查看: 2532|回复: 0
红外感应的一个模块,程序有问题,进来找错
ID:237942 发表于 2017-12-1 15:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
unsigned char table[]={0x23,0x03,0x04,0x00,0x00,0x00,0x03,0x23};
unsigned char array[]={0x23,0x04,0x00,0x23};
sbit s=P1^0;
void InitUART(void)
    TMOD = 0x20;
    SCON = 0x50;
    TH1 = 0xFD;
    TL1 = TH1;
    PCON = 0x00;
    EA = 1;
    ES = 1;
    TR1 = 1;
void delay(unsigned int i)
unsigned char j;
for(i; i > 0; i--)
for(j = 255; j > 0; j--);
void send_com(unsigned char arry[],unsigned char j)    //串口数据发送函数
          unsigned char i;
                for(i=0;i<j;i++)
               SBUF = arry[i];
               while(!TI);
         TI = 0;
    InitUART();
        if(s==0)
     delay(100);
   if(s==0)
   send_com(table,4);
   if(s==1)
    delay(50);
   if(s==1)
  send_com(array,8);
void UARTInterrupt(void) interrupt 4
    if(RI)
        RI = 0;
        //add your code here!
        TI = 0;
程序烧写到板子上,没办法正常发送数据,程序的问题么?
