多级菜单:
- //ReadMe
- //屏宽:112
- //屏高:64
- #i nclude <reg51.h>
- #i nclude <intrins.h>
- #i nclude <absacc.h>
- typedef struct
- unsigned int KeyTab_MenuIndex; //当前状态索引号
- unsigned int KeyTab_MaxItems; //本级菜单最大条目数
- unsigned int KeyTab_PressOk; //按下"回车"键时转向的状态索引号
- unsigned int KeyTab_PressEsc; //按下"返回"键时转向的状态索引号
- unsigned int KeyTab_PressDown; //按下"向下"键时转向的状态索引号
- unsigned int KeyTab_PressUp; //按下"向上"键时转向的状态索引号
- void (*CurrentOperate)(); //当前状态应该执行的功能操作
- }KeyTabStruct;
- void (*KeyFuncPtr)(); //按键功能指针
- #define S_S 0x80//上 =1000,0000=0x80,
- #define S_X 0x40//下 =0100,0000=0x40,
- #define S_Z 0x20//左 =0010,0000=0x20,
- #define S_Y 0x10//右 =0001,0000=0x10,
- #define S_ZS 0xa0//左上 =1010,0000=0xa0,
- #define S_ZX 0x60//左下 =0110,0000=0x60,
- #define S_YS 0x90//右上 =1001,0000=0x90,
- #define S_YX 0x50//右下 =0101,0000=0x50,
- #define S_SXZY 0xf0//上下左右=1111,0000=0xf0
- #define KEY_OK 0x11
- #define KEY_UP 0x12
- #define KEY_ESC 0x13
- #define KEY_LEFT 0x21
- #define KEY_DOWN 0x22
- #define KEY_RIGHT 0x23
- #define KEY_1 0x31
- #define KEY_2 0x32
- #define KEY_3 0x33
- #define KEY_4 0x41
- #define KEY_5 0x42
- #define KEY_6 0x43
- #define KEY_7 0x51
- #define KEY_8 0x52
- #define KEY_9 0x53
- #define KEY_XING 0x61
- #define KEY_0 0x62
- #define KEY_JING 0x63
- #define KEY_POWER 0x71
- #define KEY_NULL 0x00
- #define MAX_KEYTABSTRUCT_NUM 19
- #define MENU_FACE 0
- #define MENU_ROOT 1
- #define MENU_VIEW 2
- #define MENU_VIEW_ABOUTRECORDE 3
- #define MENU_VIEW_HANDSETCLOCK 4
- #define MENU_OPERATION 5
- #define MENU_OPERATION_SETPOSITION 6
- #define MENU_OPERATION_READZJTOFLASH 7
- #define MENU_OPERATION_RDZJTORAM 8
- #define MENU_OPERATION_DELGIVENZL 9
- #define MENU_OPERATION_DELALLZJ 10
- #define MENU_TEST 11
- #define MENU_TEST_RAMTEST 12
- #define MENU_TEST_FLASHTEST 13
- #define MENU_SYSTEMSET 14
- #define MENU_SYSTEMSET_DEBUG 15
- #define MENU_SYSTEMSET_DEBUG_PASSWORD 16
- #define MENU_SYSTEMSET_DEBUG_SEEPICTURE 17
- #define MENU_SYSTEMSET_SETHANDCLK 18
- #define Addr_Key 0xc000 //1100,0000,0000,0000
- #define Addr_XRamBegin1 0x0000 //0000,0000,0000,0000//共32K
- #define Addr_XRamEnd1 0x3fff //0011,1111,1111,1111
- #define Addr_XRamBegin2 0x4000 //0100,0000,0000,0000
- #define Addr_XRamEnd2 0x7fff //0111,1111,1111,1111
- #define Addr_XFlashBegin 0x9000//1000,0000,0000,0000 16K/每自然扇区
- #define Addr_XFlashEnd 0xbfff//1011,1111,1111,1111
- #define Addr_XFlashSector 0xc001//1100,0000,0000,0001 4个自然扇区(把FLASH的地址线移到这个口内容的低位)
- //Flash可用容量=4*16K=64K
- //自然扇区的内容字节范围(0->3)(0000,0000~0000,0011)共4块=64K,硬件上把A18,A17,A16锁住了,不能写)
- //能读不能写的扇区号为4-31为(0000,0100~0001,1111)共28块=448K,可以作为菜单位置
- //#define Addr_XFlashBegin 0x9000//1000,0000,0000,0000 16K/每自然扇区
- //#define Addr_XFlashEnd 0xbfff//1011,1111,1111,1111
