从51单片机平台上修改而来的带字库LCD12864液晶的驱动程序,串行和并行都有,各个函数均带有注释。亲测可用,使用时注意修改宏定义里对管脚的定义以及引脚初始化程序
- #include <stm32f10x.h>
- #include "12864.h"
- #include "delay.h"
- void LCD12864_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
- delay_init();
- /*--------------------LCD基本指令-----------------------*/
- delay_ms(2);
- Write_LCD_Command(0x30); //30--基本指令动作
- delay_ms(2);
- Write_LCD_Command(0x0c); //光标右移画面不动
- delay_ms(2);
- Write_LCD_Command(0x01); //清屏
- delay_ms(5); //清屏时间较长
- Write_LCD_Command(0x06); //显示打开,光标开,反白关
- delay_ms(2);
- Draw_Clear(); // 清屏
- 函数名:Send_Byte()
- 返回值:无
- 功 能: 写数据到LCD
- void Send_Byte(u8 zdata)
- u16 i;
- for(i=0; i<8; i++)
- if((zdata << i) & 0x80)
- SID_H;
- else
- SID_L;
- SCLK_H;
- SCLK_L;
- 函数名:Receive_Byte()
- 返回值:temp1+temp2
- 功 能: 读LCD数据
- u8 Receive_Byte(void)
- u8 i,temp1,temp2,value;
- temp1=0;
- temp2=0;
- for(i=0;i<8;i++)
- temp1=temp1<<1;
- SCLK_L;
- SCLK_H;
- SCLK_L;
- if(PAout(7)==1)
- temp1++;
- for(i=0;i<8;i++)
- temp2=temp2<<1;
- SCLK_L;
- SCLK_H;
- SCLK_L;
- if(PAout(7)==1)
- temp2++;
- temp1=0xf0&temp1;
- temp2=0x0f&temp2;
- value=temp1+temp2;
- return value ;
- 函数名:Check_Busy()
- 返回值:无
- 功 能: LCD忙检查
- void Check_Busy(void)
- do
- Send_Byte(0xfc); //11111,RW(1),RS(0),0
- while(0x80&Receive_Byte());
- 函数名: Write_LCD_Command()
- 返回值:无
- 功 能: 写命令到LCD
- void Write_LCD_Command(u8 cmdcode)
- CS_H;
- Check_Busy();
- Send_Byte(0xf8);
- Send_Byte(cmdcode & 0xf0);
- Send_Byte((cmdcode << 4) & 0xf0);
- delay_ms(2);
- CS_L;
- 函数名: Write_LCD_Data()
- 返回值:无
- 功 能: 写显示内容到LCD
- void Write_LCD_Data(u8 Dispdata)
- CS_H;
- Check_Busy();
- Send_Byte(0xfa); //11111,RW(0),RS(1),0
- Send_Byte(Dispdata & 0xf0);
- Send_Byte((Dispdata << 4) & 0xf0);
- delay_ms(2);
- CS_L;
- 函数名: Read_LCD_Data()
- 返回值:LCD收到的数据
- 功 能: 读取LCD显示内容
- u8 Read_Data(void)
- Check_Busy();
- Send_Byte(0xfe); //11111,RW(1),RS(1),0 LCD->MCU
- return Receive_Byte();
- 函数名: LCD_Clear_Txt
- 返回值:无
- 功 能: 文本区清除
- void LCD_Clear_TXT( void )
- u8 i;
- Write_LCD_Command(0x30); //8BitMCU,基本指令集合
- Write_LCD_Command(0x80); //AC归起始位
- for(i=0;i<64;i++)
- Write_LCD_Data(0x20);
- 函数名: LCD_Clear_BMP
- 返回值:无
- 功 能: 图片区清除
- void LCD_Clear_BMP( void )
- u8 i,j;
- Write_LCD_Command(0x34); //8Bit扩充指令集,即使是36H也要写两次
- Write_LCD_Command(0x36); //绘图ON,基本指令集里面36H不能开绘图
- for(i=0;i<32;i++) //12864实际为256x32
- Write_LCD_Command(0x80|i); //行位置
- Write_LCD_Command(0x80); //列位置
- for(j=0;j<32;j++) //256/8=32 byte
- Write_LCD_Data(0);
- 函数名: Display_LCD_Pos
- 返回值:无
- 功 能:设置显示位置
- void Display_LCD_Pos(u8 x,u8 y)
- u8 pos;
- switch(x)
- case 0: x=0x80;break;
