查看: 7700|回复: 3
单片机+pt100测温度Proteus仿真程序
#include <reg52.h>
#include <string.h>
#include <math.h>
#include "intrins.h"
#define ROW1 0x80
#define ROW2 0xC0
#define Ts_CONST 1                //AD采样时间系数,采样时间为0.1xTs_CONST(s)
#define NOACT 0
#define FC 1
#define Start_AD 2
#define Cal_Temperature 3
#define Kpt 0.02732644         //AD芯片max1240的采样值到温度值的转化系数
void LCD_Init(void);
void ClearDisp(unsigned char Row);
void Display(unsigned char Addr, unsigned char *pstr);
void DecToASC(unsigned int Dec,unsigned char *p, unsigned char n);
void Disp_Initize(void);
void Write_CMD(unsigned char CMD);
unsigned int AD_MAX1240(void);
sbit RS=P2^2;
sbit RW=P2^1;
sbit E=P2^0;
sbit SDA=P1^5;
sbit SCL=P1^6;
sbit CS=P1^7;
sbit Key=P3^5;
sbit up=P3^6;
sbit down=P3^7;
unsigned char DispBuf[16];
unsigned char RunState=NOACT;
unsigned int AD_Reslut,tsflag,ts=1;
float  fz,tmp,tmp1,Pt;
void delay(unsigned int j)//延时jms
    unsigned int m,n;
    for(n=0;n<j;n++)
       for(m=0;m<120;m++);
void main(void)
{        LCD_Init();
        ClearDisp(ROW1);
        Disp_Initize();
        CS=1;
        SDA=1;
        SCL=0;
        TMOD=0x11;
        TF0=0;                //开始程序前先延时65ms,等待max1240上电,以保证AD采样准确
        TH0=0;
        TL0=0;
        TR0=1;
        while(!TF0);
        TF0=0;
        TR0=0;
        TH0=0x3C;                //12M晶振时延时50ms
        TL0=0xB0;
        ET0=1;
        TR0=1;
        EX1=1;
        IT1=1;
        EA=1;
                switch(RunState)
                {        case NOACT:
                                break;
                        case FC:        //F0计算及显示
                                fz=pow(10,(tmp-121.0000)/10);
                                DecToASC(fz,DispBuf,1);
                                DispBuf[1]='.';
                                DecToASC((fz-(unsigned int)fz)*1000,DispBuf+2,3);
                                DispBuf[5]='\0';
                                Display(0x80+11,DispBuf);
                                RunState=NOACT;
                                break;
                        case Start_AD:                          //开始AD采样
                                AD_Reslut=AD_MAX1240();
                                RunState=Cal_Temperature;
                                break;
                        case Cal_Temperature:                                     //将AD值转化为温度并进行线性化
                                Pt=AD_Reslut*Kpt;
                                Pt+=100;          //温度值
                                tmp=Pt/100;
                                tmp=1-tmp;
                                tmp=2.31e-6L*tmp;
                                tmp+=1.527480889e-5L;
                                tmp=sqrt(tmp);
                                tmp+=-3.9083e-3L;
                                tmp/=-1.155e-6L;//AD采样值线性化修正
                                tmp1=tmp;
                                tmp=(tmp+tmp1)/2;//取平均温度
                                tmp=((float)((unsigned int)(tmp*10)))/10 ;
                                DecToASC(tmp,DispBuf,3);
                                DispBuf[3]='.';
                                DecToASC((tmp-(unsigned int)tmp)*10,DispBuf+4,1);
                                DispBuf[5]='\0';
                                Display(0xC0+2,DispBuf); //显示函数
                                RunState=NOACT;
                                break;
unsigned int AD_MAX1240(void)        //读取AD,AD芯片为串口数据形式
{        unsigned int adtmp=0;
        unsigned char i;
        CS=0;
        while(!SDA);
        SCL=1;
        adtmp<<=1;
        SCL=0;
        for(i=0;i<12;i++)
        {        SCL=1;
                adtmp<<=1;
                if(SDA==1)adtmp++;
                SCL=0;
        CS=1;
        return adtmp;
void Disp_Initize(void)                                //LCD初始化,将Ts,F0,t等提示字符显示在屏幕上
{        //unsigned char *p;
        DispBuf[0]='T';
        DispBuf[1]='s';
        DispBuf[2]='=';
        DecToASC(ts,DispBuf+3,2);
        DispBuf[5]='s';
        DispBuf[8]='f' ;
        DispBuf[9]='0'        ;
        DispBuf[10]='='        ;
        DispBuf[16]='\0';
        Display(0x80,DispBuf);
        DispBuf[0]='t';
        DispBuf[1]='=';
        DispBuf[2]='\0';
        Display(0xc0,DispBuf);
void INT1_ISR(void) interrupt 2                          //切换采样时间的中断函数,用于开关量识别和改变Ts(采样时间)
        EA=0;
        TR0=0;
        ET0=0;
        strcpy(DispBuf,"     ");
                if(up==0)
                        delay(100);
                        if(up==0)
                        ts++;
                if(down==0)
                {   delay(100);
                        if(down==0)
                        ts--;
                if(ts>60)
                ts=1;
                if(ts<=0)
                ts=60;
                DecToASC(ts,DispBuf,2);
                DispBuf[2]='s';
                DispBuf[3]='\0';
                Display(0x80+3,DispBuf);
                if(Key==0)
                break;
        EA=1;
        TR0=1;
        ET0=1;
void T0_ISR(void) interrupt 1         //定时中断程序
{        static unsigned char T0_CNT=Ts_CONST;
        //static bit Flag=0;
        TH0=0x3C;
        TL0=0xB0;
        //Flag=!Flag;
        //if(Flag)return;
        T0_CNT--;
        tsflag++;
        if(!T0_CNT)
        {        T0_CNT=Ts_CONST;
                RunState=Start_AD; //AD采样
        if(tsflag>=ts*20)
                tsflag=0;
                RunState =FC;           //Ts到时进行F0值运算
void DecToASC(unsigned int Dec,unsigned char *p, unsigned char n)        //将Dec变量编程可以在1602上直接显示的ASICII值
{        unsigned char i;
        p+=n;
        p--;
        for(i=0;i<n;i++)
        {        *p=Dec%10+0x30;
                p--;
                Dec/=10;
/*LCD显示*******************************************************************************/
void Check_Busy(void)
{//        return;
        do
        {        P0=0xFF;
                E=0;
                RS=0;
                RW=1;
                E=1;
                _nop_();
        }while(P0&0x80);
        E=0;
        Check_Busy();
        E=0;
        RS=0;
        RW=0;
        P0=CMD;
        E=1;
        _nop_();
        E=0;
void Write_Data(unsigned char Data)
        Check_Busy();
        E=0;
        RS=1;
        RW=0;
        P0=Data;
        E=1;
        _nop_();
        E=0;
void LCD_Init(void)
        Write_CMD(0x38);
        Write_CMD(0x0C);
        Write_CMD(0x06);
        Write_CMD(0x01);  //清屏
        Write_CMD(Addr);
        while(*pstr)
                Write_Data(*pstr++);
        Display(Row,DispBuf);
全部资料51hei下载地址:
Pt100.rar (769.19 KB, 下载次数: 213)
收藏收藏8 分享淘帖 顶2 踩
ID:720208 发表于 2020-4-1 14:53 | 只看该作者
你好
ID:304785 发表于 2020-6-13 22:06 | 只看该作者
pt100显示117,液晶到200多了?
ID:773058 发表于 2020-7-4 10:21 | 只看该作者
楼主你好,tmp=2.31e-6L*tmp,这里边的L是什么含义
