查看: 2903|回复: 0
atmega16与24l01按键主程序
ID:241891 发表于 2017-10-22 18:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<avr/io.h>
#include<avr/delay.h>
#include"NRF24L01.h"
//#define Open_TX
#define Open_RX
typedef unsigned char  uint8;                   /* defined for unsigned 8-bits integer variable     无符号8位整型变量  */
typedef signed   char  int8;                    /* defined for signed 8-bits integer variable       有符号8位整型变量  */
typedef unsigned short uint16;                  /* defined for unsigned 16-bits integer variable    无符号16位整型变量 */
typedef signed   short int16;                   /* defined for signed 16-bits integer variable      有符号16位整型变量 */
typedef unsigned int   uint32;                  /* defined for unsigned 32-bits integer variable    无符号32位整型变量 */
typedef signed   int   int32;                   /* defined for signed 32-bits integer variable      有符号32位整型变量 */
typedef float          fp32;                    /* single precision floating point variable (32bits) 单精度浮点数(32位长度) */
typedef double         fp64;                    /* double precision floating point variable (64bits) 双精度浮点数(64位长度) */
extern uint8_t RX_BUF[];
extern uint8_t TX_BUF[];
void motorrun();
uint8 HandleKey();
uint8 KEY_Release;
uint32 i,MS1;
#define  KEY1_Press  ((keys & 0x03) == 3)
#define  KEY1_Pressed ((keys & 0x03) == 2)
#define  KEY1_Release ((keys & 0x03) == 1)
#define  KEY1_Released ((keys & 0x03) == 0)
int main(void)
//nRF24L01_Config();
//usartInit();
uint8 keys = 0;
nRF24L01_Initial();
      #ifdef Open_TX
   keys=HandleKey();
   if(KEY1_Release)
   TX_BUF[0]=0x55;
   NRF24L01_Send();
   if(TX_BUF[0]==0x55)
   for(i=1;i<100;i++)
    PORTB &=~ (1<<PB0);//LED
    _delay_ms(1000);
    PORTB |= (1<<PB0);//LED
    _delay_ms(1000);
   //printf("\r\nSend data:0x%x\r\n",TX_BUF[0]);
   _delay_ms(5000);
      #else
   PORTD &=~(1<<PD2);
   NRF24L01_Receive();
   _delay_ms(2000);
   if(RX_BUF[0]==0X55)
   motorrun();
   while(1);
   #endif
uint8 HandleKey(void)
static uint8 key1laststa = 1,pressure = 0;
uint8 ret = 0;
DDRB &= ~(1 << PB1);
if(PINB & (1 << PB1))  //KEY1
  ret = (ret & ~(0x03 << 0)) | (0x00 << 0);
  if(key1laststa == 0) //release
   ret = (ret & ~(0x03 << 0)) | (0x01 << 0);
  key1laststa = 1;
  ret = (ret & ~(0x03 << 0)) | (0x02 << 0);
  if(key1laststa == 1) //press
   ret = (ret & ~(0x03 << 0)) | (0x03 << 0);
  key1laststa = 0;
return ret;
void motorrun()
PORTD |=(1<<PD2);
PORTD &=~  (1<<PD3);
PORTD &=~  (1<<PD4);//EN1
PORTD &=~  (1<<PD5);//EN2
PORTC &=~(1<<PC1);//DIR
for(i=0;i<4000;i++)
  PORTC |= (1 << PC0);
  _delay_ms(20);
  PORTC &=~ (1 << PC0);
  _delay_ms(20);
