查看: 2700|回复: 0
蜂鸣器播放音乐
ID:240013 发表于 2017-11-24 15:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <at89x52.h>
bit flag; //标志音乐输出脚电平的高低
uchar ptr = 0x00; //取音符
uchar high; //计数器高位
uchar low; //计数器低位
// 本曲谱为 "新年好",前两个十六进制表示发声频率,后一个表示发声时间,0xFF,0xFF 表示休止符
// 0x00 表示结束
// 1 _ 1_ 1 .5
uchar code music[] = {
0xFC,0x44,0x7F, 0xFC,0x44,0x7F, 0xFC,0x44,0xFF, 0xFA,0x68,0xFF,
// 3 _ 3_ 3 1
0xFD,0x23,0x7F, 0xFD,0x23,0x7F, 0xFD,0x23,0xFF, 0xFC,0x44,0xFF,
// 1_ 3_ 5 5
0xFC,0x44,0x7F, 0xFD,0x23,0x7F, 0xFD,0x82,0xFF, 0xFD,0x82,0xFF,
// 4_ 3_ 2 -
0xFD,0x23,0x7F, 0xFD,0x23,0x7F, 0xFC,0xAC,0xFF, 0xFF,0xFF,0xFF,
// 2_ 3_ 4 4
0xFC,0xAC,0x7F, 0xFD,0x23,0x7F, 0xFD,0x34,0xFF, 0xFD,0x34,0xFF,
// 3_ 2_ 3 1
0xFD,0x23,0x7F, 0xFC,0xAC,0x7F, 0xFD,0x23,0xFF, 0xFC,0x44,0xFF,
// 1_ 3_ 2 .5
0xFC,0x44,0x7F, 0xFD,0x23,0x7F, 0xFC,0xAC,0xFF, 0xFA,0x68,0xFF,
// .7_ 2_ 1 -
0xFC,0x0C,0x7F, 0xFC,0xAC,0x7F, 0xFC,0x44,0xFF, 0xFF,0xFF,0xFF,
0x00//结束
void Init(void); //初始化函数
void DelayMs(unsigned int time); //毫秒级延时函数
        uchar time;
        Init();
        TH0 = high;
        TL0 = low;
        while (1)
                if (music[ptr] != 0xFF && music[ptr] != 0x00)//判断是否是正常音符
                        TR0 = 0;
                        P2_3 = 1;
                        DelayMs(10); //间歇
                        TR0 = 1;
                        high = music[ptr]; //取设置频率数值的高8 位
                        low = music[ptr + 1]; //取设置频率数值的低8 位
                        time = music[ptr + 2]; //取发声时间
                        DelayMs(time);
                        ptr += 3;
                else if (music[ptr] == 0xFF) //判断是否是休止符
                        DelayMs(time);
                        ptr += 3;
                else //结束符,停止2 秒后继续
                        TR0 = 0;
                        P2_3 = 1;
                        DelayMs(2000);
                        ptr = 0;
* 名称:Count1(void) interrupt 1
* 功能:设置计时器0 溢出中断,每中断一次改变P2_3 引脚电平
void Count1(void) interrupt 1
        TH0 = high;
        TL0 = low;
        if (flag == 0) //改变P2_3 引脚电平
                P2_3 = 0;
                flag = 1;
                P2_3 = 1;
                flag = 0;
* 名称:Init()
* 功能:设置计数器0 工作方式,16 位计数,溢出中断方式
void Init()
        TMOD = 0x01; //定时器0 处于计时方式,16 位
        EA = 1;
        ET0 = 1; //定时器0 溢出中断
* 名称:DelayMs(unsigned int time)
* 功能:延时time * 1ms 时间
        unsigned int i;
        unsigned int j;
        for (j =0; j < time; j++) //每个循环 约 3ms
                for (i =0; i < 363; i++)
