查看: 8715|回复: 0
74HC595的单片机驱动程序
ID:249919 发表于 2017-12-12 08:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
sbit si=P2^2;  //数据线  74hc595的14管脚
sbit rck=P2^3;  //输出储存器锁存时钟线 74hc595的12管脚
sbit sck=P2^4;  //数据输入时钟线           74hc595的11管脚
sbit sclr=P2^5;    //移位寄存器清零端  74hc595的10管脚
void delay(unsigned char p)
        unsigned char i;
        while(p--)
        for(i=110;i>0;i--);
void write_data(unsigned char pp)
                unsigned char i;
                sclr=1;
                for(i=0;i<8;i++)
        {   sck=0;
                if(pp&0x80)
                si=1;
                else si=0;
                sck=1;
                pp<<=1;
                rck=0;
                delay(5000);
                rck=1;
                delay(5000);
                rck=0;
         unsigned char q=0xfe;
        sclr=0;
        delay(5000);
        sclr=1;
         write_data(q);
          delay(1);
          q=_crol_(q,1);
          delay(25000);
