查看: 7732|回复: 1
51单片机pwm的控制汇编语言源程序
原理图:
采用time0产生pwm波,int0中断记录外部脉冲,time1计时1秒定时
以下是程序:
K1  EQU  P1.0    ;¼ó
K2  EQU  P1.1    ;¼õ
ORG  0000H
AJMP MAIN
ORG  0040H
MAIN:
    MOV   SP,#60H
        MOV   R1,#3      ;3õê¼Õ¼¿Õ±è50%
        MOV   R2,#4
        MOV   R3,#0
        MOV   TH0,#0FFH
        MOV   TL0,#9CH
        MOV   TH1,#3CH
        MOV   TL1,#0B0H
        MOV   TMOD,#11H
    MOV   IE,#8FH
        SETB  IT0
        SETB  IT1
        SETB  TR0
        SETB  TR1
LOOP:
    MOV A,R1
    JB K2,S1
    CALL DELAY
    JB K2,S1
    CJNE A,#9,PWMINC
    CALL  LED
    SJMP LOOP
PWMINC:
    INC R1
    SJMP LOOP
S1:
    JB K1,S2
    CALL DELAY
    JB K1,S2
    CJNE A,#1,PWMDEC
    CALL  LED
    SJMP LOOP
PWMDEC:
    DEC R1
S2:    SJMP LOOP
ORG   000BH
AJMP  TIME0
ORG   0100H
TIME0:
    MOV A,#9
    SUBB A,R2
        JNC DONE
        INC R2
        SJMP LOOP1
DONE: MOV R2,#1
LOOP1:  CLR  C
        MOV A,R2
                SUBB A,R1
                JNC LOOP2
                SETB P1.6
                SJMP OUT1
LOOP2:  CLR P1.6
OUT1:  RETI
ORG   0003H
LJMP  IN0
ORG   1000H
IN0:
     INC R3
         RETI
LED:
    CPL P1.2
        RET
DELAY:
    MOV  R7,#100
DE: MOV  R6,#100
    DJNZ R6,$
        DJNZ R7,DE
        RET
        END
ID:828826 发表于 2020-10-12 16:11 | 只看该作者
能不能注释一下
