查看: 3557|回复: 1
单片机蓝牙实验 控制LED流水方式
ID:171810 发表于 2017-6-9 11:05 | 显示全部楼层 |阅读模式
自己做了个蓝牙控制,还多好耍的,懂原理就很简单,用HC06来实现的。挺好耍的。
单片机源码:
  1. #include<reg52.h>
  2. #define        uint        unsigned int
  3. #define        uchar        unsigned char
  4. uchar code table0[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};//LED从低位往高位移
  5. uchar code table1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};//LED从高位往低位移
  6. uchar code table2[]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00};//LED从1个亮到8个都点亮(从低位往高位)
  7. uchar code table3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x00};//LED从1个亮到8个都点亮(从高位往低位)
  8. uchar code table4[]={0x00,0x01,0x03,0x07,0x0f,0x1f,0x3f,0x7f,0xff};//LED从8个全亮到一个都不亮(从低位往高位)
  9. uchar code table5[]={0x00,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff};//LED从8个全亮到一个都不亮(从高位往低位)
  10. uchar code table6[]={0xfe,0xfc,0xfa,0xf6,0xee,0xde,0xbe,0x7e};//LED从低位往高位移(最低位始终为0)
  11. uchar code table7[]={0x7f,0x3f,0x5f,0x6f,0x77,0x7b,0x7d,0x7e};//LED从高位往低位移(最高位始终为0)
  12. uint ma,mb,mc;i;
  13. void delay(unsigned int i) //定义延时函数
  14. {
  15.    unsigned int k;
  16.    for(k=0;k<i;k++);
  17.    }
  18. void init()
  19. {
  20.     TMOD=0x20;//设置定时器1为工作方式2
  21.         TH1=0xfd;
  22.         TL1=0xfd;
  23.         SCON=0x50;
  24.         TR1=1;
  25.         EA=1;
  26.         ES=1;
  27. }
  28. void main()
  29. {
  30.   init();
  31.   while(1)
  32.          {
  33.     if(RI)
  34.           {
  35.          RI=0;
  36.          ma=SBUF;
  37.            if(ma=='1')
  38.              {
  39.             for(i=0;i<8;i++);
  40.                    {
  41.                    P0=table0[i];
  42.                    delay(100);
  43.                    P2=table0[i];
  44.                    delay(100);
  45.                    }
  46.                  }
  47.                  if(ma=='2')
  48.                    {
  49.                    for(i=0;i<8;i++)
  50.                       {
  51.                      P0=table1[i];
  52.                          delay(100);
  53.                          P2=table1[i];
  54.                          delay(100);
  55.                          }
  56.            }
  57.                   if(ma=='3')
  58.                    {
  59.                    for(i=0;i<8;i++)
  60.                       {
  61.                      P0=table2[i];
  62.                          delay(100);
  63.                          P2=table2[i];
  64.                          delay(100);
  65.                          }
  66.            }
  67.                  if(ma=='4')
  68.                    {
  69.                    for(i=0;i<8;i++)
  70.                       {
  71.                      P0=table3[i];
  72.                          delay(100);
  73.                          P2=table3[i];
  74.                          delay(100);
  75.                          }
  76.            }
  77.                  if(ma=='5')
  78.                    {
  79.                    for(i=0;i<9;i++)
  80.                       {
  81.                      P0=table4[i];
  82.                          delay(100);
  83.                          P2=table4[i];
  84.                          delay(100);
  85.                          }
  86.            }
  87.                  if(ma=='6')
  88.                    {
  89.                    for(i=0;i<9;i++)
  90.                       {
  91.                      P0=table5[i];
  92.                          delay(100);
  93.                          P2=table5[i];
  94.                          delay(100);
  95.                          }
  96.            }
  97.                  if(ma=='7')
  98.                    {
  99.                    for(i=0;i<8;i++)
  100.                       {
  101.                      P0=table6[i];
  102.                          delay(100);
  103.                          P2=table6[i];
  104.                          delay(100);
  105.                          }
  106.            }
  107.                  if(ma=='8')
  108.                    {
  109.                    for(i=0;i<8;i++)
  110.                       {
  111.                      P0=table7[i];
  112.                          delay(100);
  113.                          P2=table7[i];
  114.                          delay(100);
  115.                          }
  116.            }
  117.                  if(ma=='9')
  118.                    {
  119.                    for(i=0;i<8;i++)
  120.                       {
  121.                      P0=table7[i];
  122.                          delay(100);
  123.                          P2=table7[i];
  124.                          delay(100);
  125.                          }
  126.            }
  127.                   }
  128. …………限于本文篇幅 余下代码请从51黑下载附件…………
全部资料下载地址:
蓝牙实验.rar (32.81 KB, 下载次数: 29)
ID:194176 发表于 2017-6-12 10:06 | 显示全部楼层
51有你更精彩,继续加油
