查看: 5326|回复: 5
SSD1306 OLED arduino例程
ID:258849 发表于 2017-12-7 21:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. /*********************************************************************
  2. This is an example for our Monochrome OLEDs based on SSD1306 drivers
  3.   Pick one up today in the adafruit shop!
  4. This example is for a 128x64 size display using I2C to communicate
  5. 3 pins are required to interface (2 I2C and one reset)
  6. Adafruit invests time and resources providing this open source code,
  7. please support Adafruit and open-source hardware by purchasing
  8. products from Adafruit!
  9. Written by Limor Fried/Ladyada  for Adafruit Industries.
  10. BSD license, check license.txt for more information
  11. All text above, and the splash screen must be included in any redistribution
  12. *********************************************************************/
  13. #include <SPI.h>
  14. #include <Wire.h>
  15. #include <Adafruit_GFX.h>
  16. #include <Adafruit_SSD1306.h>
  17. #define OLED_RESET 4
  18. Adafruit_SSD1306 display(OLED_RESET);
  19. #define NUMFLAKES 10
  20. #define XPOS 0
  21. #define YPOS 1
  22. #define DELTAY 2
  23. #define LOGO16_GLCD_HEIGHT 16
  24. #define LOGO16_GLCD_WIDTH  16
  25. static const unsigned char PROGMEM logo16_glcd_bmp[] =
  26. { B00000000, B11000000,
  27.   B00000001, B11000000,
  28.   B00000001, B11000000,
  29.   B00000011, B11100000,
  30.   B11110011, B11100000,
  31.   B11111110, B11111000,
  32.   B01111110, B11111111,
  33.   B00110011, B10011111,
  34.   B00011111, B11111100,
  35.   B00001101, B01110000,
  36.   B00011011, B10100000,
  37.   B00111111, B11100000,
  38.   B00111111, B11110000,
  39.   B01111100, B11110000,
  40.   B01110000, B01110000,
  41.   B00000000, B00110000 };
  42. #if (SSD1306_LCDHEIGHT != 64)
  43. #error("Height incorrect, please fix Adafruit_SSD1306.h!");
  44. #endif
  45. void setup()   {
  46.   Serial.begin(9600);
  47.   // by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
  48.   display.begin(SSD1306_SWITCHCAPVCC, 0x3C);  // initialize with the I2C addr 0x3D (for the 128x64)
  49.   // init done
  50.   // Show image buffer on the display hardware.
  51.   // Since the buffer is intialized with an Adafruit splashscreen
  52.   // internally, this will display the splashscreen.
  53.   display.display();
  54.   delay(2000);
  55.   // Clear the buffer.
  56.   display.clearDisplay();
  57.   // draw a single pixel
  58.   display.drawPixel(10, 10, WHITE);
  59.   // Show the display buffer on the hardware.
  60.   // NOTE: You _must_ call display after making any drawing commands
  61.   // to make them visible on the display hardware!
  62.   display.display();
  63.   delay(2000);
  64.   display.clearDisplay();
  65.   // draw many lines
  66.   testdrawline();
  67.   display.display();
  68.   delay(2000);
  69.   display.clearDisplay();
  70.   // draw rectangles
  71.   testdrawrect();
  72.   display.display();
  73.   delay(2000);
  74.   display.clearDisplay();
  75.   // draw multiple rectangles
  76.   testfillrect();
  77.   display.display();
  78.   delay(2000);
  79.   display.clearDisplay();
  80.   // draw mulitple circles
  81.   testdrawcircle();
  82.   display.display();
  83.   delay(2000);
  84.   display.clearDisplay();
  85.   // draw a white circle, 10 pixel radius
  86.   display.fillCircle(display.width()/2, display.height()/2, 10, WHITE);
  87.   display.display();
  88.   delay(2000);
  89.   display.clearDisplay();
  90.   testdrawroundrect();
  91.   delay(2000);
  92.   display.clearDisplay();
  93.   testfillroundrect();
  94.   delay(2000);
  95.   display.clearDisplay();
  96.   testdrawtriangle();
  97.   delay(2000);
  98.   display.clearDisplay();
  99.   testfilltriangle();
  100.   delay(2000);
  101.   display.clearDisplay();
  102.   // draw the first ~12 characters in the font