- //能读能写的FLASH的连续地址如下:
- //#define Addr_XFlashBegin 0x0000//共64K
- //#define Addr_XFlashEnd 0xffff
- //操作FLASH地址时,
- //1.算出页地址
- //2. 对扇区解锁(读扇区不用解锁):(0x5555)=0xaa,(0x2aaa)=0x55,(0x5555)=0xa0;
- //3。把高2位移入[Addr_XFlashSector]=0的低2位,
- //4。把原来的高2位置0,再或上10B
- //5. 然后整个扇区读/写256字节
- //片外数组0x0000~0x1fff;
- unsigned char xdata Rev232Buffer[256] _at_ 0x0000; //->0x00ff
- unsigned char xdata Send232Buffer[256] _at_ 0x0100; //->0x1ff
- #define Addr_FlashWriteBuffer1 0x0200 //->0x2ff
- #define Addr_FlashWriteBuffer2 0x0300 //->0x3ff
- #define Addr_FlashReadBuffer1 0x0400 //->0x4ff
- #define Addr_FlashReadBuffer2 0x0500 //->0x5ff
- #define Addr_ZjWrRdBuffer 0x0800 //->0xfff
- unsigned char xdata clock[12] _at_ 0x1000; //->0x100b
- unsigned char xdata cGraphByte[8] _at_ 0x100e; //->0x1015
- unsigned char xdata * xdata cpGraph _at_ 0x1016; //->0x1017
- signed char xdata cMenuHLight[0x10] _at_ 0x1018;
- KeyTabStruct xdata KeyTab[MAX_KEYTABSTRUCT_NUM] _at_ 0x1028;
- unsigned char xdata CxTestByte1 _at_ 0x1145;
- //片外单变量0x2000~0x2fff;
- //通讯专用
- unsigned char xdata cUartTemp1 _at_ 0x2000;
- unsigned char xdata cUartTemp2 _at_ 0x2001;
- unsigned char xdata cUartTemp3 _at_ 0x2002;
- unsigned char xdata cUartFunSn _at_ 0x2003;
- unsigned char xdata cUartDataLenght _at_ 0x2004;
- unsigned char xdata cUartAddSum _at_ 0x2005;
- unsigned char xdata cUartXorSum _at_ 0x2006;
- unsigned char xdata iUartTemp1 _at_ 0x2007;
- unsigned char xdata iUartTemp2 _at_ 0x2008;
- unsigned char xdata iUartTemp3 _at_ 0x2009;
- //Flash专用
- unsigned char xdata cPageAddr _at_ 0x2010;
- unsigned int xdata iSectorAddr _at_ 0x2011;
- unsigned int xdata iFlashToRamAddr _at_ 0x2013;
- unsigned int xdata iRamToFlashAddr _at_ 0x2015;
- unsigned char xdata iFlashAddrH _at_ 0x2017;
- unsigned char xdata iFlashAddrM _at_ 0x2018;
- unsigned char xdata iFlashAddrL _at_ 0x2019;
- unsigned char xdata iFlashRdWrNum _at_ 0x201a;
- //菜单专用
- unsigned char xdata cMenuTemp1 _at_ 0x2020;
- unsigned char xdata cMenuTemp2 _at_ 0x2021;
- unsigned char xdata cMenuTemp3 _at_ 0x2022;
- unsigned int xdata iMenuID _at_ 0x2023;
- unsigned int xdata iMenuNextID _at_ 0x2025;
- //画线专用
- unsigned char xdata cLineTemp1 _at_ 0x2030;
- unsigned char xdata cLineTemp2 _at_ 0x2031;
- unsigned char xdata cLineTemp3 _at_ 0x2032;
- unsigned char xdata cLineTemp4 _at_ 0x2033;
- unsigned char xdata cLineTemp5 _at_ 0x2034;
- unsigned char xdata cLineTemp6 _at_ 0x2035;
- unsigned char xdata cLineTemp7 _at_ 0x2036;
- unsigned char xdata cLineTemp8 _at_ 0x2037;
- unsigned char xdata cLineTemp9 _at_ 0x2038;
- unsigned char xdata cLineTemp10 _at_ 0x2039;
- unsigned char xdata cLineTemp11 _at_ 0x203a;
- unsigned char xdata cLineTemp12 _at_ 0x203b;
