查看: 4223|回复: 1
基于arduino的循迹小车,源代码
ID:220285 发表于 2017-7-17 15:08 | 显示全部楼层 |阅读模式
void motor(char pin,char pwmpin,char state,int val)
    pinMode(pin, OUTPUT);
  if(state==1)
    analogWrite(pwmpin,val);
    digitalWrite(pin,1);
  else if(state==2)
   digitalWrite(pin,0);
else if(state==0)
    analogWrite(pwmpin,0);
void runfoward(int i)   //前进
  motor(4,5,1,i);
  motor(7,6,1,i);
void runback(int j)    //后退
   motor(4,5,2,j);
   motor(7,6,2,j);
void turnL(int m)     //左转
  motor(4,5,1,m);
  motor(7,6,0,0);
void turnR(int n)      //右转
  motor(4,5,0,0);
  motor(7,6,1,n);
void stop()            //停止
  motor(4,5,0,0);
  motor(7,6,1,0);
void setup()
  pinMode(10,INPUT);//定义右边传感器,
  pinMode(11,INPUT);//定义中间传感器,
  pinMode(12,INPUT);//定义左边传感器,
  Serial.begin(9600);
void loop()
  char num1,num2,num3;
  num1=digitalRead(12);
  num2=digitalRead(11);
  num3=digitalRead(10);
   if((num1==0)&&num2&&num3)
    turnL(120);          //检测到左边传感器遇到黑线,说明小车右偏了,立即往左转一点
    delay(2);
    while(1){
    num2=digitalRead(11);         //循环判断中间传感器度数,
    if(num2==1)
    {  turnL(120);                     //如果num2==1说明还没有转到中间位置,继续左转
     delay(2);}
     break;                      //检测到num2==0说明转过头了,跳出循环,检测三个传感器的状态再做出相应动作
   }                                       //后面道理相同
  else if(num2&&num1&&(num3==0))
    turnR(120);
    delay(2);
    if(num2==1){
      turnR(120);
     delay(2);}
      break;
    runfoward(120);
    delay(2);
ID:221212 发表于 2017-7-20 22:28 | 显示全部楼层
厉害厉害,这个循迹有点像自动避障呀?