  103.   testdrawchar();
  104.   display.display();
  105.   delay(2000);
  106.   display.clearDisplay();
  107.   // draw scrolling text
  108.   testscrolltext();
  109.   delay(2000);
  110.   display.clearDisplay();
  111.   // text display tests
  112.   display.setTextSize(1);
  113.   display.setTextColor(WHITE);
  114.   display.setCursor(0,0);
  115.   display.println("Hello, world!");
  116.   display.setTextColor(BLACK, WHITE); // 'inverted' text
  117.   display.println(3.141592);
  118.   display.setTextSize(2);
  119.   display.setTextColor(WHITE);
  120.   display.print("0x"); display.println(0xDEADBEEF, HEX);
  121.   display.display();
  122.   delay(2000);
  123.   display.clearDisplay();
  124.   // miniature bitmap display
  125.   display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  126.   display.display();
  127.   delay(1);
  128.   // invert the display
  129.   display.invertDisplay(true);
  130.   delay(1000);
  131.   display.invertDisplay(false);
  132.   delay(1000);
  133.   display.clearDisplay();
  134.   // draw a bitmap icon and 'animate' movement
  135.   testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_HEIGHT, LOGO16_GLCD_WIDTH);
  136. }
  137. void loop() {
  138. }
  139. void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  140.   uint8_t icons[NUMFLAKES][3];
  141.   // initialize
  142.   for (uint8_t f=0; f< NUMFLAKES; f++) {
  143.     icons[f][XPOS] = random(display.width());
  144.     icons[f][YPOS] = 0;
  145.     icons[f][DELTAY] = random(5) + 1;
  146.     Serial.print("x: ");
  147.     Serial.print(icons[f][XPOS], DEC);
  148.     Serial.print(" y: ");
  149.     Serial.print(icons[f][YPOS], DEC);
  150.     Serial.print(" dy: ");
  151.     Serial.println(icons[f][DELTAY], DEC);
  152.   }
  153.   while (1) {
  154.     // draw each icon
  155.     for (uint8_t f=0; f< NUMFLAKES; f++) {
  156.       display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, WHITE);
  157.     }
  158.     display.display();
  159.     delay(200);
  160.     // then erase it + move it
  161.     for (uint8_t f=0; f< NUMFLAKES; f++) {
  162.       display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, BLACK);
  163.       // move it
  164.       icons[f][YPOS] += icons[f][DELTAY];
  165.       // if its gone, reinit
  166.       if (icons[f][YPOS] > display.height()) {
  167.         icons[f][XPOS] = random(display.width());
  168.         icons[f][YPOS] = 0;
  169.         icons[f][DELTAY] = random(5) + 1;
  170.       }
  171.     }
  172.    }
  173. }
  174. void testdrawchar(void) {
  175.   display.setTextSize(1);
  176.   display.setTextColor(WHITE);
  177.   display.setCursor(0,0);
  178.   for (uint8_t i=0; i < 168; i++) {
  179.     if (i == '\n') continue;
  180.     display.write(i);
  181.     if ((i > 0) && (i % 21 == 0))
  182.       display.println();
  183.   }
  184.   display.display();
  185.   delay(1);
  186. }
  187. void testdrawcircle(void) {
  188.   for (int16_t i=0; i<display.height(); i+=2) {
  189.     display.drawCircle(display.width()/2, display.height()/2, i, WHITE);
  190.     display.display();
  191.     delay(1);
  192.   }
  193. }
  194. void testfillrect(void) {
  195.   uint8_t color = 1;
  196.   for (int16_t i=0; i<display.height()/2; i+=3) {
  197.     // alternate colors
  198.     display.fillRect(i, i, display.width()-i*2, display.height()-i*2, color%2);
  199.     display.display();
  200.     delay(1);
  201.     color++;
  202.   }
  203. }
  204. void testdrawtriangle(void) {
  205.   for (int16_t i=0; i<min(display.width(),display.height())/2; i+=5) {
  206.     display.drawTriangle(display.width()/2, display.height()/2-i,
  207.                      display.width()/2-i, display.height()/2+i,
  208.                      display.width()/2+i, display.height()/2+i, WHITE);
  209.     display.display();
  210.     delay(1);
  211.   }
  212. }