- unsigned char xdata cLineTemp13 _at_ 0x203c;
- //DispTextLine
- unsigned char xdata cTextLineTemp1 _at_ 0x203d;
- unsigned char xdata cTextLineTemp2 _at_ 0x203e;
- unsigned char xdata cTextLineTemp3 _at_ 0x203f;
- //图形字符专用
- unsigned char xdata cGraphTemp1 _at_ 0x2040;
- unsigned char xdata cGraphTemp2 _at_ 0x2041;
- unsigned char xdata cGraphTemp3 _at_ 0x2042;
- unsigned char xdata cGraphTemp4 _at_ 0x2043;
- //主程序用
- unsigned char xdata NowKey _at_ 0x2044;
- unsigned char xdata RxPos _at_ 0x2045;
- unsigned char xdata RxStep _at_ 0x2046;
- unsigned char xdata RxPrev _at_ 0x2047;
- unsigned char xdata RxNow _at_ 0x2048;
- unsigned char xdata RxDataLenght _at_ 0x2049;
- unsigned char xdata TxPos _at_ 0x204a;
- unsigned char xdata TxNum _at_ 0x204b;
- //中断0用
- unsigned char xdata cTemp_ex0 _at_ 0x204c;
- //通讯中断用
- unsigned int xdata i_uart _at_ 0x204d;
- //写Flash用
- unsigned int xdata i_FlashWr _at_ 0x204f;
- unsigned char xdata c1_FlashWr _at_ 0x2051;
- //读Flash用
- unsigned int xdata i_FlashRd _at_ 0x2052;
- unsigned char xdata c1_FlashRd _at_ 0x2054;
- //Make05Answe专用
- unsigned int xdata i_Make05Answer _at_ 0x2055;
- unsigned char xdata cAdd_Make05Answer _at_ 0x2057;
- unsigned char xdata cXor_Make05Answer _at_ 0x2058;
- //读时间用
- unsigned char xdata i_RdTime _at_ 0x2059;
- //显示文本行用
- unsigned char xdata col_DispTextLine _at_ 0x205a;
- unsigned char code * xdata p_DispTextLine _at_ 0x205b;
- //显示开机画面
- unsigned char xdata i_FaceBmp _at_ 0x205d;
- unsigned char xdata j_FaceBmp _at_ 0x205e;
- unsigned char xdata k_FaceBmp _at_ 0x205f;
- unsigned char xdata c1_FaceBmp _at_ 0x2060;
- //DisponeTextChar
- unsigned char xdata i_DisponeTextChar _at_ 0x2061;
- unsigned char xdata j_DisponeTextChar _at_ 0x2062;
- unsigned char xdata k_DisponeTextChar _at_ 0x2063;
- unsigned char xdata cTemp_DisponeTextChar _at_ 0x2064;
- //键处理程序专用
- unsigned char xdata cKeyTemp1 _at_ 0x2065;
- //定时器0专用
- unsigned int xdata iT0_1S _at_ 0x2066;
- unsigned char xdata cClock_Year _at_ 0x2068;
- unsigned char xdata cClock_Month _at_ 0x2069;
- unsigned char xdata cClock_Day _at_ 0x206a;
- unsigned char xdata cClock_Hour _at_ 0x206b;
- unsigned char xdata cClock_Minute _at_ 0x206c;
- unsigned char xdata cClock_Second _at_ 0x206d;
- //cx
- //Timer
- #define TH0data 0xb8//20ms=0xb800,1ms=0xfc66
- #define TL0data 0x00//
- sbit LCD_CS=P1^0;
- sbit LCD_RESET=P1^1;
- sbit LCD_A0=P1^5;
- sbit LCD_WR=P1^6;
- sbit KEYINT=P3^2;
- sbit I2C_SCK=P3^4;
- sbit I2C_SDA=P3^5;
- sbit KEYROW1=P1^5;
- sbit KEYROW2=P1^6;
- sbit KEYROW3=P1^7;
- unsigned char bdata BitByte0;
- sbit bOldOnline=BitByte0^7;
- sbit b_ReceiveOver=BitByte0^6;
- sbit b_KeyInt=BitByte0^5;
- sbit b_Arrive1S=BitByte0^4;
- unsigned char bdata BitByte1;
- unsigned char bdata BitByte2;
