查看: 33552|回复: 77
stm32驱动lcd1602液晶方式 程序调试成功
ID:190471 发表于 2017-4-17 15:48 | 显示全部楼层 |阅读模式
最近在搞DIY小玩意 用到了lcd1602液晶显示 最后调试成功,希望对有需要的人有所帮助!
1602液晶驱动程序的主要部分:
  1. #include "lcd1602.h"
  2. #include "delay.h"
  3. #include "stdio.h"
  4. void GPIO_Configuration(void)
  5. {
  6.         GPIO_InitTypeDef        GPIO_InitStructure;
  7.
  8.         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB | RCC_AHB1Periph_GPIOD,ENABLE);//使能PB,PD端口时钟
  9.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  10.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //普通输出模式
  11.     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽输出
  12.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //IO口速度为50MHz
  13.         GPIO_Init(GPIOD, &GPIO_InitStructure);                                //初始化GPIOD0~7
  14.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
  15.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //普通输出模式
  16.     GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽输出
  17.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //IO口速度为50MHz
  18.         GPIO_Init(GPIOB, &GPIO_InitStructure);                                //初始化GPIB15,14,13
  19. }
  20. /* 等待液晶准备好 */
  21. void LCD1602_Wait_Ready(void)
  22. {
  23.         u8 sta;
  24.
  25.         DATAOUT(0xff);
  26.         LCD_RS_Clr();
  27.         LCD_RW_Set();
  28.         do
  29.         {
  30.                 LCD_EN_Set();
  31.                 delay_ms(5);        //延时5ms,非常重要
  32.                  sta = GPIO_ReadInputDataBit(GPIOD, GPIO_Pin_7);//读取状态字
  33.                 LCD_EN_Clr();
  34.         }while(sta & 0x80);//bit7等于1表示液晶正忙,重复检测直到其等于0为止
  35. }
  36. /* 向LCD1602液晶写入一字节命令,cmd-待写入命令值 */
  37. void LCD1602_Write_Cmd(u8 cmd)
  38. {
  39.         LCD1602_Wait_Ready();
  40.         LCD_RS_Clr();
  41.         LCD_RW_Clr();
  42.         DATAOUT(cmd);
  43.         LCD_EN_Set();
  44.         LCD_EN_Clr();
  45.     //printf("%d",cmd);
  46. }
  47. /* 向LCD1602液晶写入一字节数据,dat-待写入数据值 */
  48. void LCD1602_Write_Dat(u8 dat)
  49. {
  50.         LCD1602_Wait_Ready();
  51.         LCD_RS_Set();
  52.         LCD_RW_Clr();
  53.         DATAOUT(dat);
  54.         LCD_EN_Set();
  55.         LCD_EN_Clr();
  56. }
  57. /* 清屏 */
  58. void LCD1602_ClearScreen(void)
  59. {
  60.         LCD1602_Write_Cmd(0x01);
  61. }
  62. /* 设置显示RAM起始地址,亦即光标位置,(x,y)-对应屏幕上的字符坐标 */
  63. void LCD1602_Set_Cursor(u8 x, u8 y)
  64. {
  65.         u8 addr;
  66.
  67.         if (y == 0)
  68.                 addr = 0x00 + x;
  69.         else
  70.                 addr = 0x40 + x;
  71.         LCD1602_Write_Cmd(addr | 0x80);
  72. }
  73. /* 在液晶上显示字符串,(x,y)-对应屏幕上的起始坐标,str-字符串指针 */
  74. void LCD1602_Show_Str(u8 x, u8 y, u8 *str)
  75. {
  76.         LCD1602_Set_Cursor(x, y);
  77.         while(*str != '\0')
  78.         {
  79.                 LCD1602_Write_Dat(*str++);
  80.         }
  81. }
  82. /* 初始化1602液晶 */
  83. void LCD1602_Init(void)
  84. {
  85.     GPIO_Configuration();
  86.         LCD1602_Write_Cmd(0x38);        //16*2显示,5*7点阵,8位数据口
  87.         LCD1602_Write_Cmd(0x0c);        //开显示,光标关闭
  88.         LCD1602_Write_Cmd(0x06);        //文字不动,地址自动+1
  89.         LCD1602_Write_Cmd(0x01);        //清屏
  90. //    LCD1602_Write_Cmd(0X02);
  91. //    LCD1602_Write_Cmd(0X06);
  92. //        LCD1602_Write_Cmd(0X00);
  93. //        LCD1602_Write_Cmd(0X0C);
  94. //        LCD1602_Write_Cmd(0X38);
  95. //        LCD1602_Write_Cmd(0x01);
  96.