  213. void testfilltriangle(void) {
  214.   uint8_t color = WHITE;
  215.   for (int16_t i=min(display.width(),display.height())/2; i>0; i-=5) {
  216.     display.fillTriangle(display.width()/2, display.height()/2-i,
  217.                      display.width()/2-i, display.height()/2+i,
  218.                      display.width()/2+i, display.height()/2+i, WHITE);
  219.     if (color == WHITE) color = BLACK;
  220.     else color = WHITE;
  221.     display.display();
  222.     delay(1);
  223.   }
  224. }
  225. void testdrawroundrect(void) {
  226.   for (int16_t i=0; i<display.height()/2-2; i+=2) {
  227.     display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, WHITE);
  228.     display.display();
  229.     delay(1);
  230.   }
  231. }
  232. void testfillroundrect(void) {
  233.   uint8_t color = WHITE;
  234.   for (int16_t i=0; i<display.height()/2-2; i+=2) {
  235.     display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, color);
  236.     if (color == WHITE) color = BLACK;
  237.     else color = WHITE;
  238.     display.display();
  239.     delay(1);
  240.   }
  241. }
  242. void testdrawrect(void) {
  243.   for (int16_t i=0; i<display.height()/2; i+=2) {
  244.     display.drawRect(i, i, display.width()-2*i, display.height()-2*i, WHITE);
  245.     display.display();
  246.     delay(1);
  247.   }
  248. }
  249. void testdrawline() {
  250.   for (int16_t i=0; i<display.width(); i+=4) {
  251.     display.drawLine(0, 0, i, display.height()-1, WHITE);
  252.     display.display();
  253.     delay(1);
  254.   }
  255.   for (int16_t i=0; i<display.height(); i+=4) {
  256.     display.drawLine(0, 0, display.width()-1, i, WHITE);
  257.     display.display();
  258.     delay(1);
  259.   }
  260.   delay(250);
  261.   display.clearDisplay();
  262.   for (int16_t i=0; i<display.width(); i+=4) {
  263.     display.drawLine(0, display.height()-1, i, 0, WHITE);
  264.     display.display();
  265.     delay(1);
  266.   }
  267.   for (int16_t i=display.height()-1; i>=0; i-=4) {
  268.     display.drawLine(0, display.height()-1, display.width()-1, i, WHITE);
  269.     display.display();
  270.     delay(1);
  271.   }
  272.   delay(250);
  273.   display.clearDisplay();
  274.   for (int16_t i=display.width()-1; i>=0; i-=4) {
  275.     display.drawLine(display.width()-1, display.height()-1, i, 0, WHITE);
  276.     display.display();
  277.     delay(1);
  278.   }
  279.   for (int16_t i=display.height()-1; i>=0; i-=4) {
  280.     display.drawLine(display.width()-1, display.height()-1, 0, i, WHITE);
  281.     display.display();
  282.     delay(1);
  283.   }
  284.   delay(250);
  285.   display.clearDisplay();
  286.   for (int16_t i=0; i<display.height(); i+=4) {
  287.     display.drawLine(display.width()-1, 0, 0, i, WHITE);
  288.     display.display();
  289.     delay(1);
  290.   }
  291.   for (int16_t i=0; i<display.width(); i+=4) {
  292.     display.drawLine(display.width()-1, 0, i, display.height()-1, WHITE);
  293.     display.display();
  294.     delay(1);
  295.   }
  296.   delay(250);
  297. }
  298. void testscrolltext(void) {
  299.   display.setTextSize(2);
  300.   display.setTextColor(WHITE);
  301.   display.setCursor(10,0);
  302.   display.clearDisplay();
  303.   display.println("scroll");
  304.   display.display();
  305.   delay(1);
  306.   display.startscrollright(0x00, 0x0F);
  307.   delay(2000);
  308.   display.stopscroll();
  309.   delay(1000);
  310.   display.startscrollleft(0x00, 0x0F);
  311.   delay(2000);
  312.   display.stopscroll();
  313.   delay(1000);
  314.   display.startscrolldiagright(0x00, 0x07);
  315.   delay(2000);
  316.   display.startscrolldiagleft(0x00, 0x07);
  317.   delay(2000);
  318.   display.stopscroll();
  319. }
ID:280937 发表于 2018-9-19 20:04 来自触屏版 | 只看该作者
点解决我用NANO显示不成功?
请指教
ID:511799 发表于 2019-4-14 13:19 | 只看该作者
请问你这OLED的引脚定义的在哪里
