uid:62214 日志
Lcd clock
已有 1013 次阅读2014-5-29 06:47
#include<reg51.h>
sbit lcden=P2^7;
sbit rs=P2^6;
sbit rw=P2^5;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^3;
  uchar count,shi,fen,miao,s1num;
 uchar code table[]="  2014-3-21 FRI";
uchar code table1[]="   00:00:00";
void delay(uint z)
   uint x,y;
   for (x=z;x>0;x--)
    for (y=110;y>0;y--);
void write_com(uchar com)
lcden=0;
rs=0;
rw=0;
P0=com;
delay(5);
lcden=1;
void write_date(uchar date)
lcden=0;
rs=1;
rw=0;
P0=date;
delay(5);
lcden=1;
void init()
uchar num;
lcden=0;
  write_com(0x38);
//   delay(5);
   write_com(0x0c);
   write_com(0x06); //光标
   write_com(0x01);//清0;
   write_com(0x80);//址址,第一行开始
  for(num=0;num<15;num++)
    write_date(table[num]);
    delay(20);  //20ms
  write_com(0x80+0x3f);
  for(num=0;num<11;num++)
     write_date(table1[num]);
    delay(20);
     TMOD=0x01;// 定时器0的方式1;
    TH0=(65536-50000)/256;
    TL0=(65536-50000)%256;  //初值
    EA=1;//开定时器0的中断;
    ET0=1; //开定时器0;
    TR0=1;//启动
    void write_sfm(uchar add,uchar date)
 uchar shi,ge;
 shi=date/10;
 ge=date%10;
 write_com(0x80+0x3f+add);
 write_date(0x30+shi);
 write_date(0x30+ge);
  void keyscan()
      rd=0;
   delay(5);
   if(s1==0)
   delay(5);
   if(s1==0)
    s1num++;
   while(!s1);    //待松手
      if(s1num==1)
   TR0=0;//时间停
   write_com(0x80+0x40+11);   //秒位
   write_com(0x0f)  ;      //显示光标,闪
    if(s1num==2)
 write_com(0x80+0x40+8);//分
     if(s1num==3)
  write_com(0x80+0x40+5);//小时
     if(s1num==4)
  s1num=0;
  write_com(0x0c);//光标不闪
  TR0=1;//继续走时
       if(s1num!=0)
       if(s2==0)
    delay(5);
    if(s2==0)
     if(s1num==1)
     miao++;
     if(miao==60)
     miao=0;
     write_com(0x80+0x40+9);//显示更新
     write_sfm(9,miao);
   if(s1num==2)
   if(s1num==3)
     //确定光标在哪个位置
  init(); //初始化
       keyscan();
          if(count==20)
       count=0;
          miao++;
        if(miao==60)
          miao=0;
          fen++;
             if(fen==60)
             fen=0;
             shi++;
                if(shi==24)
                   shi=0;
           write_sfm(4,shi); }
          write_sfm(7,fen);}
                    write_sfm(10,miao);
//  while(1);//停此
  void timer0()   interrupt 1  // 定时器0的中断序号
  count++;
路过
鸡蛋
鲜花
握手
雷人
评论 (0 个评论)
返回顶部