  97. }
下载:
lcd1602显示.7z (294.08 KB, 下载次数: 1485)
参与人数 4黑币 +20 收起 理由
z72287 + 5 很给力!
zqs222 + 5 很给力!
sdfasfsdfsdf + 5 很给力!
cheeselala + 5 很给力!
ID:220748 发表于 2018-12-12 21:27 | 显示全部楼层
祝贺stm32驱动lcd1602液晶方式程序调试成功!
但没有看见电路图,所以不知液晶显示什么?输入什么信号?看标题好像是检测指纹,对么?
1602液晶数据端口接到STM32d的什么引脚?
ID:220748 发表于 2018-12-13 20:50 | 显示全部楼层
编译时出现两个错误,请帮助解决!
谢谢!!
ID:105355 发表于 2017-4-17 20:22 | 显示全部楼层
f407...................................
ID:190672 发表于 2017-4-17 23:51 | 显示全部楼层
谢谢分享,学习了!
ID:148108 发表于 2017-5-25 21:19 | 显示全部楼层
谢谢楼主。帮了大忙
ID:221735 发表于 2017-7-23 15:15 | 显示全部楼层
谢谢楼主!!
ID:91163 发表于 2017-7-23 20:19 | 显示全部楼层
stm32这么快,搞1602怪浪费的
ID:241124 发表于 2017-10-19 22:55 | 显示全部楼层
谢谢分享!!!
ID:242484 发表于 2017-10-24 16:46 | 显示全部楼层
刚刚好用到
ID:233664 发表于 2017-12-9 13:09 | 显示全部楼层
显示一个变量行吗?
ID:259891 发表于 2017-12-11 09:33 | 显示全部楼层
谢谢分享 正好需要
ID:275121 发表于 2018-1-13 20:24 | 显示全部楼层
非常感谢,
ID:279429 发表于 2018-1-25 14:44 | 显示全部楼层
谢谢楼主分享
ID:279429 发表于 2018-1-25 15:09 | 显示全部楼层
非常感谢
ID:234038 发表于 2018-1-28 21:23 | 显示全部楼层
谢谢啦  刚好要用 试试看
ID:283718 发表于 2018-2-11 20:08 | 显示全部楼层
支持支持
ID:272345 发表于 2018-2-28 09:56 | 显示全部楼层
谢谢楼主
ID:297898 发表于 2018-3-28 15:13 | 显示全部楼层
用不了啊,我rw直接接地的,只用于显示。就把有关rw的全注释了,对应的脚也改了,尝试了几次什么都没显示。
ID:287482 发表于 2018-4-2 17:09 | 显示全部楼层
谢谢楼主  帮了大忙
ID:301675 发表于 2018-4-7 12:30 | 显示全部楼层
谢谢分享
ID:284518 发表于 2018-4-10 09:50 | 显示全部楼层
感谢楼主分享,非常感谢
ID:305418 发表于 2018-4-10 20:25 | 显示全部楼层
感谢楼主!
ID:306466 发表于 2018-4-12 11:16 | 显示全部楼层
谢谢楼主分享,正好需要用到
ID:315667 发表于 2018-4-24 20:20 | 显示全部楼层
谢谢!非常需要!
ID:326724 发表于 2018-5-10 12:31 | 显示全部楼层
谢分享
ID:326772 发表于 2018-5-10 13:43 | 显示全部楼层
谢谢分享,学习了!
ID:290647 发表于 2018-5-21 15:39 | 显示全部楼层
谢谢。。。很棒
ID:319334 发表于 2018-6-5 15:07 | 显示全部楼层
非常感谢
ID:367898 发表于 2018-7-9 13:41 | 显示全部楼层
需要下载看看
ID:368558 发表于 2018-7-10 11:27 | 显示全部楼层
谢谢楼主很给力
ID:375746 发表于 2018-7-20 12:40 | 显示全部楼层
谢谢楼主
ID:376963 发表于 2018-7-21 22:39 | 显示全部楼层
感谢楼主,好人一生平安
ID:380780 发表于 2018-7-30 11:21 | 显示全部楼层
感谢,好用了再夸奖
ID:372701 发表于 2018-8-2 16:04 | 显示全部楼层
很给力
ID:372701 发表于 2018-8-2 16:07 | 显示全部楼层
感谢大佬
ID:384753 发表于 2018-8-10 20:02 | 显示全部楼层
唉  没黑币啊
ID:218309 发表于 2018-9-11 13:36 | 显示全部楼层
做一个数据是4线的
ID:390236 发表于 2018-9-11 14:45 | 显示全部楼层
谢谢楼主
ID:403971 发表于 2018-9-29 11:37 | 显示全部楼层
感谢楼主分享!
ID:420871 发表于 2018-11-5 09:25 | 显示全部楼层
感谢楼主分享!
ID:259517 发表于 2018-11-8 21:16 | 显示全部楼层
很好,资料不错,谢谢分享
