查看: 2580|回复: 0
MCP73871引脚图电路图与pdf数据手册下载
Description
The MCP73871 device is a fully integrated linearsolution for system load sharing and Li-Ion / Li-Polymerbattery charge management  with ac-dc wall adapter
and USB port power sources selection. It’s alsocapable of autonomous power source selection
between input or battery. Along with its small physicalsize, the low number of required external components makes the device ideally suited for portable
applications.
The MCP73871 device automatically obtains power for the system load from a single-cell Li-Ion battery or an input power source (ac-dc wall adapter or USB port).
The MCP73871 device specifically adheres to the current drawn limits governed by the USB specification. With an ac-dc wall adapter providing power to the system, an external resistor sets the magnitude of 1A maximum charge current while supports up to 1.8A total current for system load and battery charge current.
MCP73871引脚图与管脚定义
MCP73871应用电路图如下:
完整的pdf格式芯片数据手册文档51黑下载地址:
MCP73871.pdf (638.37 KB, 下载次数: 30)
