
#define        ADC_POWER 0x80
#define        ADC_FLAG 0x10
#define        ADC_START 0x08
#define        ADC_SPEEDLL 0x00
#define        ADC_SPEEDL 0x20
#define        ADC_SPEEDH  0x40
#define ADC_SPEEDHH 0x60
void InitUart();
void SendData(BYTE dat);
void Delay(WORD n);
void InitADC();
BYTE     ch=0;
  InitUart();
  InitADC();
  IE=0xa0;
  while(1);
   void adc_isr()interrupt 5 using 1
     ADC_CONTR&=!ADC_FLAG;
         SendData(ADC_RES);
         ADC_CONTR=0xea;
         void InitADC()
            P1ASF=0xff;
                ADC_RES=0;
                ADC_CONTR=ADC_POWER|ADC_SPEEDHH|ADC_START|ch;
                Delay(2);
                void InitUart()
                  SCON=0x5a;
                  T2L=0xea;
                  T2H=0xff;
                  AUXR=0x14;
                  AUXR|=0x01;
                   void SengData(BYTE dat)
                    while(!TI);
                        TI=0;
                        SBUF=dat;
                        void Delay(WORD n)
                          WORD x;
                          while(n--)
                            x=5000;
                                while(x--);
这是错误的提示:
       Build target 'Target 1'
compiling w.c...
linking...
*** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
    SEGMENT: ?PR?_SENGDATA?W
*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL
    SYMBOL:  _SENDDATA
    MODULE:  w.obj (W)
*** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL
    SYMBOL:  _SENDDATA
    MODULE:  w.obj (W)
    ADDRESS: 089FH
Program Size: data=18.0 xdata=0 code=266
"w" - 0 Error(s), 3 Warning(s).
ID:180790 发表于 2017-3-27 17:04 | 显示全部楼层
没有人么?
ID:7485 发表于 2017-3-27 19:50 | 显示全部楼层
有多余的没有用到的,诸如定义、函数、等
ID:7485 发表于 2017-3-27 19:51 | 显示全部楼层
如果看不懂,其实你可以复制过来用在线翻译看一下。
ID:155507 发表于 2017-3-27 20:03 | 显示全部楼层
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #define BYTE unsigned char
  4. typedef unsigned int WORD;
  5. #define URMD 0
  6. sfr T2H=0xd6;
  7. sfr T2L=0xd7;
  8. sfr AUXR=0x8e;
  9. sfr ADC_CONTR=0xBC;
  10. sfr ADC_RES=0xBD;
  11. sfr ADC_LOW2=0xBE;
  12. sfr P1ASF=0x9D;
  13. #define        ADC_POWER 0x80
  14. #define        ADC_FLAG 0x10
  15. #define        ADC_START 0x08
  16. #define        ADC_SPEEDLL 0x00
  17. #define        ADC_SPEEDL 0x20
  18. #define        ADC_SPEEDH  0x40
  19. #define ADC_SPEEDHH 0x60
  20. void InitUart();
  21. void SendData(BYTE dat);
  22. void Delay(WORD n);
  23. void InitADC();
  24. BYTE     ch=0;
  25. void main()
  26. {
  27.         InitUart();
  28.         InitADC();
  29.         IE=0xa0;
  30.         while(1);
  31. }
  32. void adc_isr()interrupt 5 using 1
  33. {
  34.         ADC_CONTR&=!ADC_FLAG;
  35.         SendData(ADC_RES);
  36.         ADC_CONTR=0xea;
  37. }
  38. void InitADC()
  39. {
  40.         P1ASF=0xff;
  41.         ADC_RES=0;
  42.         ADC_CONTR=ADC_POWER|ADC_SPEEDHH|ADC_START|ch;
  43.         Delay(2);
  44. }
  45. void InitUart()
  46. {
  47.         SCON=0x5a;
  48.         T2L=0xea;
  49.         T2H=0xff;
  50.         AUXR=0x14;
  51.         AUXR|=0x01;
  52. }
  53. void SendData(BYTE dat)//void SengData(BYTE dat)
  54. {
  55.         while(!TI);
  56.         TI=0;
  57.         SBUF=dat;
  58. }
  59. void Delay(WORD n)
  60. {
  61.         WORD x;
  62.         while(n--)
  63.         {
  64.                 x=5000;
  65.                 while(x--);
  66.         }
  67. }
ID:183940 发表于 2017-3-27 20:19 | 显示全部楼层
有多余的没有用到的语句:定义、函数、等,删除就好了
ID:180790 发表于 2017-3-27 21:04 | 显示全部楼层
谢谢  太感谢了  我写了好久不知道哪里错误了
ID:183914 发表于 2017-3-27 23:56 | 显示全部楼层
多余的语句或者函数没有用到,警告不导致编译错误直接生成hex烧录就行了,实在在乎的话把相应的部分注释了就行了
