查看: 3105|回复: 6
1602制作计算器
ID:243612 发表于 2017-10-31 14:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有谁可以帮忙看下程序吗?就是程序无法做运算?
#include<reg52.h>
#include<stdio.h>
#define        uint unsigned int
sbit lcdrs=P2^6;
sbit lcdrw=P2^5;
sbit lcden=P2^7;
void delay(uint z)
      uint x,y;
          for(x=z;x>0;x--)
              for(y=110;y>0;y--);
void write_com(uchar com)
   lcdrs=0;
   lcden=0;
   P0=com;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void write_data(uchar date)
   lcdrs=1;
   lcden=0;
   P0=date;
   delay(5);
   lcden=1;
   delay(5);
   lcden=0;
void init()
   lcden=0;
   lcdrw=0;
   write_com(0x38);
   write_com(0x0c);
   write_com(0x06);
   write_com(0x01);
   write_com(0x30);
   write_com(0x80);
void write_char(uchar x,uchar y,uchar dat)
  if(y==0)
    write_com(0x80+x);
    write_com(0xc0+x);
  write_data( dat);
void write_string(uchar x,uchar y,uchar *s)
   if(y==0)
    write_com(0x80+x);
    write_com(0xc0+x);
  while(*s)
    write_data(*s);
        s++;
uchar keyscan()
  unsigned char cord_h,cord_l;
  P1=0x0f;
  cord_h=P1&0x0f;
   if(cord_h!=0x0f)
     delay(50);
         if((P1&0x0f)!=0x0f)
            cord_h=P1&0x0f;
                 P1=cord_h|0xf0;
                 cord_l=P1&0xf0;
                  while((P1&0xf0)!=0xf0);
                   return(cord_h+cord_l);
    return(0xff);
unsigned char keypro()
   switch(keyscan())
        case 0x77:return '+';break;
            case 0x7b:return '-';break;
                case 0x7d:return 'x';break;
                case 0x7e:return '/';break;
                case 0xbb:return '3';break;
                case 0xbd:return '6';break;
                case 0xbe:return '9';break;
                case 0xb7:return '=';break;
            case 0xdb:return '2';break;
            case 0xdd:return '5';break;
                case 0xde:return '8';break;
            case 0xd7:return '0';break;
                case 0xeb:return '1';break;
                case 0xed:return '4';break;
                case 0xee:return '7';break;
                case 0xe7:return '.';break;
                default:return 0xff;break;
    unsigned char i,num,sign;
        unsigned char temp[16];
        bit firstflag;
        float a=0,b=0;
        unsigned char s;
        init();
        delay(10);
        write_com(0x01);
          num=keypro();
          if(num!=0xff)
            if(i==0)
                write_com(0x01);
                if(('+'==num)||(i==16)||('-'==num)||('*'==num)||('='==num)||('/'==num))
                i=0;
                if(firstflag==0)
                   sscanf(temp,"%f",&a);
                   firstflag=1;
                   sscanf(temp,"%f",&b);
                        for(s=0;s<16;s++)
                        temp[s]=0;
                        write_char(0,1,num);
                        if(num!='=')
                        write_char(0,0,num);
                        sign=num;
                     firstflag=0;
                         switch(sign)
                           case '+':a=a+b;break;
                           case '-':a=a-b;break;
                           case '*':a=a*b;break;
                           case '/':a=a/b;break;
                           default:break;
                        sprintf(temp,"%f",a);
                        write_string(1,1,temp);
                        sign=0;a=b=0;
                        for(s=0;s<16;s++)
                        temp[s]=0;
                else if(i<16)
                  if((0==i)&&(temp[0]=0))
                    if(num=='0')
                          write_com(0x01);
                           temp[0]=num;
                           i++;
                    temp[i]=num;
                        write_char(i,0,num);
                        i++;
ID:244827 发表于 2017-11-1 09:32 | 只看该作者
好厉害
ID:244857 发表于 2017-11-1 10:32 来自手机 | 只看该作者
厉害了
ID:244874 发表于 2017-11-1 10:48 | 只看该作者
厉害了
ID:244874 发表于 2017-11-1 10:49 | 只看该作者
厉害啊,学习
ID:241249 发表于 2017-11-2 21:04 | 只看该作者
运行不起来么
ID:245732 发表于 2017-11-3 16:02 | 只看该作者
#include <reg51.h>
    sbit K1=P2^0;
    sbit K2=P2^1;
    sbit K3=P2^2;
    sbit K4=P2^3;
    sbit K5=P2^4;
        sbit K6=P2^5;
        sbit K7=P2^6;
        sbit K8=P2^7;
        sbit K9=P1^5;
        sbit K10=P1^6;
        sbit bell=P1^7;
        sbit RS = P1^0;
    sbit RW = P1^1;
    sbit E  = P1^2;
        void init();
        void wcom(unsigned char i);
    void wdata(unsigned char i);
    void ifnotbusy(void);
        unsigned char code music_H[]={0xfc,0xfc,0xfd,0xfd,0xfd,0xfd,0xfe,0xfe, 0xfa,0xfb,0xfb,0xfb,0xfa,    0xf9,0xfa,0xfb,   0xfb,0xfa,0xfb,0xfb,0xfa,0xf9,0xf9,0xfa,0xf9,0xfb,0xfa,0xfa,0xf9,0xf9,0xfb,0xf9,0xf9,0xfb,0xf9,    0xf9,0xf9,0xfa,    0xf9,0xf9,0xfa,    0xfb,0xfb,0xfb,0xfb,0xfb,0xf9,0xfa};
