查看: 2013|回复: 0
自动循迹小车程序(51单片机)
ID:210992 发表于 2017-6-25 14:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
循迹小车程序下载:
自动循迹小车程序.rar (3.89 KB, 下载次数: 10)
  1. #define P_IOA_Data (volatile unsigned int *)0x7000
  2. #define P_IOA_Dir (volatile unsigned int *)0x7002
  3. #define P_IOA_Attrib (volatile unsigned int *)0x7003
  4. unsigned int scan();//检测黑线函数定声明
  5. unsigned int num=0;
  6. void delay();
  7. void init_1()//输入初始化
  8. {
  9. [P_IOA_Dir]=0x00f0;
  10. [P_IOA_Attrib]=0x00f0;
  11. [P_IOA_Data]=0x000f;
  12. }
  13. //void init_2()//输出初始化
  14. //{
  15. //[P_IOA_Dir]=1;
  16. //[P_IOA_Attrib]=1;
  17. //[P_IOA_Data]=0;
  18. //}
  19. void main()
  20. {
  21. while(1)
  22. {
  23.   void init_1();
  24.   num=scan();
  25.   //void init_2();
  26.   switch(num)
  27.   {
  28.   case 1:
  29.    {
  30.     while(1)
  31.     {
  32.      [P_IOA_Data]=0x9f;
  33.      delay(500);
  34. //     if([P_IOA_Data]==1)//传感器返回1,则终止转弯,下同
  35.      break;
  36.     }
  37.    }
  38.   case 2:
  39.    {
  40.     while(1)
  41.     {
  42.      [P_IOA_Data]=0x9f;
  43.      delay(500);
  44.      break;
  45.     }
  46.    }
  47.   case 4:
  48.    {
  49.     while(1)
  50.     {
  51.      [P_IOA_Data]=0x6f;
  52.      delay(500);
  53.      break;
  54.     }
  55.    }
  56.   case 5:
  57.    {
  58.     while(1)
  59.     {
  60.      [P_IOA_Data]=0x6f;
  61.      delay(500);
  62.      break;
  63.     }
  64.    }
  65.   case 0:
  66.    {
  67.     while(1)
  68.     {
  69.      [P_IOA_Data]=0x5f;
  70.      delay(500);
  71.      break;
  72.     }
  73.    }
  74.   }
  75. [P_IOA_Data]=0x5f;//直走
  76. delay(500);
  77. }
  78. }
  79. void delay(uint z)
  80. {
  81. uint x,y;
  82. for(x=z;x>0;x--)
  83.   for(y=110;y>0;y--);
  84. }
  85. unsigned int scan()
  86. {
  87. if(P_IOA_Data==0xfe)
  88. {
  89.   num=1;
  90.   return num;
  91. }
  92. if(line_2==0xfd)
  93. {
  94.   num=2;
  95.   return num;
  96. }
  97. if(line_4==0xfb)
  98. {
  99.   num=4;
  100.   return num;
  101. }
  102. if(line_5==0xf7)
  103. {
  104.   num=5;
  105.   return num;
  106. }
  107. return 0;
  108. }