- case 1: x=0x90;break;
- case 2: x=0x88;break;
- case 3: x=0x98;break;
- pos=x+y;
- Write_LCD_Command(pos);
- 函数名:Display_LCD_String()
- 返回值:无
- 功 能:显示字符串
- void Display_LCD_String(u8 *s)
- while(*s != '\0')
- Write_LCD_Data(*s);
- s++;
- delay_ms(2); //控制每一个字符之间显示的时间 间隔
- * 函数名称 :PutBMP
- void PutBMP(const u8 *puts)
- u16 x=0;
- u8 i,j;
- for(j=0;j<16;j++) //256/8=32 byte
- { //列位置每行自动增加
- Write_LCD_Data(puts[x]);
- x++;
- Write_LCD_Command(0x88); //列位置
- { //列位置每行自动增加
- x++;
- void PHO_Display(const u8 *s)
- u8 COUNT3 = 0X02,COUNT1,COUNT2,LCD_X = 0X80,LCD_Y;
- for (;COUNT3 != 0;COUNT3 --)
- LCD_Y = 0X80;
- COUNT2 = 0X20;
- for(;COUNT2 != 0;COUNT2 --)
- //COUNT1 = 0X10;//全屏
- COUNT1 = 0X08;//半屏
- Write_LCD_Command(LCD_Y);
- Write_LCD_Command(LCD_X);
- for (;COUNT1 != 0;COUNT1 --)
- Write_LCD_Data(*s ++);
- LCD_Y += 1;
- LCD_X = 0X88;
- LCD显示缓存
- u16 LCD12864_Buffer[64][16] = {0};
- const u8 m_ch4x5[][6] =
- {0x06,0x09,0x09,0x09,0x06,5}, // 0,字符宽度5点阵
- {0x02,0x06,0x02,0x02,0x07,5}, // 1
- {0x06,0x09,0x02,0x04,0x0F,5}, // 2
- {0x06,0x09,0x02,0x09,0x06,5}, // 3
- {0x02,0x06,0x0A,0x0F,0x02,5}, // 4
- {0x0E,0x08,0x0E,0x01,0x0E,5}, // 5
- {0x06,0x08,0x0E,0x09,0x06,5}, // 6
- {0x0F,0x01,0x02,0x04,0x04,5}, // 7
- {0x06,0x09,0x06,0x09,0x06,5}, // 8
- {0x06,0x09,0x07,0x01,0x06,5}, // 9
- {0x00,0x00,0x00,0x00,0x01,2}, // .
- {0x00,0x01,0x00,0x01,0x00,2}, // :
- {0x00,0x00,0x00,0x00,0x00,5}, // 空格
- 功能:画点
- 参数:
- x:横坐标
- y:纵坐标
- color:颜色,0不显示,1显示
- const u16 DrawDotsTable[] = {0x8000, 0x4000, 0x2000, 0x1000, 0x0800, 0x0400, 0x0200, 0x0100, 0x0080, 0x0040, 0x0020, 0x0010, 0x0008, 0x0004, 0x0002, 0x0001};
- void Draw_Dots(u8 x, u8 y, u8 color)
- u8 i0, y0;
- u16 value;
- // 获得坐标
- if ( y >= 32 )
- y0 = y-32;
- i0 = x/16+8;
- else
- y0 = y;
- i0 = x/16;
- value = DrawDotsTable[x%16];
- if (color == 0)
- LCD12864_Buffer[y0][i0] &= ~value;
- else
- LCD12864_Buffer[y0][i0] |= value;
- 功能:刷新显示
- void Draw_Update(void)
- u8 x, y;
- for (y=0; y<64; y++)
- Write_LCD_Command(0x80|y);
- for (x=0; x<16; x++)
- Write_LCD_Data(LCD12864_Buffer[y][x]>>8);
- Write_LCD_Data(LCD12864_Buffer[y][x]);
- 功能:显示清屏
- void Draw_Clear(void)
- u8 x, y;
- LCD12864_Buffer[y][x] = 0;
- 功能:显示4*5字符
- 参数:
- x:写出横坐标
- y:写出纵坐标
- value:字符
- void Draw_Char4x5(u8 x, u8 y, u8 value)
- u8 i, j, p, z, a;
- a = m_ch4x5[value][5];
- for (i=0; i<5; i++)
- p = 0x10>>(5-a);
- for (j=0; j<a; j ++)
- z = m_ch4x5[value][i];
- if ( z & p )
- Draw_Dots(j+x, i+y, 1);
- p >>= 1;
- 功能:显示一行4*5字符
- 参数:
- x:写出横坐标
- y:写出纵坐标
- value:字符串
- len:长度
12864.rar
(6.83 KB, 下载次数: 367)