         unsigned char code music_L[]={0x8f,0xef,0x45,0x6c,0xb4,0xf4,0x2e,0x3d, 0x8c,0x68,0xe9,0x68,0xbc,    0xe1,0x8c,0x68,   0x68,0x8c,0x68,0x68,0x8c,0xe1,0x21,0x8c,0xe1,0x68,0xd8,0x8c,0x21,0xe1,0x68,0x21,0xe1,0x68,0x21,    0x21,0x21,0x8c,    0x21,0x21,0x8c,    0xe9,0xe9,0xe9,0xe9,0x68,0x21,0x8c};
         unsigned char code Time[]={500,500,500,500,500,500,500,500,500,500,500,500,500,250,250,500,500,800,500,500,500,500,250,250,500,500,800,500,500,1000,500,500,1000,500,500,500,500,500,500,500,500,500,500,500,500,500};
         int i;
         void fy();
         void delay( int k);
        main()
    TMOD=0x01; //选择方式1
    TH0=music_H[i]; //        高八位
    TL0=music_L[i]; //低八位
    //TR0=1;   //启动计时
         while(1){
           if(K1==0)
           {delay(10);
              if(K1==0)
                      i=0;
                      fy();
                          init();
                           wcom(0x80);
                           wdata(0x31);
           if(K2==0)
           {delay(10);
              if(K2==0)
                     i=1;
                         fy();
                         init();
                         wcom(0x80);
                           wdata(0x32);
                  if(K3==0)
           {delay(10);
              if(K3==0)
                             i=2;
                         fy();
                         init();
                         wcom(0x80);
                           wdata(0x33);
                 if(K4==0)
           {delay(10);
              if(K4==0)
                  {             i=3;
                         fy();
                         init();
                         wcom(0x80);
                           wdata(0x34);
                  if(K5==0)
           {delay(10);
              if(K5==0)
                  {             i=4;
                         fy();
                         init();
                         wcom(0x80);
                           wdata(0x35);
                  if(K6==0)
           {delay(10);
              if(K6==0)
                  {             i=5;
                         fy();
                         init();
                                  wcom(0x80);
                           wdata(0x36);
                            if(K7==0)
           {delay(10);
              if(K7==0)
                  {               i=6;
                         fy();
                         init();
                         wcom(0x80);
                           wdata(0x37);
                   if(K8==0)
           {delay(10);
              if(K8==0)
                  {               i=7;
                         fy();
                         init();
                         wcom(0x80);
                           wdata(0x38);
                  if(K9==0)
           {delay(10);
              if(K9==0)
                  {           i=8;
                           wcom(0x80);
                           wdata('l');
                           wcom(0x81);
                           wdata('z');
                           wcom(0x82);
                           wdata('l');
                           wcom(0x83);
                           wdata('h');
                     fy();
                          i++;
                           if(i>=25)
                          break;
                             if(K10==0)
           {delay(10);
              if(K10==0)
                  {           i=40;
                           wcom(0x80);
                           wdata('h');
                           wcom(0x81);
                           wdata('l');
                           wcom(0x82);
                           wdata('w');
                     fy();
                          i++;
                           if(i>=53)
                          break;
  void fy()
  {        int j=0;
    TR0=1;
    while(j<Time[i])         //Time[i]music_Time[i]
   { if(TF0==1)         //定时/计数器溢出标志位 TF0=1 表示溢出
           { TF0=0;
             TH0=music_H[i];
                 TL0=music_L[i];
                 bell=!bell;
                 j++;
           TR0=0;
  void delay(int k)
    int b,d;
         for (d=0;d<k;d++)
    for(b=0;b<250;b++);
  void init()
    wcom(0x01);
    wcom(0x38);
    wcom(0x06);
    wcom(0x0c);
  void ifnotbusy()
{ P0=0xff;
RS=0;
RW=1;
E=0;
E=1;
while(P0&0x80)
E=0;E=1;
void wcom(unsigned char j)
{ifnotbusy();
E=0;
RS=0;
RW=0;
P0=j;
E=1;
E=0;
void wdata(unsigned char j)
{ifnotbusy();
E=0;
RS=1;
RW=0;
P0=j;
E=1;
E=0;
