查看: 2861|回复: 13
求各位大佬帮帮小弟啦 3个单片机问题
ID:218870 发表于 2017-8-13 05:53 | 显示全部楼层
//液晶1602(带字库)显示测试程序// #include<reg51.h> #define uint unsigned int #define uchar unsigned char        //宏定义 uchar code table[]=" LU LIE QI "; uchar code table1[]="WWW.LAOWANG.COM"; sbit LCD_RS=P2^6;          //位定义 sbit LCD_RW=P2^5; sbit LCD_EN=P2^7; uchar num;           //定义全局变量 //延时程序===1ms// void delay_1ms(uint mas) {         uint i,j;         for(i=0;i<mas;i++)         for(j=0;j<110;j++); } void write_com(uchar com)  //  写命令 {         LCD_RS=0;         LCD_RW=0;         P0=com;         delay_1ms(5);         LCD_EN=1;         delay_1ms(5);         LCD_EN=0; } void write_data(uchar dadt) //写数据 {         LCD_RS=1;         P0=dadt;         delay_1ms(5);         LCD_EN=1;         delay_1ms(5);         LCD_EN=0;  } void init()  //初始化函数 {         LCD_EN=0;         write_com(0x38);        //显示模式设置16X2,5X7点阵,8位数据口         write_com(0x0f);        //开显示、开关标、关标闪烁         write_com(0x06);        //关标加一         write_com(0x01);        //清屏         write_com(0x80+0x10);        //数据指针位置         } //=====主函数======// void main() {         init();                  for(num=0;num<10;num++)         {                         write_data(table[num]);                         delay_1ms(20);                                          }         write_com(0x80+0x50);         for(num=0;num<15;num++)         {                         write_data(table1[num]);                         delay_1ms(20);                                          }         for(num=0;num<16;num++)         {                 write_com(0x18);                 delay_1ms(500);                 }         while(1); }
