查看: 4617|回复: 2
OLED简易万年历单片机源程序
简易万年历在德飞莱开发板上
  1. #include <REGX52.H>
  2. #include "type.H"
  3. #include "OLEDDrive.H"
  4. #include"DS1302.h"
  5. #define FunKeyVal 1//按下功能键
  6. #define AddKeyVal 2//按下增加键
  7. #define SubKeyVal 3//按下减少键
  8. #define EscKeyVal 4//退出键
  9. //当前选中的时那个位置编号
  10. #define IDMax       9
  11. #define SelectYear  1
  12. #define SelectMonth 2
  13. #define SelectDate  3
  14. #define SelectDay   4
  15. #define SelectHour  5
  16. #define SelectMin   6
  17. #define SelectSec   7
  18. #define SelectClockHour 8
  19. #define SelectClockMin  9
  20. #define DIRUP  1
  21. #define DIRDOW 2
  22. extern uint16 ReadTemp(uint8 mode);
  23. uint8 buf[5];//显示缓存
  24. uint8 SelectState[]={0x00,0xff};
  25. bit ReadTemperatureFlag=0;//温度读取标志位
  26. uint16 Temperature;//DS18B20读取的16位温度数据
  27. code uint8 DecimalNum[16]={'0','1','1','2','3','3','4',
  28. '4','5','6','6','7','8','8','9','9'};//DS18B20读取的16bit数据最低4位对应的小数4舍5入取一位
  29. sfr IAP_CONTR = 0XE7;//特殊功能寄存器
  30. uint8 ClockHour=0;
  31. uint8 ClockMin=0;
  32. bit ClockFlag=0;
  33. sbit BEEP=P3^7;
  34. uint8 ID=0;//功能切换
  35. code uint8 weekstr[8][3]={
  36. "   ","Mon","Tue","Wed","Thu","Fri","Sat","Sun"};
  37. uint8 code Mon2[2][13]={0,31,28,31,30,31,30,31,31,30,31,30,31,
  38.                                   0,31,29,31,30,31,30,31,31,30,31,30,31};
  39. uint8 code TempIco[]={
  40. /*--  调入了一幅图像:这是您新建的图像  --*/
  41. /*--  宽度x高度=8x16  --*/
  42. 0x00,0x00,0xFC,0x02,0xAA,0xFC,0x00,0x00,0x08,0x1C,0x3F,0x7E,0x7E,0x3F,0x1C,0x08,
  43. };
  44. uint8 code BEEPIco[]=
  45. {/*--  调入了一幅图像:C:\Users\wise\Desktop\喇叭.bmp  --*/
  46. /*--  宽度x高度=16x16  --*/
  47. 0xF0,0x10,0x10,0xF0,0x18,0x0C,0x06,0x03,0xFF,0xFF,0xB0,0x98,0x8C,0x86,0x83,0x81,
  48. 0x0F,0x08,0x08,0x0F,0x08,0x30,0x20,0xC0,0xFF,0xFF,0x0D,0x19,0x31,0x61,0xC1,0x81};
  49. //温度单位符号℃
  50. uint8 code TempUint[]={
  51. /*--  调入了一幅图像:这是您新建的图像  --*/
  52. /*--  宽度x高度=6x8  --*/
  53. 0x02,0x05,0x72,0x88,0x88,0x00,
  54. };
  55. void UARTInit()
  56. {
  57.     SCON = 0x50;           //设定串口工作方式
  58.     PCON = 0x00;           //波特率不倍增
  59.     TMOD = 0x20;           //定时器1工作于8位自动重载模式, 用于产生波特率
  60.     EA = 1;
  61.     ES = 1;              //允许串口中断
  62.     TL1 = 0xfd;
  63.     TH1 = 0xfd;             //波特率9600
  64.     TR1 = 1;
  65. }
  66. /**************************************************
  67. 将2位十进制数转为字符
  68. **************************************************/
  69. void Dec2ToStr(uint8 dec,uint8 *str)
  70. {
  71.     *str++=dec/10+0x30;
  72.     *str=dec%10+0x30;
  73. }
  74. /**************************************************
  75. 闰年判断2000-2099年能被4整除就时闰年
  76. **************************************************/
  77. uint8 IsLeapYear(uint8 year)
  78. {
  79.     if((year%4)==0)
  80.     {
  81.         return 1;
  82.     }
  83.     return 0;
  84. }
  85. /**************************************************
  86. 显示年信息
  87. **************************************************/
  88. void ShowYear(void)
  89. {
  90.     GUIShowString(2*6,0,"20",2,SelectState[SelectYear==ID]);
  91.     Dec2ToStr(time.year,buf);
  92.     GUIShowString(4*6,0,buf,2,SelectState[SelectYear==ID]);
  93.     GUIShowString(6*6,0,"-",1,0);
  94. }
  95. /**************************************************
  96. 显示月信息
  97. **************************************************/
  98. void ShowMonth(void)
  99. {
  100.     Dec2ToStr(time.month,buf);
  101.     GUIShowString(7*6,0,buf,2,SelectState[SelectMonth==ID]);
  102.     GUIShowString(9*6,0,"-",1,0);
  103. }
  104. /**************************************************
  105. 显示日期信息
  106. **************************************************/
  107. void ShowDate(void)
  108. {
  109.     Dec2ToStr(time.date,buf);
  110.     GUIShowString(10*6,0,buf,2,SelectState[SelectDate==ID]);
  111. }
  112. /**************************************************
  113. 显示星期信息
  114. **************************************************/
  115. void ShowDay(void)
  116. {
  117.     GUIShowString(17*6,0,weekstr[time.day],3,SelectState[SelectDay==ID]);
  118. }