- unsigned char bdata BitValue;
- sbit bOnline=BitValue^7;
- sbit bPowerOff=BitValue^6;
- unsigned char bdata BitValue1;
- sbit bBit7=BitValue1^7;
- sbit bBit6=BitValue1^6;
- sbit bBit5=BitValue1^5;
- sbit bBit4=BitValue1^4;
- sbit bBit3=BitValue1^3;
- sbit bBit2=BitValue1^2;
- sbit bBit1=BitValue1^1;
- sbit bBit0=BitValue1^0;
- void lcd_write_d(unsigned char c1);
- void lcd_write_c(unsigned char c1);
- void LcdInit();
- void MyInit();
- void DispOneBoxTextChar(unsigned char Row,unsigned char Col,unsigned char c1,unsigned char DispAttrib);
- void DispTwoBoxHexChar(unsigned char Row,unsigned char Col,unsigned char c1,unsigned char DispAttrib);
- void DispGraphChar(unsigned char Row,unsigned char Col,unsigned char xdata *cArray,unsigned char DispAttrib);
- void DispTextLine(unsigned char Row,unsigned char code *MenuText,unsigned char DispAttrib);
- void ReadyForKey();
- void DelayMs(unsigned int iMs);
- void UartProcess();
- void IAmZj();
- void IAmOk();
- void IAmUnKnow();
- void FlashSectorWr(unsigned int SourceXRamAddr,unsigned int TargetFlashAddr);
- void FlashSectorRd(unsigned int SourceFlashAddr,unsigned int TargetXRamAddr);
- void Make05Answer();
- void Make06Answer();
- void I2Cstart(void);
- void I2Csend(unsigned char);
- unsigned char I2Csuback(void);
- void I2Cmastack(void);
- unsigned char I2Cread(void);
- void I2Cnoack(void);
- void I2Cstop(void);
- void Make07Answer();
- unsigned char set_time();
- void Make08Answer();
- void MakeBox(unsigned char row1,unsigned char col1,unsigned char row2,unsigned char col2);
- void MenuFunctionNull();
- void MenuFunctionDemo1();
- void MenuFunctionDemo2();
- void MenuFunctionDemo3();
- void MenuFunctionDemo4();
- void MenuFunctionDemo5();
- void MenuFunctionDemo6();
- void MenuFunctionDemo7();
- void MenuFunctionDemo8();
- void MenuFunctionDemo9();
- void MenuFunctionDemo10();
- void MenuFunctionDemo11();
- void MenuFunctionDemo12();
- void MenuFunctionDemo13();
- void MenuFunctionDemo14();
- void MenuFunctionDemo15();
- void MenuFunctionDemo16();
- void MenuFunctionDemo17();
- void MenuFunctionDemo18();
- void MenuFunctionDemo19();
- void DispFaceBmp();
- void DispMenu_Root();
- void DispMenu_View();
- void DispMenu_Operation();
- void DispMenu_Test();
- void DispMenu_SystemSet();
- void DispMenu_Debug();
- void JudgeHLight();
- unsigned char ReadTime();
- void ShowDesktopTime();
- unsigned char code Echar[96][8];
- unsigned char code FaceBmp[112][8];
- unsigned char code *Menu_Root[4]=
- " View ",
- " Operation ",
- " Test ",
- " System Set "
- unsigned int code Menu_RootID[4]=
- MENU_VIEW,
- MENU_OPERATION,
- MENU_TEST,
- MENU_SYSTEMSET
- unsigned char code *Menu_View[2]=
- " About ZL ",
- " HandSet CLK "
