查看: 4955|回复: 0
51单片机实现拨号效果
ID:223281 发表于 2017-12-5 17:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51单片机实现拨号效果
  1. #include "stc15.h"
  2. #include "intrins.h"
  3. #include "gpio.h"
  4. #include "595hc.h"
  5. #define MAIN_Fosc  11059200L   //定义主时钟
  6. u16 counter = 0;
  7. u8 i,j,k;
  8. //      Y     P04      P05      P06      P07
  9. //            |        |        |        |
  10. //  X         |        |        |        |
  11. //  P00 ---- K00 ---- K01 ---- K02 ---- K03 ----
  12. //            |        |        |        |
  13. //  P01 ---- K04 ---- K05 ---- K06 ---- K07 ----
  14. //            |        |        |        |
  15. //  P02 ---- K08 ---- K09 ---- K10 ---- K11 ----
  16. //            |        |        |        |
  17. //  P03 ---- K12 ---- K13 ---- K14 ---- K15 ----
  18. //            |        |        |        |
  19. u8  KeyCode = 0;    //给用户使用的键码, 1~16有效
  20. u8  IO_KeyState = 0, IO_KeyState1 = 0, IO_KeyHoldCnt = 0;    //行列键盘变量
  21. static unsigned int get_flag = 0;
  22. u8 next_flag = 0;
  23. u8 Buf[] = {17,17,17,17,17,17,17,17};
  24. void IO_KeyDelay(void)
  25. {
  26.         u8 i = 60;
  27.         while (--i);
  28. }
  29. void IO_KeyScan(void)    //50ms call
  30. {
  31.         u8  j = IO_KeyState1;   //保存上一次状态
  32.         P0 = 0xf0;  //X低,读Y
  33.         IO_KeyDelay();
  34.         IO_KeyState1 = P0 & 0xf0;
  35.         P0 = 0x0f;  //Y低,读X
  36.         IO_KeyDelay();
  37.         IO_KeyState1 |= (P0 & 0x0f);
  38.         IO_KeyState1 ^= 0xff;   //取反
  39.         if (j == IO_KeyState1)   //连续两次读相等
  40.         {
  41.                 j = IO_KeyState;
  42.                 IO_KeyState = IO_KeyState1;
  43.                 if (IO_KeyState != 0)    //有键按下
  44.                 {
  45.                         F0 = 0;
  46.
  47.                         if (j == 0)  F0 = 1; //第一次按下
  48.                         else if (j == IO_KeyState)
  49.                         {
  50.                                 if (++IO_KeyHoldCnt >= 20)   //1秒后重键
  51.                                 {
  52.                                         IO_KeyHoldCnt = 18;
  53.                                         F0 = 1;
  54.                                 }
  55.                         }
  56.                         if (F0)
  57.                         {
  58.                                 next_flag = 1;
  59.                                 switch(IO_KeyState)
  60.                                 {
  61.                                         case 0x11: get_flag = 0;break;
  62.                                         case 0x12: get_flag = 1;break;
  63.                                         case 0x14: get_flag = 2;break;
  64.                                         case 0x18: get_flag = 3;break;
  65.                                         case 0x21: get_flag = 4;break;
  66.                                         case 0x22: get_flag = 5;break;
  67.                                         case 0x24: get_flag = 6;break;
  68.                                         case 0x28: get_flag = 7;break;
  69.                                         case 0x41: get_flag = 8;break;
  70.                                         case 0x42: get_flag = 9;break;
  71.                                         case 0x44: get_flag = 10;break;
  72.                                         case 0x48: get_flag = 11;break;
  73.                                         case 0x81: get_flag = 12;break;
  74.                                         case 0x82: get_flag = 13;break;
  75.                                         case 0x84: get_flag = 14;break;
  76.                                         case 0x88: IAP_CONTR = 0x20;break;//复位
  77.                                         default:   get_flag = 16;break;
  78.                                 }
  79.                         }
  80.                 }
  81.                 else IO_KeyHoldCnt = 0;
  82.         }
  83.         P0 = 0xff;
  84. }
  85. /********************延时函数******************************/
  86. void Delay1ms()                //@11.0592MHz
  87. {
  88.         _nop_();
  89.         _nop_();
  90.         _nop_();
  91.         i = 11;
  92.         j = 190;
  93.         do
  94.         {
  95.                 while (--j);
  96.         } while (--i);
  97. }
  98. void Delay_ms(u8 xms)
  99. {
  100.         for (k=0;k<xms;k++)
  101.         {
  102.                 Delay1ms();
  103.         }
  104. }
  105. ///********************** Timer0初始化 ************************/
  106. void Timer0Init(void)                //1毫秒 @11.0592MHz
  107. {
  108.         AUXR = 0x80;                //定时器时钟1T模式
  109.         TMOD = 0x00;                //设置定时器模式
  110.         TL0 = 0xCD;                //设置定时初值
  111.         TH0 = 0xD4;                //设置定时初值
  112.         EA = 1;                    //开启总中断
  113.         ET0 = 1;                //允许定时器0中断
  114.         TF0 = 0;                //清除TF0标志
  115.         TR0 = 1;                //定时器0开始计时
  116. }
  117. ///********************** Timer0中断函数 ************************/
  118. void timer0 (void) interrupt 1
  119. {
  120.         counter++;
  121.         DisplayScan();
  122. }
  123. /********************** 主函数 ************************/
  124. void main(void)
  125. {
  126.         GPIO();
  127.         Timer0Init();
  128.         for (k = 0; k < 8; k++) LED8[k] = 17;
  129.         Delay_ms(1000);
  130.         counter = 0;
  131.         while(1)
  132.         {
  133.                 if(counter == 50)
  134.                 {
  135.                         IO_KeyScan();
  136. ……………………
  137. …………限于本文篇幅 余下代码请从51黑下载附件…………
拨号.rar (35 KB, 下载次数: 12)
收藏收藏2 分享淘帖 顶顶 踩踩
