查看: 2635|回复: 2
新唐单片机N76E003在115200波特率有乱码解决方法
ID:518421 发表于 2019-4-22 11:12 | 显示全部楼层 |阅读模式
    N76E003为高性价比单片机,碰到115200波特率不准导致有乱码问题。在初始化时候执行以下void MODIFY_HIRC_VLAUE(void),测试可以完美解决此问题。见附件!
    set_IAPEN;
    IAPAL = 0x30;
    IAPAH = 0x00;
    IAPCN = READ_UID;
    set_IAPGO;
    hircmap0 = IAPFD;
    IAPAL = 0x31;
    IAPAH = 0x00;
    set_IAPGO;
    hircmap1 = IAPFD;
    clr_IAPEN;
    trimvalue16bit = ((hircmap0<<1)+(hircmap1&0x01));
    trimvalue16bit = trimvalue16bit - 15;
    hircmap1 = trimvalue16bit&0x01;
    hircmap0 = trimvalue16bit>>1;
    TA=0XAA;
    TA=0X55;
    RCTRIM0 = hircmap0;
    TA=0XAA;
    TA=0X55;
    RCTRIM1 = hircmap1;
ID:103401 发表于 2019-11-1 10:48 | 显示全部楼层
支持一下新唐