- unsigned int code Menu_ViewID[2]=
- MENU_VIEW_ABOUTRECORDE,
- MENU_VIEW_HANDSETCLOCK
- unsigned char code *Menu_Operation[5]=
- " Set Position ",
- " Rd Zj To ROM ",
- " Rd ZL To Ram ",
- " Del Given ZL ",
- " Del All ZL "
- unsigned int code Menu_OperationID[5]=
- MENU_OPERATION_SETPOSITION,
- MENU_OPERATION_READZJTOFLASH,
- MENU_OPERATION_RDZJTORAM,
- MENU_OPERATION_DELGIVENZL,
- MENU_OPERATION_DELALLZJ
- unsigned char code *Menu_Test[2]=
- " Ram Test ",
- " Flash Test "
- unsigned int code Menu_TestID[2]=
- MENU_TEST_RAMTEST,
- MENU_TEST_FLASHTEST
- unsigned char code *Menu_SystemSet[2]=
- " Debug ",
- " Set Hand Clk "
- unsigned int code Menu_SystemSetID[2]=
- MENU_SYSTEMSET_DEBUG,
- MENU_SYSTEMSET_SETHANDCLK
- unsigned char code *Menu_Debug[2]=
- " PassWord ",
- " See Picture "
- unsigned int code Menu_DebugID[2]=
- MENU_SYSTEMSET_DEBUG_PASSWORD,
- MENU_SYSTEMSET_DEBUG_SEEPICTURE
- unsigned char code MenuNULL[]={" "};
- main()
- MyInit();
- LcdInit();
- cMenuHLight[0x00]=0x00;
- cMenuHLight[0x01]=0x00;
- cMenuHLight[0x02]=0x00;
- cMenuHLight[0x03]=0x00;
- cMenuHLight[0x04]=0x00;
- cMenuHLight[0x05]=0x00;
- cMenuHLight[0x06]=0x00;
- cMenuHLight[0x07]=0x00;
- cMenuHLight[0x08]=0x00;
- cMenuHLight[0x09]=0x00;
- cMenuHLight[0x0a]=0x00;
- cMenuHLight[0x0b]=0x00;
- cMenuHLight[0x0c]=0x00;
- cMenuHLight[0x0d]=0x00;
- cMenuHLight[0x0e]=0x00;
- cMenuHLight[0x0f]=0x00;
- DelayMs(20);
- //调试用
- MenuFunctionNull();
- Bitvalue="/oblog3/XBYTE[Addr_Key];
- bOldOnline=(~bOnline);
- b_KeyInt=0;
- b_ReceiveOver=0;
- b_Arrive1S=0;
- DispFaceBmp();
- iMenuID=MENU_FACE;
- while(1)
- ReadyForKey();
- BitValue=XBYTE[Addr_Key];
- if(bOldOnline!=bOnline)
- bOldOnline=bOnline;
- if(!bOldOnline)
- {//Line=1
- else
- {//Line=0;
- if(b_ReceiveOver)
- UartProcess();
- b_ReceiveOver=0;
- RxStep=0;
- RxPos=0;
- REN=1;
- if(b_KeyInt)
- switch(NowKey)
- case KEY_OK://KEY_OK, KEY_UP, KEY_ESC,
- if(KeyTab[iMenuID].KeyTab_PressOk!=999)
- iMenuID=KeyTab[iMenuID].KeyTab_PressOk;
- iMenuNextID=KeyTab[iMenuID].KeyTab_PressOk;
- JudgeHLight();
- KeyFuncPtr=KeyTab[iMenuID].CurrentOperate;
- " (*KeyFuncPtr)(); //执行当前按键的操作
- break;
- case KEY_UP:
- if((KeyTab[iMenuID].KeyTab_PressUp!=999)&&(iMenuNextID!=999))
- KeyTab[iMenuID].KeyTab_PressOk=KeyTab[iMenuNextID].KeyTab_PressUp;
- iMenuNextID=KeyTab[iMenuNextID].KeyTab_PressUp;
- JudgeHLight();
- break;
- case KEY_ESC:
- if(KeyTab[iMenuID].KeyTab_PressEsc!=999)
- iMenuID=KeyTab[iMenuID].KeyTab_PressEsc;
- JudgeHLight();
- (*KeyFuncPtr)(); //执行当前按键的操作
- break;
- case KEY_LEFT://KEY_LEFT, KEY_DOWN, KEY_RIGHT,
- JudgeHLight();
- break;
- case KEY_DOWN:
- if((KeyTab[iMenuID].KeyTab_PressDown!=999)&&(iMenuNextID!=999))
- KeyTab[iMenuID].KeyTab_PressOk=KeyTab[iMenuNextID].KeyTab_PressDown;
