压缩后有可能不能运,里面有C语言文件,你自己可以生成hex文件,然后自己添加到里面,供参考
proteus仿真图如下:
- #include<reg51.h>
- #include <intrins.h>
- #define Disdata P3
- #define discan P0
- sbit adrd=P2^7; //IO口定义
- sbit adwr=P2^6;
- sbit csad=P2^4;
- sbit DIN=P3^7; //LED小数点控制
- unsigned char j,k,ad_data,t;
- unsigned char dis[4]={0x00,0x00,0x00,0x00};
- unsigned char code dis_7[12]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x40};
- /* 共阳LED段码表对应 "0" "1" "2" "3" "4" "5" "6" "7" "8" "9" "不亮" "-" */
- unsigned char code scan_con[4]={0xfe,0xfd,0xfb,0xf7}; // 列扫描控制字
- void delay(unsigned int t)
- for(;t>0;t--)
- } //11微秒延时函数
- void scan()
- char k;
- for(k=0;k<4;k++) //四位LED扫描控制
- Disdata=dis_7[dis[k]];
- if(k==1)
- DIN=1; //加入小数点
- discan=scan_con[k];
- delay(90);
- discan=0xff;
- void ad0804()
- P1=0xff; //读取P1口之前先给其写全1
- csad=0; //选通ADCS
- adrd=0; //AD读使能
- ad_data=P1; //AD数据读取赋给P1口
- adrd=1;
- csad=1; //关闭ADCS
- adwr=0;
- void ad_compute() //u=2.55+T/100, 2.55反映在AD上为0x83
- unsigned char t_temp;
- //if(ad_data>=0x83)
- ad_data=ad_data-0x83;
- t_temp=ad_data*2-4;
- if(t_temp<=110)
- dis[3]=t_temp/100;
- dis[2]=t_temp/10-dis[3]*10;
- dis[1]=t_temp%10;
- dis[0]=t%5*2;
- else
- t_temp=256-t_temp;
- dis[3]=11;
- dis[2]=t_temp/10;
- dis[1]=t_temp%10;
- dis[0]=t%5*2;
热敏电阻温度计.zip
(27.77 KB, 下载次数: 199)
