vl53l0x激光测距的stm32单片机源程序如下:
- #include "vl53l0.h"
- VL53L0X_Dev_t vl53l0x_dev;
- VL53L0X_DeviceInfo_t vl53l0x_dev_info;
- VL53L0X_RangingMeasurementData_t vl53l0x_data;
- VL53L0X_Error vl53l0x_status;
- void print_pal_error(VL53L0X_Error Status)
- char buf[VL53L0X_MAX_STRING_LENGTH];
- VL53L0X_GetPalErrorString(Status, buf); //得到错误码与字符串
- printf("API Status: %i : %s\n", Status, buf);
- void print_range_status(VL53L0X_RangingMeasurementData_t* pdata)
- uint8_t RangeStatus;
- // New Range Status: data is valid when pdata->RangeStatus = 0
- RangeStatus = pdata->RangeStatus;
- VL53L0X_GetRangeStatusString(RangeStatus, buf);
- // printf("Range Status: %i : %s\n", RangeStatus, buf);
- VL53L0X_Error vl53l0x_start_single_test(VL53L0X_Dev_t *pdev, \
- VL53L0X_RangingMeasurementData_t *pdata)
- VL53L0X_Error status = VL53L0X_ERROR_NONE;
- if(vl53l0x_status != VL53L0X_ERROR_NONE)
- return vl53l0x_status;
- status = VL53L0X_PerformSingleRangingMeasurement(pdev, pdata); //VL53L0X执行单一测量范围
- if(status != VL53L0X_ERROR_NONE){
- // printf("error:Call of VL53L0X_PerformSingleRangingMeasurement\n");
- return status;
- print_range_status(pdata);
- printf("%icm\n\n", (pdata->RangeMilliMeter)/10);
- return status;
- VL53L0X_Error vl53l0x_measure_init(VL53L0X_Dev_t *pMyDevice)
- VL53L0X_Error Status = VL53L0X_ERROR_NONE;
- //FixPoint1616_t LimitCheckCurrent;
- uint32_t refSpadCount;
- uint8_t isApertureSpads;
- uint8_t VhvSettings;
- uint8_t PhaseCal;
- // Device Initialization
- Status = VL53L0X_StaticInit(pMyDevice); //基本设备初始化
- if(Status != VL53L0X_ERROR_NONE){ //判断是否初始化成功 失败打印错误信息
- printf ("Call of VL53L0X_StaticInit\n");
- print_pal_error(Status);
- return Status;
- Status = VL53L0X_PerformRefCalibration(pMyDevice, &VhvSettings, &PhaseCal); //执行参考校准
- if(Status != VL53L0X_ERROR_NONE){ //判断是否校准成功
- printf ("Call of VL53L0X_PerformRefCalibration\n");
- return Status;
- // needed if a coverglass is used and no calibration has been performed
- Status = VL53L0X_PerformRefSpadManagement(pMyDevice,&refSpadCount, &isApertureSpads);
- printf ("Call of VL53L0X_PerformRefSpadManagement\n");
- printf ("refSpadCount = %d, isApertureSpads = %d\n", refSpadCount, isApertureSpads);
- return Status;
- // no need to do this when we use VL53L0X_PerformSingleRangingMeasurement 当我们使用VL53L0X_PerformSingleRangingMeasurement不需要
- Status = VL53L0X_SetDeviceMode(pMyDevice, VL53L0X_DEVICEMODE_SINGLE_RANGING); // Setup in single ranging mode 设置单一测量模式
- printf ("Call of VL53L0X_SetDeviceMode\n");
- return Status;
- // Enable/Disable Sigma and Signal check
- if(Status == VL53L0X_ERROR_NONE){
- Status = VL53L0X_SetLimitCheckEnable(pMyDevice, //启用/禁用特定限制检查
- VL53L0X_CHECKENABLE_SIGMA_FINAL_RANGE, 1);
- VL53L0X_CHECKENABLE_SIGNAL_RATE_FINAL_RANGE, 1);
- Status = VL53L0X_SetLimitCheckValue(pMyDevice,
- (FixPoint1616_t)(0.25*65536));
- (FixPoint1616_t)(18*65536));
- Status = VL53L0X_SetMeasurementTimingBudgetMicroSeconds(pMyDevice, //设置微秒时间
- 200000);
- printf ("Sigma and Signal check error\n");
- return Status;
- * Step 4 : Test ranging mode
- /* for(i=0;i<10;i++){
- printf ("Call of VL53L0X_PerformSingleRangingMeasurement\n");
- Status = VL53L0X_PerformSingleRangingMeasurement(pMyDevice,
- &vl53l0x_data);
- print_range_status(&vl53l0x_data);
- VL53L0X_GetLimitCheckCurrent(pMyDevice,
- VL53L0X_CHECKENABLE_RANGE_IGNORE_THRESHOLD, &LimitCheckCurrent);
- printf("RANGE IGNORE THRESHOLD: %f\n\n", (float)LimitCheckCurrent/65536.0);
- if (Status != VL53L0X_ERROR_NONE) break;
- printf("Measured distance: %i\n\n", vl53l0x_data.RangeMilliMeter);
- return Status; //返回0
- VL53L0X_Error vl53l0x_init(void)
- VL53L0X_Error Status = VL53L0X_ERROR_NONE; //初始值赋值为0
- VL53L0X_Dev_t *pMyDevice = &vl53l0x_dev; //得到设备地址
- pMyDevice->I2cDevAddr = 0x52; //iic地址
- pMyDevice->comms_type = 1; //选择IIC还是SPI iic=1;SPI=0
- pMyDevice->comms_speed_khz = 400; //iic速率
- VL53L0X_i2c_init(); //IIC配置
- Status = VL53L0X_DataInit(pMyDevice); // Data initialization //VL53L0X_DataInit:一次设备的初始化,初始化成功返回0
- if(Status != VL53L0X_ERROR_NONE){ //判断如果状态不为0 打印错误信息
- return Status; // 返回错误值 可通过此值DEBUG查找错误位置
- Status = VL53L0X_GetDeviceInfo(pMyDevice, &vl53l0x_dev_info); //读取给定设备的设备信息
- return Status;
- printf("VL53L0X_GetDeviceInfo:\n");
- printf("Device Name : %s\n", vl53l0x_dev_info.Name); //设备名
- printf("Device Type : %s\n", vl53l0x_dev_info.Type); //产品类型VL53L0X = 1, VL53L1 = 2
vl53l0x_测距.rar
(639.98 KB, 下载次数: 483)