- iMenuNextID=KeyTab[iMenuNextID].KeyTab_PressDown;
- JudgeHLight();
- break;
- case KEY_RIGHT:
- JudgeHLight();
- break;
- case KEY_1://KEY_1, KEY_2, KEY_3,
- break;
- case KEY_2:
- break;
- case KEY_3:
- break;
- case KEY_4://KEY_4, KEY_5, KEY_6,
- break;
- case KEY_5:
- break;
- case KEY_6:
- break;
- case KEY_7://KEY_7, KEY_8, KEY_9,
- break;
- case KEY_8:
- break;
- case KEY_9:
- break;
- case KEY_XING://KEY_XING, KEY_0, KEY_JING,
- break;
- case KEY_0:
- break;
- case KEY_JING:
- break;
- case KEY_POWER://KEY_POWER, KEY_NULL
- break;
- case KEY_NULL:
- MakeBox(3,3,5,12);
- break;
- default:
- break;
- b_KeyInt=0;
- if((b_Arrive1S==1)&&(iMenuID==MENU_FACE))
- ReadTime();
- ShowDesktopTime();
- b_Arrive1S=0;
- void isr_ex0(void) interrupt 0 using 1
- b_KeyInt=1;
- cTemp_ex0=0xff;
- DelayMs(20);
- ReadyForKey();
- cTemp_ex0=XBYTE[Addr_Key];
- cTemp_ex0=cTemp_ex0&0x3f;
- switch(cTemp_ex0)
- case 0x3e://第一行
- NowKey=0x10;
- break;
- case 0x3d://第二行
- NowKey=0x20;
- break;
- case 0x3b://第三行
- NowKey=0x30;
- break;
- case 0x37://第四行
- NowKey=0x40;
- break;
- case 0x2f://第五行
- NowKey=0x50;
- break;
- case 0x1f://第六行
- NowKey=0x60;
- break;
- default:
- NowKey=0x00;
- break;
- KEYROW1=0;
- KEYROW2=1;
- KEYROW3=1;
- cTemp_ex0&=0x3f;
- if(cTemp_ex0!=0x3f)
- NowKey=NowKey|0x01;
- else
- KEYROW1=1;
- KEYROW2=0;
- KEYROW3=1;
- cTemp_ex0&=0x3f;
- NowKey=NowKey|0x02;
- else
- KEYROW1=1;
- KEYROW2=1;
- KEYROW3=0;
- cTemp_ex0&=0x3f;
- NowKey=NowKey|0x03;
- else
- if(!bPowerOff)
- NowKey=0x71;
- else
- NowKey=0x00;
- do
- DelayMs(100);
- }while(!KEYINT);
- IE0=0;//清外中断0请求
- void isr_t0(void) interrupt 1 using 2
- TL0=TL0data;
- TH0=TH0data;
- iT0_1S+=20;//因为定时器的定时为20Ms一次
- if(iT0_1S>=1000)
- iT0_1S=0;
- b_Arrive1S=1;
- void isr_ex1(void) interrupt 2 using 1
- _nop_();
- void isr_t1(void) interrupt 3 using 2
- _nop_();
- void isr_ser(void) interrupt 4 using 3
- if(TI)
- if((TxNum--)>0)
- SBUF=Send232Buffer[TxPos++];
- else
- TxNum=0;
- TxPos=0;
- TI=0;
- else
- RI=0;
- RxNow=SBUF;
- Rev232Buffer[RxPos++]=RxNow;
- if(RxPos>=255)
- RxPos=0;
- if(!b_ReceiveOver)
- switch(RxStep)
- case 0://帧头:55 55
- if(RxNow==0x55)
- if(RxPrev==0x55)
- RxStep=1;
- else
- RxPrev=RxNow;
- RxPos=0;
- RxStep=0;
- else
- RxStep=0;
- RxPos=0;
- REN=1;
- break;
- case 1://命令帧和数据帧的判断
- if((RxNow&0x80)==0)
- RxStep=3;
- else
- RxPrev=RxNow;
- RxStep=2;
- break;
- case 2://命令帧,第二个命令字(和第一个命令字相同)
- if(RxNow==RxPrev)
- RxStep=7;
- else
- RxStep=0;
- RxPos=0;
- REN=1;
- break;
- case 3://数据帧,帧长度
- RxDataLenght=RxNow;
- RxStep=4;
- break;
- case 4://数据帧,数据段
- RxDataLenght--;
- if(RxDataLenght==0)
- RxStep=5;
- break;
- case 5://数据帧,累加和
- RxStep=6;
- break;
- case 6://数据帧,异或和
- RxStep=8;
- break;
- case 7://命令帧,累加和