  119. /**************************************************
  120. 显示小时信息
  121. **************************************************/
  122. void ShowHour(void)
  123. {
  124.     GUIShowChar15X24(0,2,time.hour/10,SelectState[SelectHour==ID]);
  125.     GUIShowChar15X24(1*15,2,time.hour%10,SelectState[SelectHour==ID]);
  126.     GUIShowChar15X24(2*15,2,10,0);
  127. }
  128. /**************************************************
  129. 显示分信息
  130. **************************************************/
  131. void ShowMin(void)
  132. {
  133.     GUIShowChar15X24(3*15,2,time.min/10,SelectState[SelectMin==ID]);
  134.     GUIShowChar15X24(4*15,2,time.min%10,SelectState[SelectMin==ID]);
  135.     GUIShowChar15X24(5*15,2,10,0);
  136. }
  137. /**************************************************
  138. 显示秒信息
  139. **************************************************/
  140. void ShowSec(void)
  141. {
  142.     GUIShowChar15X24(6*15,2,time.sec/10,SelectState[SelectSec==ID]);
  143.     GUIShowChar15X24(7*15,2,time.sec%10,SelectState[SelectSec==ID]);
  144. }
  145. /**************************************************
  146. 显示闹铃时
  147. **************************************************/
  148. void ShowClockHour(void)
  149. {
  150.     Dec2ToStr(ClockHour,buf);
  151.     GUIShowString(11*6,7,buf,2,SelectState[SelectClockHour==ID]);
  152.     GUIShowString(13*6,7,":",1,0);
  153. }
  154. /**************************************************
  155. 显示闹铃分
  156. **************************************************/
  157. void ShowClockMin(void)
  158. {
  159.     Dec2ToStr(ClockMin,buf);
  160.     GUIShowString(14*6,7,buf,2,SelectState[SelectClockMin==ID]);
  161. }
  162. void Dec1ToStr1(uint8 dec,uint8 *str)
  163. {
  164.         str[0]=' ';
  165.         str[1]=' ';
  166.         str[2]=dec+0x30;
  167. }
  168. void Dec2ToStr1(uint8 dec,uint8 *str)
  169. {
  170.         str[0]=' ';
  171.         str[1]=dec/10+0x30;
  172.         str[2]=dec%10+0x30;
  173. }
  174. void Dec3ToStr1(uint8 dec,uint8 *str)
  175. {
  176.         str[0]=dec/100+0x30;
  177.         str[1]=dec%100/10+0x30;
  178.         str[2]=dec%10+0x30;
  179. }
  180. /**************************************************
  181. 显示温度信息
  182. **************************************************/
  183. void ShowTemperature(uint16 temperature,uint8* str)
  184. {
  185.     str[3]='.';
  186.         if(temperature&0x8000)//负温度
  187.         {
  188.                 temperature=~temperature+1;
  189.                 str[4]=DecimalNum[temperature&0x0f];//计算小数部分
  190.                 temperature=temperature>>4;
  191.                 if(temperature>9)//负温度的时候最多只有2位整数部分
  192.                 {
  193.                         Dec3ToStr1(temperature,str);
  194.                         str[0]='-';
  195.                 }
  196.                 else
  197.                 {
  198.                         Dec2ToStr1(temperature,str);
  199.                         str[1]='-';
  200.                 }
  201.         }
  202.         else
  203.         {
  204.                 str[4]=DecimalNum[temperature&0x0f];//计算小数部分
  205.                 temperature=temperature>>4;
  206.                 if(temperature>99)
  207.                 {
  208.                         Dec3ToStr1(temperature,str);
  209.                 }
  210.                 else if(temperature>9)
  211.                 {
  212.                         Dec2ToStr1(temperature,str);
  213.                 }
  214.                 else
  215.                 {
  216.                         Dec1ToStr1(temperature,str);
  217.                 }
  218.         }
  219.         GUIShowString(8,7,str,5,0);
  220. }
  221. /**************************************************
  222. 显示时间信息
  223. **************************************************/
  224. void ShowTime(void)
  225. {
  226.     ShowYear();//显示时间
  227.     ShowMonth();
  228.
  229. ……………………
  230. …………限于本文篇幅 余下代码请从51黑下载附件…………
B1.程序.zip (102.25 KB, 下载次数: 74)
收藏收藏3 分享淘帖 顶顶 踩踩
ID:243748 发表于 2017-12-28 12:58 来自触屏版 | 只看该作者
学习一下
ID:362103 发表于 2018-6-30 06:47 | 只看该作者
学习一下
