查看: 3720|回复: 3
单片机串口通信方式1双机通信
ID:225607 发表于 2017-8-7 21:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主机1:程序源码keil
#include<reg52.h>
#define uint unsigned int
uchar code table0[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
int flag=0;
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
  for(j=110;j>0;j--);
void display0(uchar num)
P0=table0[num];
delayms(1000);
//wela=1;
//wela=0;
void send(uchar key_num)
  ES=0;
  SBUF=key_num;
  while(!TI);
  TI=0;;
void matrixkeyscan()
  uchar temp,key,value;
  P2=0xfe;
  temp=P2;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xee:
                key=0;
                        break;
          case 0xde:
                key=1;
                        break;
          case 0xbe:
                key=2;
                        break;
          case 0x7e:
                key=3;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send(key);
  P2=0xfd;
  temp=P2;
  temp=temp&0xf0;
   if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xed:
                key=4;
                        break;
          case 0xdd:
                key=5;
                        break;
          case 0xbd:
                key=6;
                        break;
          case 0x7d:
                key=7;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send(key);
  P2=0xfb;
  temp=P2;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xeb:
                key=8;
                        break;
          case 0xdb:
                key=9;
                        break;
          case 0xbb:
                key=10;
                        break;
          case 0x7b:
                key=11;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send(key);
  P2=0xf7;
  temp=P2;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xe7:
                key=12;
                        break;
          case 0xd7:
                key=13;
                        break;
          case 0xb7:
                key=14;
                        break;
          case 0x77:
                key=15;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send(key);
  if(0<key<=15&&value==0xee)
    ES=0;
  else ES=1;
  TMOD=0x20;
  TH1=0xfd;
  TL1=0xfd;
  TR1=1;
  SM0=0;
  SM1=1;
  REN=1;
  EA=1;
  ES=1;
  P0=0x00;
   matrixkeyscan();
void ser0() interrupt 4
  uchar a;
  RI=0;
  a=SBUF;
  display0(a);
主机2: keil源码
#include<reg52.h>
int flag1=0;
//sbit dula=P2^6;
//sbit wela=P2^7;
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uint i,j;
for(i=xms;i>0;i--)
  for(j=110;j>0;j--);
void display(uchar num)
P0=table[num];
delayms(1000);
//wela=1;
//wela=0;
void send1(uchar key_num)
  ES=0;
  SBUF=key_num;
  while(!TI);
  TI=0;
void matrixkeyscan1()
  uchar temp,key,value1;
  P2=0xfe;
  temp=P2;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xee:
                key=0;
                        break;
          case 0xde:
                key=1;
                        break;
          case 0xbe:
                key=2;
                        break;
          case 0x7e:
                key=3;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send1(key);
  P2=0xfd;
  temp=P2;
  temp=temp&0xf0;
   if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xed:
                key=4;
                        break;
          case 0xdd:
                key=5;
                        break;
          case 0xbd:
                key=6;
                        break;
          case 0x7d:
                key=7;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send1(key);
  P2=0xfb;
  temp=P2;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xeb:
                key=8;
                        break;
          case 0xdb:
                key=9;
                        break;
          case 0xbb:
                key=10;
                        break;
          case 0x7b:
                key=11;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send1(key);
  P2=0xf7;
  temp=P2;
  temp=temp&0xf0;
  if(temp!=0xf0)
   delayms(10);
   temp=P2;
   temp=temp&0xf0;
   if(temp!=0xf0)
    temp=P2;
        switch(temp)
          case 0xe7:
                key=12;
                        break;
          case 0xd7:
                key=13;
                        break;
          case 0xb7:
                key=14;
                        break;
          case 0x77:
                key=15;
                        break;
        while(temp!=0xf0)
          temp=P2;
          temp=temp&0xf0;
        send1(key);
  if(0<key<=15&&value1==0xee)
    ES=0;
  else ES=1;
  TMOD=0x20;
  TH1=0xfd;
  TL1=0xfd;
  TR1=1;
  SM0=0;
  SM1=1;
  REN=1;
  EA=1;
  ES=1;
  P0=0x00;
  //wela=1;
  //wela=0;
    matrixkeyscan1();
void ser() interrupt 4
  uchar a;
  RI=0;
  a=SBUF;
  display(a);
protues仿真图如下:
ID:280466 发表于 2018-5-20 20:57 | 只看该作者
可以吗
ID:293038 发表于 2018-5-23 22:01 | 只看该作者
楼主,在液晶12864上显示可以吗?
ID:336959 发表于 2018-5-23 23:13 | 只看该作者
好东西顶顶  我也试试
