战舰驱动nokia 5110屏幕。。亲测可用
PCD8544特征:
单芯片 LCD 控制/驱动
48 行,84 列输出
显示数据 RAM 48*84 位
芯片集成:
——LCD电压发生器(也可以使用外部电压供应)
——LCD偏置电压发生器
——振荡器不需要外接元件(也可以使用外部时钟)
外部 RES(复位)输入引脚
串行界面最高4.0Mbits/S
CMOS兼容输入
混合速率:48
逻辑电压范围VDD到 VSS:2.7V~3.3V
显示电压范围VLCD到 VSS:
——6.0~8.5V LCD内部电压发生器(充许电压发生器)
——6.0~9.0V LCD外部电压供应(电压发生器关闭)
低功耗,适用于电池供电系统
关于VLCD的温度补偿
使用温度范围:-25~70℃
48x84点矩阵LCD控制/驱动
PCD8544方框图:
PCD8544引脚功能介绍:
PCD8544中文资料pdf文档的截图:
stm32源程序:
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "LCD5110.h"
- //ALIENTEK miniSTM32开发板实验1
- int main(void)
- delay_init(); //延时函数初始化
- LED_Init(); //初始化与LED连接的硬件接口
- #if USESPI
- SPI1_Config();
- DMA_SPI_Config();
- #endif
- LCD5110_Init();
- delay_ms(10);
- LCD_Clear();
- // delay_ms(10);
- // LCD_Write_EnStr(0,0,"**************");
- // LCD_Write_EnStr(0,1,"gu dong dong");
- // LCD_Write_EnStr(0,2,"smart health");
- // LCD_Write_EnStr(0,3,"JiangsuZhihai");
- // LCD_Write_EnStr(0,4,"ElectronicTechnology");
- // LCD_Write_EnStr(0,5,"**************");
- delay_ms(10); //μè′y
- LCD_Write_Hanzi(2,0,0);
- LCD_Write_Hanzi(4,0,1);
- LCD_Write_Hanzi(6,0,2);
- LCD_Write_Hanzi(8,0,3);
- LCD_Write_Hanzi(10,0,4);
- LCD_Write_Hanzi(2,2,5);
- LCD_Write_Hanzi(4,2,6);
- LCD_Write_Hanzi(6,2,7);
- LCD_Write_Hanzi(8,2,8);
- LCD_Write_Hanzi(10,2,9);
- LCD_Write_Hanzi(2,4,10);
- LCD_Write_Hanzi(4,4,11);
- while(1)
- GPIO_ResetBits(GPIOA,GPIO_Pin_8); //LED0输出低
- GPIO_SetBits(GPIOD,GPIO_Pin_2);//LED1输出高
- delay_ms(300);
- GPIO_SetBits(GPIOA,GPIO_Pin_8);//LED0输出高
- GPIO_ResetBits(GPIOD,GPIO_Pin_2);//LED1输出低
- delay_ms(300);
全部资料下载地址:
源程序:
ALIENTEK MINISTM32 驱动诺基亚5110液晶.rar
(314.61 KB, 下载次数: 63)
