查看: 9895|回复: 3
STM32+FPM10A指纹识别源程序与原理图
ID:262045 发表于 2017-12-15 15:28 | 显示全部楼层 |阅读模式
有个STM32指纹识别的代码分享出来
视频:
FPM10A指纹识别技术手册资料:
  1. #include "sys.h"
  2. #include "usart.h"
  3. #include "delay.h"
  4. #include "key.h"
  5. #include "lcd1602.h"
  6. #include "fpmxx.h"
  7. unsigned char LCD_ID_11[16] = {"    Huan Ying   "};
  8. unsigned char LCD_ID_22[16] = {"     Shi Bai    "};
  9. unsigned char LCD_ID_33[16] = {"  Qing Shi Yong "};
  10. void FPMXX_Check_Module()
  11. {
  12.          unsigned int i=0;
  13.          FPMXX_Cmd_Check();
  14.    for(i=0;i<12;i++)
  15.          {
  16.            FPMXX_RECEICE_BUFFER[i] = UART_Receive_Byte();//UART Receive a byteg
  17.    }
  18.          if(FPMXX_RECEICE_BUFFER[8]==0x03)
  19.          {
  20.                  for(i=0;i<556;i++)
  21.                  {
  22.                          switch(i)
  23.                          {
  24.                                  case 37:FPMXX_RECEICE_BUFFER[1] = UART_Receive_Byte();break;
  25.                                  case 38:FPMXX_RECEICE_BUFFER[2] = UART_Receive_Byte();break;
  26.                                  case 39:FPMXX_RECEICE_BUFFER[3] = UART_Receive_Byte();break;
  27.                                  case 40:FPMXX_RECEICE_BUFFER[4] = UART_Receive_Byte();break;
  28.                                  case 41:FPMXX_RECEICE_BUFFER[5] = UART_Receive_Byte();break;
  29.                                  default:FPMXX_RECEICE_BUFFER[0] = UART_Receive_Byte();
  30.                          }
  31.                  }
  32.
  33.                  //判断指纹模块型号
  34.                  if(FPMXX_RECEICE_BUFFER[1] == 0x46 && +
  35.                           FPMXX_RECEICE_BUFFER[2] == 0x50 && +
  36.                                 FPMXX_RECEICE_BUFFER[3] == 0x4D && +
  37.                                 FPMXX_RECEICE_BUFFER[4] == 0x31 && +
  38.                                 FPMXX_RECEICE_BUFFER[5] == 0x30)
  39.                  {
  40.                          L1602_string(1,1,LCD_ID_11);
  41.                          while(1)
  42.                          {
  43.                                  if(KEY0 == 0)
  44.                                  {
  45.                                          Delay_Ms(10);
  46.                                          while(KEY0 == 0);
  47.                                          Delay_Ms(100);
  48.                                          break;
  49.                                  }
  50.                                  Delay_Ms(100);
  51.                          }
  52.                  }
  53.          }
  54. }
  55.
  56. int main(void)
  57. {
  58.           Stm32_Clock_Init(9);//系统时钟设置
  59.         delay_init(72);                //延时初始化
  60.         uart_init(72,57600); //串口1初始化
  61.
  62.     KEY_Init();
  63.         L1602_init();
  64.         Delay_Ms(20);
  65.         USART1->DR=0X00;
  66.         while((USART1->SR&0X40)==0);//等待发送结束
  67.         Delay_Ms(20);
  68.         L1602_string(1,1,LCD_ID_22);
  69.         FPMXX_Check_Module();
  70.         while(1)
  71.         {
  72.         L1602_string(1,1,LCD_ID_11);
  73.                 L1602_string(2,1,LCD_ID_33);
  74.                 //添加指纹
  75.                 if(KEY0 == 0)
  76.                 {
  77.                         Delay_Ms(10);
  78.                         while(KEY0==0); //等待松开按键
  79.                         Delay_Ms(100);
  80.                         FPMXX_Add_Fingerprint();
  81.                 }
  82.                 //添加指纹
  83.
  84.                 //搜索指纹
  85.                 if(KEY1 == 0)
  86.                 {
  87.                         Delay_Ms(10);
  88.                         while(KEY1==0); //等待松开按键
  89.                         Delay_Ms(100);
  90.                         FPMXX_Find_Fingerprint();
  91.                 }
  92.                 //搜索指纹
  93.                 //清空指纹
  94.                 if(KEY2 == 0)
  95.                 {
  96.                         Delay_Ms(10);
  97.                         while(KEY2==0); //等待松开按键
  98.                         Delay_Ms(100);
  99.                         FPMXX_Delete_All_Fingerprint();
  100.                 }
  101.                 //清空指纹
  102.         }
  103. }
STM32指纹识别.zip (835.46 KB, 下载次数: 193)
ID:257640 发表于 2018-1-8 16:19 | 显示全部楼层
程序不完整
ID:375715 发表于 2019-4-27 19:32 来自触屏版 | 显示全部楼层
谢谢分享
ID:786182 发表于 2020-6-21 22:50 | 显示全部楼层
你的指纹模块怎么封装的