- RxStep=8;
- break;
- case 8://帧尾:aa aa
- if(RxNow==0xaa)
- if(RxPrev==0xaa)
- b_ReceiveOver=1;
- REN=0;
- else
- RxPrev=RxNow;
- else
- RxStep=0;
- RxPos=0;
- REN=1;
- break;
- default:
- RxStep=0;
- RxPos=0;
- REN=1;
- break;
- cUartTemp1=0;
- cUartTemp2=0;
- cUartTemp3=0;
- cUartFunSn=0xff;
- cUartTemp1=Rev232Buffer[0];
- cUartTemp2=Rev232Buffer[1];
- if((cUartTemp1==0x55)&(cUartTemp2==0x55))
- cUartTemp1=Rev232Buffer[2];
- cUartTemp1&=0x80;
- if(cUartTemp1!=0)
- {//命令帧
- cUartTemp2=Rev232Buffer[3];
- if(cUartTemp1==cUartTemp2)
- cUartTemp3=cUartTemp1+cUartTemp2;
- cUartTemp1=Rev232Buffer[4];
- if(cUartTemp1==cUartTemp3)
- cUartTemp1=Rev232Buffer[5];
- cUartTemp2=Rev232Buffer[6];
- if((cUartTemp1==0xaa)&&(cUartTemp2=0xaa))
- cUartFunSn=Rev232Buffer[2];
- else
- {//数据帧
- cUartAddSum=Rev232Buffer[2]+Rev232Buffer[3];
- cUartXorSum=Rev232Buffer[2]^Rev232Buffer[3];
- cUartDataLenght=Rev232Buffer[3];
- for(i_uart=4;i_uart<(cUartDataLenght+4);i_uart++)
- cUartTemp1=Rev232Buffer[i_uart];
- cUartAddSum+=cUartTemp1;
- cUartXorSum^=cUartTemp1;
- cUartTemp1=Rev232Buffer[cUartDataLenght+4];
- cUartDataLenght++;
- cUartTemp2=Rev232Buffer[cUartDataLenght+4];
- if((cUartTemp1==cUartAddSum)&&(cUartTemp2==cUartXorSum))
- if((cUartTemp1==0xaa)&&(cUartTemp2==0xaa))
- cUartFunSn=Rev232Buffer[6];
- switch(cUartFunSn)
- case 0xa5:
- case 0xa6://我要伪装成座机0xa7
- IAmZj();
- break;
- case 0xac:
- case 0xad:
- case 0xae:
- IAmOk();
- break;
- case 5:
- iFlashAddrH=Rev232Buffer[7];
- iFlashAddrM=Rev232Buffer[8];
- iFlashAddrL=Rev232Buffer[9];
- iFlashRdWrNum=Rev232Buffer[10];
- i_uart=iFlashAddrM;
- i_uart=(i_uart<<8)&0xff00;
- FlashSectorRd(i_uart,Addr_FlashReadBuffer1);
- i_uart=iFlashAddrM+1;
- FlashSectorRd(i_uart,Addr_FlashReadBuffer2);
- Make05Answer();
- break;
- case 6:
- FlashSectorRd(i_uart,Addr_FlashWriteBuffer1);
- FlashSectorRd(i_uart,Addr_FlashWriteBuffer2);
- cUartTemp1=iFlashRdWrNum;
- iUartTemp1=iFlashAddrL;
- cUartTemp2=0;
- while(cUartTemp1>0)
- XBYTE[Addr_FlashWriteBuffer1+iUartTemp1]=Rev232Buffer[11+cUartTemp2];
- cUartTemp1--;
- iUartTemp1++;
- cUartTemp2++;
- FlashSectorWr(Addr_FlashWriteBuffer1,i_uart);
- FlashSectorWr(Addr_FlashWriteBuffer2,i_uart);
- Make06Answer();
- break;
- case 7:
- ReadTime();
- Make07Answer();
- break;
- case 8:
- // 5 7 8 9 10 11 12
- //55 55 03 09 00 CF 08 03 11 11 19 39 15 6F FB AA AA
- clock[0]=0xa2;//I2C address
- clock[1]=0x02;//address
- clock[8]=Rev232Buffer[7];//year
- clock[7]=Rev232Buffer[8];//month
- clock[5]=Rev232Buffer[9];//date
- clock[4]=Rev232Buffer[10];//hours
- clock[3]=Rev232Buffer[11];//minutes
- clock[2]=Rev232Buffer[12];//seconds
- set_time();
- Make08Answer();
- break;
- default:
- IAmUnKnow();
- RxStep=0;
多级菜单.rar
(76.02 KB, 下载次数: 104)
